Question about Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
Maxtor 3200 error code 10
How do I resolve this error code problem? I have uninstalled and reinstalled the device, unplugged and plugged back in all to no avail.
Computer novice but need my backup info on this device-worried.
  • 16 more comments
  • tcartmell Aug 30, 2008
    I am getting the exact same error code.
  • pennster34 Sep 05, 2008
    i have the same problem i have tried the same things, i have looked high and low on the internet to find a solution-tried everything i could understand....i found something about a hotfix from microsoft but am unable to find anything. i really want this thing to snap out of it and work, i have a lot of important materials on this drive and am really upset because isnt this why we got this product, to backup our important documents? kind of upsetting
  • Anonymous Sep 10, 2008
    I got the code 10 error problem when connecting the hard drive to 2 different computers. The green light is on, but the disk is not spinning nor is it recognized by the system.
  • Anonymous Sep 23, 2008
    What is with this drive? It is just a lemon or what? I have the exact same problem. I've used it twice now, awhile back, with no problems, but now? Forget it. Won't work for anything.
  • crmulder Oct 03, 2008
    I have just upgraded to SP3 and now mine no longer spins up either......gotta love Microsoft...
  • Anonymous Oct 31, 2008
    3200 was working fine. Computer will not recognize it. In the past, I have never "listened" to it. So I dont know if it ever made any spinning noise or not. The green light come on, no noise. I upgraded to service pack 3 recently. I wonder if that could have caused the problem? If its power supply, will the light still come on?
  • crmulder Nov 07, 2008
    copycat, thanks for the assistance! I took the casing apart, hooked up the drive as a second inrternal hard drive, and it worked like a champ! No data loss whatsoever! Must have been the maxtor USB adapter...thanks for the post!
  • thebigo100 Nov 15, 2008
    f: doesn't show up on my computer. tried reinstalling with no results.
  • Rossjones123 Nov 30, 2008
    Im having the same problem
    when i plug it into my pc, it doesn't find it, then i go to device manager and it says i have Error 10
  • fenton2 Dec 08, 2008
    lets face it - we have all bough a turkey
  • missikershne Dec 15, 2008
    I have a maxtor 3200 and i keep getting a code 10 error and i cannot get it fixed! i have plugged and unplugged the external hard drive. I have uninstalled the driver on my computer and it won't fix the problem! I'm somewhat of a novice at fixing things so as clear instructions as possible would be great and I don't know a lot of lingo so again, keeping it clear would be great!
    thanks in advance for your help!
  • Anonymous Dec 17, 2008
    Having the same problem here. I find it odd that many of us, suddenly, have this same trouble.
  • Anonymous Jan 17, 2009
    I have the same problem. I lost all my old family photos..thanks Maxie.
  • Anonymous Jan 23, 2009
    I have the same error code 10 problem, and lost all of my financial records, and invoice photos. Help!!!!!
  • Anonymous Feb 05, 2009
    Help! Yes, I'm having the same problem with my Maxtor not being recognized and getting a Code 10 error.
  • rodious2003 Feb 27, 2009
    I have taken out my 6L200P0 harddrive from the casing and i looked into my 2003 dell 2400 with no luck on a connection to temporarily slave from. Are there any other suggestions as to how I can move the memory to a different external harddrive? I have purchased a new drive from a reputable company LaCie this time. How can I transfer the data? Then drop this maxtor piece of **** off a 10 story building...
    Unfortunately this product is no longer in circulation so I can't buy the drive to use for mine and then take it back. Does anyone have a working USB adapter I can use?
  • FOREMAN1172 May 25, 2009
    i have not tried any of the removal solutions of usb card and dont knonw how. nor tried a new power supply. ill check it out because maxtor says catastrofic failure junk it i got alot of material on this maxtor i need to keep i cant just pitch it. thnaks
  • yolanda1996 May 11, 2010
    Help! Yes, I'm having the same problem with my Maxtor not being recognized and getting a Code 10 error. I use my Maxtor (loaded with tons of photos and precious info) on my laptop. How can I solve my problem? Can I open my laptop and follow the same directions as opening a desktop. Thanks everyone for your solutions. I'm very nervous right now!
I had the same problem and this is what I did.
Problem:
Working for 1.5 years and suddenly quit. Computer did not recognize the hardrive.
Code 10 trying to mount harddrive.
My hard-drive did not make any noise, just a silent click.......click....
Condition:
This worked for me under the situation that:
I used this external drive on my desktop.
I have an available slave connector and power.
I know enough about the inside of my desktop to install a slave drive.
Solution:
Removed the drive from the box, and attach to computer Desktop as slave.
