Question about Olympus Camedia C-770 Digital Camera
UV filters
I have an Olympus C-770 camera and it says that the lens is 63mm and I was wondering if a 62mm UV Filter would work on it.
    Master:
  • 852 Answers
According to Olympus, you must use the CLA-4 lens adapter tube to attach a filter to the C-770. The CLA-4 tube then will accept any 55mm filter.
Posted on Sep 06, 2005
When I turn on my Sony A77,the screen is all red.Is there anything I can do to fix it
The first step I would do is to return the camera to factory default options and see if that fixes it.
Nov 30, 2014 | Sony a77II Alpha 77 Mark II Translucent...
Dear sirs; What type of uv filter fits a quantarary tech 10 28mm - 200mm zoom lens. I have several 62mm filters and the zoom lens does not accept the normal threaded screw on format common to lenses
First, make sure that the lens diameter is 62mm. It should say on the front or on the body of the lens. If this is correct, it could be a unique mount that would require a specific brand. If it's quantaray, it might require quantaray filters. If it's an old lens, it might require an attachment to the front of the lens that would act as a filter holder for the square filter tiles.
Jun 04, 2012 | Cameras
How do I remove my 62mm CPL filter?
Wow, four days I just can't get to all the question. Okay here is a solution or two. I've been in the situation several times when the filter just won't unscrew from the front of the lens. Well, the problem is you have to squeeze the lens to get a grip of it which believe it or not makes it out of round and it wil refuse to budge. So method one is to place a wide rubber band around the filter edge and very lightly with your fingers try to unscrew it without applying pressure to the filter (squeeze) This works for me 90% of the time. Another way is by placing the rubber bottom of a mouse pad flat against the filter face edge and unscrew the filter that way. You need to hold the camera/lens in one hand and the mouse pad against the filter with the other and gently turn it off. When it comes you will be amazed at how little pressure it took to turn it off. Best of luck
Dec 25, 2010 | Nikon 62mm Cpl Uv Fld Lens Filter Kit For...
Size of uv lens filter
Can you give me details of what kind of lens you have, Brand/Model with the F-stop size. Tony
Jun 03, 2010 | Olympus Cameras
What size uv filter do i need for an olympus sp-570uz camera ?
The SP-570UZ does not have a filter thread; therefore, lens filters cannot be attached directly to the camera.
Filters with 55mm diameter can be attached to the SP-570UZ via the CLA-10 Lens Tube Adapter, sold separately. However, it is not recommended because vignetting may occur in the corners of the image when the camera is set to wide angle positions.
The CLA-10 Lens Tube Adapter (Item #202104) is available from authorized Olympus dealers and also online from The Olympus Store: http://emporium.olympus.com
Apr 26, 2010 | Olympus SP-570UZ Digital Camera
My Nikon D40 18-55mm lens won't work on automatic
THERE is a problem in lens not with the UV filter
remove the lens clean the contact of lens & camera if not working repair or replace it
Jul 17, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Which types of filters can be used?
Please use thin type filters to prevent vignetting on the corners. The following filters are vignetting-free. Konica Minolta 49mm AC L37 (UV filter) (Thickness is approx. 5.5mm in total, and approx. 3.4mm excluding the screw part.) Konica Minolta 49mm ND 4x filter 49mm type causes vignetting. Please use Konica Minolta filter adapter (49mm > 62mm) and 62mm Polarizing filter II (Circular) in combination.
Sep 15, 2005 | Konica Minolta DiMAGE A2 Digital Camera
Lens Protection Size!!!
Get a CLA-1 lens tube. It screws into the camera body. The other end accepts 43mm accessories. Put on a 43-49mm step-up ring. Into that screw a 49mm UV filter. (The step-up ring is needed to separate the filter from the extended lens.) Leave the UV filter on at all times. Throw away the lens cap.
Sep 11, 2005 | Olympus Camedia C-3040 Zoom Digital Camera
Attach a conversion lens or filter
You will need the CLA-4 Lens Adapter. It provides a 55mm mounting thread for a 55mm filter or conversion lens.
Sep 04, 2005 | Olympus Camedia C-770 Digital Camera
Filters
Yes, the Olympus E-20N has a 62mm filter thread size. You can attach a standard 62mm lens filter directly on the lens. Color filters would not have an effect on the camera due to the auto white balance.
Aug 31, 2005 | Olympus Camedia E-20N Digital Camera
Olympus Camedia C-770 Digital Camera Logo
79 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
