Question about Hotpoint WMA32 Front Load Washer
Hotpoint WMA32 drum problem
The bearings on the drum are damaged and I think the drum spider is damaged as well. Is this a relative straight forward job to repair myself if I buy Drum rear half with bearing kit already fitted or is it beyond ecomonical repair. Machine 5 years old.
  • 639 Answers
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
This machine in three years ago in the UK cost 280 pounds
You probably can buy it today for half the money from then!
I suggest a new one and not that model which had a lot of problems! Speed Queen has the best warranty.And does 8 loads a week for 25 years.
They start at about $549 in the States!
Not sure if they sell it in the UK????
Here is a good service that I recommend to my customers,
in our 65 year old appliance business! they answer 24/7
Not expensive!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 26, 2008
    New Friend:
  • 38 Answers
Your looking at around 3 hours to fix and it aint easy whole machine has to come to bits then split the drum then £12 for drum bareing kit and as long as nothing is to badly worn it costs you £12 just doing one as we speak ,no im not a repair man im a joiner just like to fix washing machines/tumble dryers hate to see the old folk getting ripped of
Posted on Oct 05, 2008
My zanussi essential 1200 6kg makes a really loud knocking noise when it spins. How do i repair it please?
Firstly,put your hand on the silver drum and revolve it back wards and forwards(side to side) ,if it feels as though it is or sounds rumbly the bearings have gone-not unknown with this make at 3 years of age!If this seems all ok,put one paddle in front of you and try to press down the drum at the front lip to see if it moves in relation to the front of the plastic tank-your trying to prove that the bearing shaft spider assembly hasn`t cracked-3 arms which are bolted between the drum and tank that holds the drum in place ie the bearing shaft-these arms match up to the 3 paddles.The spider is made from an AL2 alloy which is attacked by a fungus and makes it brittles so it cracks!!-strange to believe ,but true!!!!Suggest you turn of the power to the machine,undo the two lid screws at the rear of the machine and remove the w/top lid.Have a look at where the rear half and front half of the plastic tank are joined-i think from memory that these two are factory heat wielded so that it is impossible to dismantle the tank to replace the bearing or assoc parts even if you wanted to due to cost.Have alook and see!best of luck
Dec 02, 2010 | Zanussi IZ161S Front Load Washer
How to replace bearings in hotpoint washing machine. Has anuone got a plan view of what I need to do.
Hello,It's fairly straight forward,not easy though.The facial comes off(take the dispenser out and remove the four screws), front of the machine comes off (3 screws at the bottom and 3 behind the facial,the outer tub front comes off.)The pulley on the rear comes off,the inner drum can be knocked through.This gives you access to the bearings and bearing seal,not the easiest to get out.A lot of the time the outer race is left behind from the front bearing and it's a nightmare to get out.Hotpoint use a special bearing tool,get yourself a spider and bearing kit as well as a new tub seal.
Thanks
May 30, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
I have a aquarius hotpoint 340, bearing gone
You have to split the drum to replace the bearings
The reason the bearings have gone is that water has leaked into them and the soap content has destroyed the grease
There is a carbon seal on the spider assy which attaches to the back of the drum , this normally cracks so the spider or seal has to be replaced
Feb 24, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WMA54 - in middle of attempting to replace the drum bearings. I've split the drum apart and am attempting to remove the existing bearings and spider; however, I'm unable to separate/unscrew the...
Here are a series of free videos to help you with your bearing problems and how to fix them
For all your free videos on appliance repairs remember to mark us down and leave feed back please
For all your parts visit our site http://www.apart4u.co.uk
This first video shows you how to diagnose the problem
The next Hotpoint video is on how to take the drum out
This Hotpoint video will show you how to change the bearings in the drum tub
the last one will show you how to change the spider or drum support as they are known
Jan 09, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Change Bearings for HotPoint WMA62N
Hi, I also have the bearing problem on a hotpoint wma and have just stated the repair job. I have found the following on different forums, so maybe it might help others. You do need to remove the drum and there are two different sizes of bearings 30mm and 35mm. To find the size you need you have to get to the bearings and measure them.
