Question about Toshiba Tecra 9100 Notebook
Problem after loading windows,display???
I need help ,so i start the machine working perfect and no problems.. until the windows start, it shows a black after loading .. but I can hear the sounds when is starting but nothing showing on display just black XC ..help me please and thank you!
  • Cheyzar Aug 26, 2008
    on safe mode it stops on loading???
  • g60gerry Feb 06, 2009
    Toshiba 9100, i have try'ed many times to get the laptop to boot up ..but to no avail it does not, It just about gets to the windows logo then 5 sec after that 'keeps on rebooting to the same point .....anyone able enought to shed some light on the issue please???
    Genius:
  • 2,028 Answers
This sounds like a driver glitch. You will need an external monitor in order to fix it and check it to be sure it's not a malfunction with the video card. Connect the external monitor and start the machine, if everything works properly, then the video card is good and you have a driver glitch. If it does the same black screen, then the video card has failed and will need replaced. For a driver glitch, uninstall the video drivers from the device manager then reboot. The machine will find the video card and reinstall the drivers automatically. If this is a driver glitch, this will fix the problem, and you should have your screen back.
Posted on Aug 26, 2008
  • 282 Answers
It could be a problem with the video card video driver,tried going to safe mode,reboot your pc and press F8.Go to safe mode with networking.
  • clark styx valencia
    clark styx valencia Aug 26, 2008
    when youre on safe mode,video driver will stop loading,you might need to go to safe mode with networking to download update video drivers
My hotpoint aquarius is coming up with test and will not start when I have gone to use it it came up with the time and temperature but then it just said test and will not move on
hello try this Someone has accidentally pressed some buttons and locked you into test mode.
To get out of it you need to press start, the display should go daft. Press start again and the display should settle down. Now press the on/off button and the start button at the same time and hold them down for a few seconds until the display shows d-end or d-off.
Your machine should now work. hope it helps
regards
shaun
Jan 08, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
My washer is digital, and at the moment every time i press start it says test can u help me
hello, Someone has accidentally pressed some buttons and locked you into test mode.
regards
shaun
Jan 03, 2011 | Hotpoint Aquarius WD640 Front Load...
My hotpoint washing machine wt741 will do nothing except fast spin, LED display is flashing TEST, it will not stop doing this unless i switch if off, what can i do?
Unplug your appliance before working on it
Thank You
Sep 12, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Washing machine stuck in test mode hotpoint wf865
Your machine should now work. hope this helps.
Nov 22, 2009 | Hotpoint Ultima WF865 Front Load Washer
Testing Shows On Display
press and hold start/cancel button for 5 secs. Thenpress on /offbutton and start/cancel together until Doff is displayed the machine should now be ok
Nov 26, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Error Message
I called the Hotpoint helpline and the solution to this problem was simple:
I had to press and hold the start/cancel button until all the lights on the display flashed
then I had to press and hold the start/cancel button along with the on/off button together at the same time, until the word "dOFF" was displayed... the msachine then functioned as normal.
Easy when you know how!
Aug 30, 2008 | Washing Machines
My washing machine is showing test
To Deactivate
Press the Start/Cancel button until all the console LED's illuminate.
Press both Start/Cancel and On/Off buttons together until
d OFF appears.
The default screen returns and you can select a new programme.
Note:- The default screen information displayed on these models is that of the programme currently selected by the selector knob.
Jun 02, 2008 | Hotpoint Ultima WF860 Front Load Washer
Shows "LE" in display.
Machine has a bad motor or "stator" on this machine. It is a direct drive winding on the back of the machine. Remove the back panel, the one bolt removes the rotor then you will see the stator winding, replace it and your good to go.
May 11, 2008 | Washing Machines
Hotpoint wf865 problem
Try the following, may work:
  1. Press the Start/Cancel button together until all the console Led's illuminate
  2. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  3. Default screen should return and you can select a new programme
Pl rate me nice if this solution helped!
Mar 22, 2008 | Hotpoint Ultima WF865 Front Load Washer
"LE" error means the motor has overloaded. There is no way to fix this yourself. You will probably need a new motor. Call for an engineer.
Jan 20, 2008 | LG WM-1480FHD Front Load Washer
Toshiba Tecra 9100 Notebook Logo
122 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