1) There are some slider latches on either lenth wise sides. Once disengaged top should come right off. Or just crack it open.
2) Once opened remove screws from metal Cage, and remove top of cage.
3) Remove three screws holding the USB adapter card. (All visible screws) Not the ones on the actual hard drive.
3) Carefull remove harddrive and the attached usb adapter card in one piece.
4) Remove the USB adapter card from hard drive.
5) Turn off computer to be installed, and unplug. Install drive direct, as slave. No jumpers to move since the drive is already set to slave.
6) Plug computer to test and if it is read and mounted, your ready to go.
7) turn off computer, and unplug. arrange cables in desktop case.
9) Close up the service panel and plug your computer back up.
I need to be sure before sending it in for recovery and spending $800. So I connected as slave to 2nd desktop computer and it mounted. This means that the "USB adapter card" that came with the maxtor3200 was faulty. It was recommended that the best way to back up on another harddrive is to directly plug your harddrive into your computer as slave.
Good Luck!
Copy-Cat
Posted on Nov 03, 2008
I had the same problem many here have had...
Dell 8300 running XP SP3
Solid light on the hard drive and on the power adapter and a faint clicking noise in the drive.
Windows would see the drive when plugged in but then after about 30 sec it would say that there was a problem and the divice may not work.
Device manager gave the code 10 error.
I broke the plastic shell off the drive, removed the drive from the wire cage, removed the USB card and installed the drive internally in my tower. Booted up and bingo!
I got 40 gigs of music and pictures back!
Thanks for the help.
Posted on May 14, 2009
Hi, I had the same problem, "code 10 error, device failed to start". Low buzzing sound and hard drive heating up more than usual.
Took it down to a local repair place where they took the case off and tried to plug it directly into the internal power yokey in a desktop tower.. same response. They concluded that the motor inside was seized and referred me to a data recovery specialist who said it would cost at least €700 to repair.
So then I took it home, moderately p***ed off, figured i had nothing to lose so i plugged it in to the power and just shook it! I shook it semi-violently in a kind of clockwise and anticlockwise rotation kind of way for about 10 seconds. Then i heard the low buzzing sound speed up and become a healthy working hard drive sound!
I guess it kind of push started the motor or dislodged something that was stuck, either way I'm very relieved.
So, if you've tried everything else and your about to shell out big bucks for data recovery, try shaking the bejeezus out of it! It's not a very sophisticated solution but it's cheap!
Posted on Jul 28, 2010
  • 3 Answers
Go to eBay. Get a DA-24B12-C Power Adapter made by Asian Power Devices, Inc.
Posted on Mar 08, 2010
I was searching for a fix to my MAXTOR ERRROR CODE 10 when I found this string and followed the advice for a fix.
I tried connecting the external drive to another machine with service pack 2 - no luck.
HOWEVER, upon removing the drive from it's original casing and installing it as a "slave" in my CPU - VOILA, it worked like a charm.
After rebooting the machince, the drive even showed up as "Maxtor external J ", which retained the alpha code that I had assigned to it in it's early days.
My "computer geek" agrees that it likely the USB connection in the original unit that is creating the problem..
DO NOT send your Maxtor drive out for any expensive repairs or service. All my data was still on the drive is DEFINITELY in tact.
It's a relatively simplty operation to remove the drive from its casing and install it in your CPU. Beg, borrow and get help from a knowledgable friend.
The entire job took about half an hour.
Posted on Aug 30, 2009
Following some of the advice further down in this forum i can confirm that changing the casing works. the power supply on the maxtor must be dodgy. I took out the actual HD and put it into another case and it now works perfectly. Took about 5 minutes
Posted on Jun 02, 2009
I have a maxtore 3200. never got an error message, just stopped working.
my $20 solution. Go to MicroCenter, buy an eide housing. CAREFULLY open the housing and remove the hard drive, which is safely inside a metal frame. Hook the drive to the internal controls, plug it into your PC - takes about 5 minutes- and you are good to go with all data intact.
good luck!
Posted on Oct 23, 2008
    New Friend:
Have do I get another power pack for my Maxtor hard drive External.And how much will it cost, Whats your Opion.
