Look at the back of the LCD panel to see if the backlight lamps are flickering or not since bad T-CON board can be flickering on and off which will make you think you have the backlights problem.
Check for bad caps as well as suggested.
Either bad caps driving the 24v look next to the plug going to inverter board from the power supply or bad connections on transformers of inverter board
