Question about Ricoh Aficio 1018D Copier
Paper a misfeed
Paper passes halfway though the fuser and stops. the paper is getting stuck in the first drawer of the copier
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Ricoh Master
  • 1,362 Answers
Not sure if you are talking about two papers jammed in different locations or at different times?
first thing would be to clean the tires that pick up the paper, if too smooth then replace. sounds like a timing issue.paper getting stuck halfway in the fuser c(if no other paper jammed) can be Seperation is off causing the paper to rise onto the drum creating a time lapse, paper tansport belt (in the machine after the drum) is not turning ok, or as simple as wrong size paper Letter in machine but says Legal 8 1/2 x 14
Posted on Aug 27, 2008
Misfeed detected but there is no paper jam have removed the paper
It is possible that a switch is stuck. Most commonly on that model it is the switch just above the fuser (the hot part of the machine ). This switch can get stuck or knocked completely out of the machine.
Apr 21, 2015 | Minolta C350 Printer
Misfeed in copier and total counter 463898
Your information too general. But base on your meter reading counter, I assumed a lot of your copier's parts might worn out.
1) Check any paper jammed remaining in the copier. You might accidentally tore the paper and the other tore remaining paper still in the copier.
2) Open and close all the covers. its all on the right side.
-fuser cover,side cover (T/S block section), duplex cover, drawer 1 cover (just below bypass), optional drawer cover (if there is LCT or LCF)
2) Replaced the feed, separation rollers for the drawers,
3) Check the fuser condition. Replace them if condition is not good.
Mar 08, 2015 | Toshiba e-Studio 350 Copier
How removed misfeed indicated problem?
a miss feed mean the roller could not get the paper, so clean the roller (s) or have them replaced, try a different paper draw
Jun 25, 2014 | Konica Minolta Di2010 Di2510 Di3010 Di3510...
We can not clear the paper jam error. We have cleared the paper jam, turned the unit on and off, unplugged the unit, moved all the rollers, can not see any pieces of paper that are still in the misfeed but...
This copier has 4 sensor
1. paper sensor
It is called paper sensor its installed paper tray
2.Drawer sensor
3. Drive sensor its installed middle position
4. Exit sensor it is in fuser unite.
May be any sensor displace or broken.So you should check it.
Good luck.
Feb 16, 2011 | Sharp AL 1631 Copier
Paper gets stuck halfway
Fuser problem:
start a print from tray 1/manual feed and just as the trailing edge of paper is entering the machine; quickly open it to stop print and take out the cartridge and look at it
Dec 15, 2010 | Samsung ML 1610 Laser Printer
Misfeed
there is most likely a small piece of paper on a sensor/
remove paper tray and look inside, is there paper behind the tray? look at the tires are they bald and sniny? replace. Look at the tires and see if there is any scrap of paper there.
open right door and look down towards the paper tray, do you see any pieces of paper? there is a small black lever there, it's the sensor is it stuck?
look into the fuser (where it gets hot) ,you may have to remove it the paper sometimes gets crumbled like an accordion there, htere is also a small black lever there see any paper is it stuck?
Sep 15, 2008 | Sharp AL 1631 Copier
Paper a misfeed
It should be looked at by a technician to see if there is any work needed to be done on the fuser section. It could be something as simple as a bearing replacement or a fuser roller.
Jul 26, 2008 | Ricoh Aficio 1013F Copier
Paper Jam
1st, you need to find out exactly where the paper is getting stuck.
Is the paper stopping just as it gets to the rollers, or
stops when it goes through the rollers and are getting stuck on the little fuser claws?
If the paper is stopping right when it gets to the rollers, then there is a problem with the fuser drive or drive gears.
This you would probably need to place a service call to have repaired.
If the paper is getting stuck in the claws, then make sure that the claws are not stuck down. All claws should be up against the rollers, both upper and lower claws.
Sometimes they get stuck down or the spring gets knocked off.
Other than that, as long as both upper and lower fuser rollers are in good condition, paper should pass through.
If you have any other questions, feel free to repost.
Good luck.
If I have helped answer your question, please remember to post a rating.
Mac =)
Mar 18, 2008 | Toshiba 2060 Copier
Samsung CLP-300 Laser Printer
Try changing the printer toner cartridge first if not make sure that the paper of where the paper is stuck if under the toner cartridge check that there if there is any print on it and that it is entering the fuser section. If it has stopped at the fuser section then the possibility is that the fuser drive gear is broken or some teeth missing. If the paper is stuck before the toner cartridge then there maybe the pickup tyre dirty and not feeding correctly the other thing there maybe a sensor arm stuck down.
Try the above
Thanks J
Jan 19, 2008 | Samsung CLP 300 Laser Printer
My copier makes a noisy sound
Check the crumpled paper. If it has an image, it has reached the drum and is crumpling at the fuser unit (part that gets hot). If that is the case the fuser gear and drive gear need to be replaced.
May 01, 2007 | Sharp AL 1215 Black and White Copier
155 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
