Question about Alpine MRP-M350 Car Audio Amplifier
Light doesnt come on
Light does not come on checked all fuses and connection but nothing
  • xstaticx Jan 31, 2009
    I have a similar problem. I have 11-12 volts running in my power wire (before the fuse and after the fuse) when I have the power connected to my amp.
    So there should be current running to the amp, but I don't get a blue light to signal on and it basically doesn't work.
    I have gotten some power to the amp by hooking up the ground and connecting the remote, but it only lasts 3 seconds before it fades away.
    What is the next step to troubleshooting this?
  • 631 Answers
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Let me know if you have any other questions.
Posted on Aug 26, 2008
07 pilot cruise control doesnt work, light does not come on. Any suggestions?
Yes , your cruise control is computer controlled , your best bet .take it to the dealer . Nothing you can do .
Nov 27, 2017 | Cars & Trucks
Turn key on, nothing,doesnt turn over,no headlights, dome lights,nothing,new battery,good conections,no power to car
Assuming the battery is fully charged, it could be a bad connection, a bad battery cable, or a blow main fuse.
It also depends on the make model and year.
Feb 27, 2016 | Cars & Trucks
I was riding my bike and all of a sudden it just turned off. It has no power, no lights, engine doesnt turn over. nothing. The battery is brand new. any suggestions?
Batt connection may b bad. Or somethin in wiring harness. Fuses may lookgud but can havfault. Test w a lite. The inline fuse on the battery wire tu ignition may hav isuue..cant start a motor w out
Jun 08, 2015 | Motorcycles
Fuse burn out all the time. Interior light, door locks, trunck relese and radio.
Check what circuits are connected around this fuse, then check each one, test voltage and wire connections.
Good luck.
Jan 03, 2014 | Chrysler Concorde Cars & Trucks
Car wont start or crank nothing works total silence
Check battery connections. or battery. Try jumping it with a booster box or jumper cables. If nothing. Check your main fuse, it should be located in the black box under your hood. It is the huge fuse, (also could locate in the owner manual)
Nov 09, 2013 | 2002 Oldsmobile Silhouette
I think i might have fuse problem, my clock doesnt and doom light
Yes it can be the fuse problem.the fuses needs to be checked.
The other possibility can be short in the wiring's but needs to be checked.
There is a fuse associated with the clock. It is the same fuse for the Cigarette lighter, check the small panel by the drivers side pull out the coin holder and look at the diagram at the back to find where the fuse is.
In the Toyota Cramy Solara there are 3 fuse panels.
The main one is down by the drivers kick panel, another is by the passengers kick panel and last one  in the main engine compartment.
Thanks. you can rate this solution and show your appreciation.
May 20, 2010 | 2000 Toyota Camry Solara
Blower fan has no output. Temp guage not working
for blower motor check fuse hvac 20a int.panel and hvac 30a fuse in elect.center eng.compartment,if ok,check for 12v at blower connector if power is there fan is defect..temp.gauge check connection at unit if ok check resitance if it varies when engine warms up,if it doesnt vary replace unit,if it varies check wiring circuit,unit is place at drivers side of eng.block near sprk plugs.for hard to start;if check eng.light is not on could be in need of a tune-up depending on how long ago it was done,if check eng light is on or was on scan ecm for trouble code.
Oct 03, 2009 | 1999 Chevrolet Blazer
I have a 99 camry the went dead and i tried to jump it the horn blows good the head lights comes on but when i turn the key it says nothing the dash lights doesnt come on its like its not getting any power
There could be several reasons for your problem:
  1. Check your connections for tightness and corrosion. A corroded battery cable/post will diminish the current going to the dead battery.
  2. Check jumper connections
  3. Dead battery; the worse off the battery is, the more time it will take to charge the battery sufficiently enough to start the car; a completely dead battery with bad cells will never recharge sufficiently enough to hold a charge and start the car on a regular basis
Hope this answers your question. Best of luck.
Greg
Sep 04, 2009 | 1999 Toyota Camry
Nothing electrical works
the main terminal is a heavy red wire attached to the fuse block it should be clean and tight. also you can hook a test light from the battery neg. to the terminal it should light. if it doesn't light you could have a bad engine ground (primary ground). or a poor connection tot he main fuse block terminal previously mentioned
Sep 29, 2008 | 2002 Chevrolet Blazer
Alpine MRP-M350 Car Audio Amplifier Logo
111 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