Posted on Feb 28, 2013
Had the same problem...drive would not start...took unit apart..removed the 3 screws holding circuit board out and removed hard drive and circuit board as one. removed power suppy plug from hard drive( 4 wire plug), took side cover off of desktop computer ..found a similar power supply plug and plugged it into maxtor drive unit...reconnected maxtor power plug and when i reconnected the USB cord to Maxtor and Desktop...IT POWERED UP
Posted on Jan 20, 2009
Code 10 is described by the help desk at Maxtor and the Geek Squad as a catastrophic failure that will take $100s if not $1000s of dollars to recover your date. Don’t buy it! Or at least until you check and see if your Maxtor 3200 external hard is trying to run on Windows XP with service pack 3. IT WILL NOT WORK. However, when I was able to go back to service pack 2, the drive that was supposed to be dead, worked just fine. In my opinion, find a computer that does not have service pack 3, get your data, and throw that junk Maxtor drive in the trash. Also, be very careful if you are trying to remove service pack 3 from your machine. That can cause allot more problems like you needing to reload Windows from scratch. Yeah! It happened to me but I did recover my data from a DEAD DRIVE with an error code 10.
Posted on Jan 15, 2009
  • yeahok Jan 15, 2009
  • yeahok Feb 13, 2009
    YOUR MOXTOR 3200 drive is alive and well. Don't believe the data recovery folks. I have seen two issues with this drive throwing a "Code10" which is supposed to mean death and $1000s of dollars.
    It means either you upgraded to service pack 3 or the power supply on the drive in failing. Both can be solved by the solutions provided already
i have the same problem folks ,green led flashing like crazy! jargelio is the man i changed my power supply,all fine now!
Posted on Oct 24, 2008
Posted on Sep 29, 2008
  • jargelio Oct 02, 2008
    I am getting the exact same error code and the solution was change the power supply and now I have back all my files and the maxtor its working again.
I had the same problem all of you had and I had just updated to XP Service Pack 3. I took the Maxton to another non-updated machine and it works wonderfully. I also took another Maxton 3200 (my back-up drive) and tried it on the updated XP machine and it also failed...... I do not think it is the Maxtor drives. I think it is something in Windows XP. Find an un-updated machine and try it before you give up on it.
Wow, I am in the same situation. Was on the Maxtor site. They indicate that the drive has failed. I have tried the samethings everyone else has. Looking on the internet for more info. My hard drive is about 3 years old.
Posted on Sep 24, 2008
Same problem here. Once I unplug, then replug, I get nothing. my entire company files are on this hard drive - I'll never buy Maxtor again.
Posted on Sep 20, 2008
The error code on maxtor's site says to open up a claim to get a new drive. Mine the green light is solid and the drive will not "spin up" like it use to. I am wondering if its a bad drive, power supply in the case, or something else. I want to know before sending it to data recovery.
Posted on Sep 08, 2008
Connection pc usb
This code is a hardware device error code..so this could mean that your device driver hasn't been installed properly on your computer or your computer is not seeing the necessary drivers for your phone.
so this is how you resolve it ok: open device manager and
  1. To open Device Manager, click Start, click Search programs and files, and then type Device Manager. A list of available matching items appears above the search box; click Device Manager. Device Manager opens with your computer name at the top and a list of devices that are installed on your computer beneath your computer name.
  2. Locate the malfunctioning device in the list of devices, right-click the device, and then click Uninstall. When a warning message appears that you are uninstalling a device from your system, click OK. Device manager uninstalls the device.
  3. Right-click your computer name in Device Manager and click Scan for hardware changes. Device manager scans your system and automatically reinstall your device.
  4. Right-click the device and click Properties. On the General tab of the device Properties dialog box, in Device status, you should see the message This device is working properly.
If the steps above do not resolve the problems with the device, , use the taskbar icon to safely eject the device, then unplug the device from the computer.If the device includes a drivers disk, ensure that you have it handy to install the device drivers; otherwise, Windows should automatically locate the correct drivers and install them.
If you do not have a driver disk and Windows cannot automatically detect the drivers, it means that your hardware manufacturer has not uploaded the drivers for your device to Windows Update. If this is the case, you must go to your device manufacturer web site to download or request the most recent drivers for your device.
Oct 05, 2013 | Nokia 6230i Cellular Phone
ISATAP Code 31?
receive error code 31 if the device driver is not updated.
As you have already updated the device try reinstalling the device driver and check if that works, if that does not resolve the issue you may ignore the error message, below link will you go more information related to this issue:
On a Windows Vista-based computer or on a Windows Server 2008-based computer, the Microsoft ISATAP adapter appears with a yellow exclamation mark next to it in Device Manager, and you also receive an error message
http://support.microsoft.com/default.aspx/kb/932520
Steps to uninstall and reinstall the device driver:
Uninstall and reinstall the device from device manger. Steps to uninstall the device:
i. Click Start, type devmgmt.msc and press enter.
ii. Locate Microsoft ISATAP Adapter device
iii. Right click on the device and select uninstall
iv. Restart the computer for the changes to happen
Uninstall and reinstall the adapter from Program and features. Steps to follow
i. Click Start and choose Control Panel
ii. In Control Panel double click on the "Programs and Features" icon.
iii. Here you can find all the programs and items which are installed in Windows Vista.
iv. To remove adapter click once on the program and then click on Uninstall/Change and follow the prompts.
hope this helps
Jul 03, 2012 | Microsoft ISATAP Adapter
I am unable to scan photos from my Hp psc2175 all in one ink jet printer from the printer to my HP windows xp computer "My pictures". I have uninstalled and reinstalled the printer to no...
