Question about Kodak Office Equipment & Supplies
Fresh cartriges but the copies, faxes and photos come out light.
  • 659 Answers
Do a cleaning and print nozzle check on the system if not using the brand of ink from the printers company but a cheaper replacement the ink quality is not the same.
Posted on Aug 26, 2008
Ink cartrige problem i replaced both cartriges keeps saying right cartrige is incorrect wont let me print
Wiping the nozzles with a moistened soft cloth or removing and reinserting the cartridges usually helps. The cartridges for the Lexmark X7170 are black: 32/34 and color: 33/35. If these are the cartridges that you purchased and even tried your old and new cartridges yet the problem persists, please don't hesitate to contact Lexmark technical support.
Mar 23, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
It won't print black, the cartrige is new
I can get it to do sortof bubble-letters if I convert to a jpg or png or gif first, but the behavior here with my X4650 is very similar in that it won't do black at all from Word or web-browsers.
Oct 15, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
I'd like to refill the ink cartridge on my Philips
Yes, some have a chip on the cartrige unit, they cannot be reset.
Buy a new unit.
Sometimes using competitve ink in this machine can cause other problems.
The copies are light with background and with streaks, also sometimes the toner might be spilling below the developer housing or copy cartrige unit.
Good luck
Oct 14, 2009 | Philips Office Equipment & Supplies
My printer is displying an error message, saying- cartrige error, what should I do.
hi!!!! in that case there's a big possibility that your catridge was defective. Try to install another cartridge if that error message will pop up again.
Apr 19, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Cleaning the Xerox Workcentre Pro 575
More than likely, you have a bad toner cartridge.
Nov 12, 2008 | Xerox WorkCentre Pro 555 Plain Paper Laser...
My printer won't print from the computer command; it will print fax or copy a paper.
MY PRINTER WONT PRINT FROM THE COMPUTER. IT WILL COPY A PAPER, BUT NOTHING FROM THE COMPUTER COMMAND.
Nov 04, 2008 | HP Officejet 5510 All-In-One Thermal...
Lexmark X8350 gets power not much else
it could be jammed , but unplug it for a while then see if that helps, otherwise a faulty ink cartrige could cause it , a bad wire strip or connection , if none of that seems to be the problem then it is definately an electronic problem
Oct 09, 2008 | Lexmark X8350 Print, Scan, Copy and Fax...
Ink levels
on the printer reset the ink levels and in the sofware , otherwise the cartrige is to old and just wont register correctly
Oct 08, 2008 | Lexmark X8350 Print, Scan, Copy and Fax...
Brother intellifax 4750e
if the copy comes out black and/or sends black the Contact Image Sensor in the scanner may be needed.
Hope that helps...
Jun 17, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Light print of incoming faxes, cannot read
are copies light too? if not then it is sending fax, but most times it is inferior ink or drum causing the problem sometimes damp paper (try printing on reverse side as well)
Oct 31, 2007 | Brother IntelliFAX 2600 Fax
19 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