. Ok,Hotpoint wma series drum bearing failure.Firstly very common problem since i work on these things every day-i think there is a design fault-nothing new in this trade!What follows is
the sequence of problems in changing the drum bearings:If the machine has been thrashed into oblivion just changing the oilseal/bearings will have you back to square one within a
couple of months since you would`ve damaged the drum shaft as the bigger bearing of the 2 goes into shapnell mode!So you`d best change the drum shaft(in the trade known as the
spider) however this thing is aluminium usually held onto the the drum via torx headed screws either in steel or soft Al2 also-forget it as your not going to get these out unless your mega
lucky,what we do at work is to replace the whole tank/drum/bearing assembly which comes with a new element and belt ie the whole tank unit,the trade price of this part is less than
£100.00-you can draw your own conclusions as to the retail price as you wish.If you haven`t thrashed the machine you can get away with replacing just the bearings or easier still the rear
half of the tank(trade price 30.00+vat) in which the bearings are already fitted via the factory and reuse the existing spider/drum shaft so long as it isn`t damaged by disintergrated bearing
shapnell.I hope this clears up this problem for you.Please note that this machine`s filter which is at the rear doubles up as the air trap-the oval section 8" long semi transpatent plastic tube
thing-the part that allows the water to compress the air so turning off the level of fill at the right level via the round swt behind the soap dispenser-called the pressure swt-if the filter gets
bunged up the machine o/fills and either overfills or overfills and floods or tries to spin with aload of water still inside the drum or perhaps no spin at all.Hope this helps someone.
The drum comes out through the front on this one. Take off kick plate and remove screws holding front panel to frame. Take out soap drawer & remove screws behind it. Take off band
holding door seal & peel seal back. Remove 2 screws holding door lock &push lock through. Pull control panel forward at left side & slide to right to remove being careful with board &
wiring. Remove screws holding top end of front then lift slightly &remove front. Remove back panel & take wiring off heating element & pump. Disconnect the pump hose at the drum end,
disconnect the hose from the soap dispenser, note that wiring is fastened to the drum at several points and will need to be disconnected. Remove panel from behind control board then
carefully move everything away from the front of the machine, the drum can now be lifted clear.
Forgot to mention unplugging motor but common sense will prevail.
Mar 11, 2009 | Hotpoint WMA64 Front Load Washer
Drum bearings need replacing
Mar 02, 2009 | Hotpoint WMA32 Front Load Washer
Washing machine noise spinning
Feb 12, 2009 | Hotpoint WMA31 Front Load Washer
Loud noise as drum turns,gets louder as speed increases.
There is no doubt that the drum bearings have failed from your description.
The normal procedure is to replace the whole drum and tub assy as a complete unit, this makes it a fairly straight forward repair, though relatively expensive.
To strip it down and replace worn bearings, is a very involved repair, and not one I would recommenend.
If the washer is less than 5 years old, then you can get it done under the Hotpoint 5 year part guarantee, but you would have to contact Hotpoint about this.
Plz rate my solution.
Thankyou.
Jan 25, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Very noisy
The washer is not a sealed unit but the rear drum bearing are also you will need a new spider...To take a look inside - Initially you will see enough from the top to see where things are...
1. UNPLUG the washer.
2. check you've unplugged.
3. Open the top of the machine - see the sides of the lid about 10 cm from front, remove plastic caps on each torx head, undo torx. (torx set required)
4. Remove concrete block from top - large spanner is required - remember the sequence so you can replace later.
5. Lean over the drum and see the large drive wheel.
If the Drum bearing has failed it is usually due to over loading or a faulty seal in the drum, water leaks into the inner bearing. This causes corrosion and then ultimately failure.
In the likely event that the bearings have failed (I have had a hotpoint wma33 fail at 23 months...) Its actually cheaper for you to pay hotpoint to fit a new drum (Parts are free for 5 years! you just pay a flat callout fee - believe me its a bargin). + they never ever replacing just bearings, it takes too long for them. They will do a whole drum and spider arrangement in under 2 hours...
I wasted 3 days because these things are really awkward to remove and refit. The callout fee for a hotpoint engineer a fixed cost. I bought a spider see:
http://www.4hotpoint.co.uk/cgi-bin/product.pl?PID=954798&brand=&model=wma33&part=spider
This spider costs 61.25 + delivery - ouch.
I bough a half drum thinking I would keep the costs down. Hotpoint will fit half a drum or full drum (Depending on what is on the van for their call out fee) the actual cost of a half drum is 75.99 + delivery see: http://www.4hotpoint.co.uk/cgi-bin/product.pl?PID=639770&brand=&model=wma33&part=drum
and a full drum costs 161.49 + delivery
see: http://www.4hotpoint.co.uk/cgi-bin/product.pl?PID=639763&brand=&model=wma33&part=drum
They take away all the rubbish at the end also!
I know this site is about doing it yourself and I can go into more details about how to do it. But because I did not have the correct tools that hotpoint must have to pull the bearings from the housing etc - I feel I would be wasting your time.
I hope this helps
Please don't rate me as unhelpful, this is not a simple change the bearings task.
Jul 06, 2008 | Hotpoint WMA40 Front Load Washer
Noisy drum
You are describing shot bearings.
It should be perfectly possible to replace the bearings if you are able to press them out of the spider.
The usual fix is to obtain a replacement spider, your local domestic appliance repair shop should be able to supply an exchange unit.
If you attempt the repair you should check that the drum has not damaged the water heaters as it may have been these that it was grinding on.
Oct 16, 2007 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint WMA32 Front Load Washer Logo
239 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
