Question about Yamaha RX-V2700 Receiver
RX-V1070/870 The display lights on front of panel do not work.
5 Suggested Answers
robotek
  • 1512 Answers
SOURCE: yamaha receiver/remote mute button.
Hi brawex
Try this first... unplug amp from the wall overnight and see if it powers up the same in the morning. If the problem is still there, then unplug and leave for 10 days....I know that's a while, but what we are trying to do here is reset the unit back to defaults. One of these 2 methods will allow the working memory of the unit to be cleared, and the mute problem will go away. You WILL also loose all your station presets and surround levels settings also, a small compromise to get it working again.
Another approach is to repair the remote control...I could talk you through that also. You choose. Comment back to me here if you want to go the full method and fix the remote :)
regards
Graeme
Posted on Mar 08, 2008
  • 16 Answers
SOURCE: RX-V1500- front panel lights not working
The display on an amp has two components.
A small Lamp (light bulb)
A LCD display with a color filter.
Normally when the display goes out the problem is with the lamp
The lamp on my RXV 870 died after about 9 years of use.
I called Yamaha and was able to by a replacement.
The lamp is an odd voltage 14.5 if I recall.
Looking at the receipt i should have bought 3 for the cost of shipping. It cost about 10.00 cnd,
Posted on Apr 01, 2008
VOTIT
  • 2071 Answers
SOURCE: RX-V1070 tuner fault
This only a cold solder symptom in tuner section .Just reworks all solder joints components parts in tuner section.
Good luck:
Regards:
Dont forget to rate.
Posted on Jun 30, 2009
SOURCE: Display panel does not light; sound is ok
Out of curiosity, could you please elaborate on your issue. My RX-730 display is completely dead. It should actually have two lights, one general backlight and then the LCD display to indicate station frequency, etc. Does either one of these work for you? If so, which one? Can you check the voltage at the output terminals for your backlight? It is pretty simple, just trace the wires from the display back to the connector header on the board and put your VOM leads across the two terminals with the unit powered up. What voltage reading are you getting. I just checked mine and read about 0.12 volts which seems kind of low for a lamp circuit. I'll let you know what the service manual says when I get my hands on one.
Posted on Jul 20, 2009
  • 127 Answers
SOURCE: Yamaha front panel display dim
You can change the LCD brightness in the Setup / Display menu.
Posted on Mar 02, 2010
How can I factory reset RX-V2092
Press MASTER ON/OFF on the front panel to
release it outward to the OFF position to turn
off this unit
Press and hold STRAIGHT on the front panel
and then press MASTER ON/OFF inward to
the ON position to turn on this unit.
This unit turns on, and the advanced setup menu
appears in the front panel display.
Rotate the PROGRAM selector on the front
panel to select "PRESET"
Press STRAIGHT on the front panel
repeatedly to select "RESET"
confirm your selection and turn off this unit
Dec 10, 2016 | Yamaha RX-V2092
My front panel display is not working.
check to make sure you don't have the dimmer down too low. you can adjust this option to make the room darker if the front panel is distracting while watching a movie etc.
Mar 14, 2014 | Yamaha RX-V530 Receiver
THE FRONT PANEL DISPLAY IS BLANK. HAVE I DONE
Perhaps, the manual mentions a Dimmer setting under the Display Set Menu but doesn't specify how dark it can get. Give it a try.
Dec 26, 2009 | Yamaha RX-V1000 Receiver
It may not need repair. if you have it hooked up to a TV, by video, s-video, or component. Press the menu button on the remote and you can see the main menu of the unit on the TV. Navigate the menu up/down/left/right/enter until you get to "display". You should be able to turn the display of the receiver on/off. If you don't have the manual. http://www.yamaha.com/yamahavgn/Documents/YEC/Stereo_Receivers/Manual/RX-797_e_U_p.pdf That's the PDF from Yamaha. I haven't used this particular unit, but that's the way it's done on all the other series. ie. RX-V or RX-Z. Hope this helps
Jun 02, 2009 | Yamaha RX-797 Receiver
Replace front side running light in a 2000 Lexus RX300
Unscrew 3 - 4 screws on the front tire fendor cover close to your side marker light. Pull the fender cover out, use your other hand to reach the side marker light. Using twist and pull the light set out. Replace a new light bulb. Replace everything in a reverse order.
Mar 18, 2009 | 2000 Lexus RX 300
The display light doesn't come on to indicate what the unit is doing (frequency, mode, etc.)
I assume that it plays, you just can't see the display. It may just need a new display bulb, that back lights the display.
Feb 22, 2009 | Yamaha RX-V730 Receiver
RX-V661 front display problem
Excess power supply demand from the display can cause the symptoms you describe. Unfortunately, the fix will be a new display if this is the case...accordianman
Jun 16, 2008 | Yamaha RX-V661 Receiver
Front display panel
Check for bad connections on the display pins themselves. Specifically, the ones on the ends are the power/ground pins.
Let us know if that resolves the problem. If not, we'll look further into the circuitry.
Dan
Apr 14, 2008 | Yamaha RX-V657 Receiver
Display is permanently "off" on the Yamaha RX-V620
Sounds like the LED that lights up the display has burnt out. An easy fix, if you're not afraid to take the front panel apart and resolder a new one.
Feb 05, 2008 | Yamaha RX-V620 Receiver
Apr 02, 2007 | Yamaha RX-V1500 Receiver
Yamaha RX-V2700 Receiver Logo
247 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
