Question about Amana Heating & Cooling
OLDER MODEL AMANA AC HEATPUMP WALL UNIT, 230. WILL NOT TURN ON, NO NOISE/ NO HUMMING ETC. HAVE VERIFIED ELECTRICITY IS AT WALL FIXTURE. WHERE IS LIKELY PLACE TO START CHECKING? WHERE IS MODEL NUMBER? IS NOT ON COVER, ONLY SAYS AMANA
After power come from the wall plug, it goes to the selector switch then to the thermostat!! !
Posted on Aug 27, 2008
I have an older amana central ac/heating unit, fan not turning outside, did pencil test, turns slowly then stops. changed capacitor a month or so ago all was fine. started making a humming noise so ran and...
Sounds like the fan motor has reached its endpoint. It will have to be removed and replaced. Find the dircuit breaker in your electric panel that supplies power to the air conditioner unit. When you have found the right one, even the humming sounds will be absent. The fan usually is at the top of the unit. You must have opened this to change the capacitor. Remove the fan band motor as a unit and take it to a store like Grangers and determine if they have a motor that would replace the one from your unit. If the motor has a model number on it, you may find a replacement available onlilne by Googling that number and the name Amana. Put electricians tape over the wires that led to the motor, just in case someone turns on the circuit breaker before you have completed the job
Oct 04, 2013 | Goodman CLQ36AR49 Air Conditioner
PTC073E35AXXX humming
sounds like a control transformer . No danger.
Nov 20, 2012 | Amana PTH123B25AJ Heat Pump Air...
I am looking for an ac adapter for a pixma mp600
I am not an expert on this, but my experience is:
I dont have an AC-DC adapter on my MP600, its a two pin mains lead directly inserted into the printer.
I am in the UK and the mains electricity is 230-240V @ 50Htz.
If you have a model that requires a power adaptor then you could buy a generic one as a replacement but make sure that the 'Current rating' (in amps or millamps) and voltage ratings match the old adaptor or you could set fire to your printer/home.
Good luck
Jan 16, 2012 | Canon PIXMA MP600 all-In-One InkJet...
Need instructions for installing- model 0192773 instructions # 3 ses connect red timer wire to wire from fixture using wire connector What is the wire from the fixture, is it postive or negative? no...
Open following link for large print instructions, and specific wiring step.
Read the additional help for step by step action.
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html#wiring
The 'wire from fixture' means the wire that goes to the light.
One of the two wires that previously connected to switch is 'wire from fixture.'
The wire that goes to light will not show any power when it is disconnected from switch, and will not test positive or negative.
Single phase household electricity does not test positive or negative.
Household electricity is AC current which means the electricity is an oscillating wave that reverses direction either 50 or 60 times per second, depending on which country you reside.
For example each electrical appliance, like TV or treadmill, has small rating sticker, and in US, the rating sticker will show 60Hz. This is 60 cycles per second. A 60Hz appliance will not work in India or New Zealand or other countries that have 50Hz electricity.
Batteries are DC current and will test positive or negative.
Household electricity is AC current and does not test positive or negative.
Open following link for general illustration of household wiring:
http://waterheatertimer.org/See-inside-main-breaker-box.html
Sep 07, 2011 | Intermatic Inc. ST01C Digital In-Wall...
Have amana heat pump ac unit,,condenser fan doesn,t turn when on, not cooling, makes humming noise
The fan needs to be cleaned and lubbed. If this cannot be done then replace the fan.
May 22, 2011 | Amana Heating & Cooling
Humming sound coming from compressor on goodman heatpump but the unit works fine
A humming sound is not unusual for any a/c compressor. In some cases the humming is nothing more than a loose exterior housing. If it works fine don't worry about the noise.
Oct 04, 2010 | Heating & Cooling
Amana thru the wall ac unit won't turn off
The adjustment knob on the unit does not turn down how do you get the knobs off? Can we replace the control unit with one that is touch control? Could the problem of it not turning down be the thermostat? It is an Amana PTC153A35AD wall unit.
Jul 02, 2009 | Heating & Cooling
Outside unit freezing over
check the outside drain in the pan if there is a plug in the bottom pull it out.the ptac unit will go into emergency heat and run more the colder it gets outside
Nov 23, 2008 | Amana PTH123B25AJ Heat Pump Air...
Amana wall ac unit
Try using your remote to turn it on. This is what worked for me. Hope it helps!
Sep 06, 2008 | Heating & Cooling
Heating & Cooling Logo
131 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