Please follow the sequence below:
Unplug the device from the computer.
From Control Panel->Ad Remove Progs uninstall the device.
Reboot the computer.
Reinstall the device.
Plug in the device and allow Windows to auto detect the device and load its drivers.
Use the program provided by HP to scan.
And cheers.
Jul 07, 2011 | HP PSC 2210 All-In-One InkJet Printer
I have a brand new que drive external cd player,he wont work
you might have to physically unplug the leads for this cd burner then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you will have options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if your computer came with a motherboard disc the drivers could be on it
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps dont forget to vote
Mar 13, 2011 | QPS Que! Fire CD-RW Burner
I have a problem with driver ad-7561S. Please, help me.
you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Mar 06, 2011 | Sony NEC Optiarc AD-7200A IDE Internal DVD...
It goes to 100 percent then it kicks the cds out and say error code 2400
go into control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured you might be able to uninstall then reinstall some of these files/software
hope this helps
Jan 19, 2011 | MicroBoards (DSR-DVD-D884RM) DVD...
When I try to copy data to a DVD-R, I have a message saying, "DMA-error, crc-error"\r\n My LG DVD-R is primary IDE channel Device : 0 Transfer Mode : DMA if available Current Transfer Mode...
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
hope this helps
Dec 21, 2010 | LG GH22NP20 Super Multi DVDRW (R DL)...
To uninstall a device
  1. Open Device Manager.
  2. Double-click the type of device that you want to uninstall.
  3. Right-click the specific device you want, and then click Uninstall. You can also double-click the device, and then on the Driver tab, click Uninstall.
  4. In the Confirm Device Removal page, select Delete the driver software for this device if you also want to remove the device driver package from the driver store. .
    The Delete the driver software for this device option removes the package from the driver store. It does not remove the currently installed driver for any other operational devices that use the same driver. If you remove the driver from the store, and the device is connected to the computer again, Windows must search for a copy of the driver package in the standard search locations, including possibly prompting the user for media. This option is the equivalent of running the command: pnputil -d -f <package.inf>. For more information, see Remove a Driver Package from the Driver Store.
  5. Click OK to complete the uninstall process.
  6. When the uninstall process is complete, unplug the device from the computer.
    If you are prompted to restart the computer, the removal is not completed and the device might continue to function until the computer is restarted.
Reinstall a Plug and Play device Reinstall a device only if it is working improperly or it has stopped working altogether. Before you reinstall a device, try to restart your computer and check the device to determine whether it is functioning properly. If it is not, try reinstalling the device.
To reinstall a Plug and Play device
  2. Follow the instructions in the preceding procedure to uninstall the device.
  3. If you are prompted to restart the computer, follow these steps:
    • Plug in the device and then restart the computer. The device will be detected and reinstalled after Windows restarts.
    • Follow any instructions on-screen to complete installation.
  4. If you are not prompted to restart the computer, follow these steps:
    • In Device Manager, in the Action menu, click Scan for hardware changes.
    • Follow the instructions on the screen.
Dec 05, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Error code 10
You may need a driver. Download it from the manufacturer's website.
Or; right-click on MY COMPUTER icon, choose PROPERTIES, then click on the DRIVER tab, and click Update. Windows should install on or tell you that the one you have is ok.
IF that does not solve it; these disks notoriously ****... (die alot) it could be your drive. I have had 4 maxtors drop dead on me. Try your drive on another computer; if it is not recognized there; then it is your HDD- hope it's in warranty.
If another computer CAN recognize; then go back to DEVICE MANAGER and right click all your USB connections (under serial bus controllers) one at a time and UNINSTALL. DOn't worry about the warnings, just UNINSTALL. DO NOT DELETE!!
Restart your computer; and WINDOWS should reinstall them for you. Try plugging in your drive again.
IF no worky- its dead or your USB cable is old. Try a new USB.
My money, if it is a Maxtor, is it is croaked. You will need to either pay through the nose to get your files recovered; or find someone who knows how to take it apart; install it into a desktop bus internally and copy your files from there.
Good luck.
you can also try this help site http://www.pchell.com/hardware/usbcode10.shtml
Nov 20, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
3,926 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
