I have a Maytag Epic-Z washer. On the last few minutes of the cycle the washer stops and gives and F-28 error code. The manual states that F-19 thru F-31 are electrical errors. Is there something I can check before waiting 2 weeks for Maytag to send someone? Thanks
-   I just purchased my Epic Z and it's giving me the F 28 error code, I called Maytag and they did schedule me for someone from A & E Factory to come out to my home. The door won't unlock, it does absolutely nothing!!
I just looked it up on another website, it's an electrical problem. I just bought it, have not used it once. It's extremely heavy and we did have to bring it up a flight of stairs or else I would take it back to Lowe's! Hopefully it will be an easy fix, with three men in the house, we will be up to our necks in dirty clothes in no time!!-   tsousa1967
Sep 08, 2008
-   My washer shows the error code F-28. The front door will not open, the washer will do nothing at all. Tried unplunning for up to an hour. Did not help. Help
-   Guest
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
Try unplugging the machine for 3 minutes and then rebooting it! If the problem continues! Service is the only possibility If your in the states try A&E Factory service the 800 number is below! They are usually quick!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business! they answer 24/7
Not expensive!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
F28 is a misc error,
most of the time it is because the washer is NOT LEVEL.
1. Unplug waher,
2. Relevel washer. (make sure all legs are equally distributing weight, so as to ensure no shaking). See owner's manual.
3. Plug in, and use.
Hope this helps.
Jay
Was this helpful?
Yes
No
Popular Solutions for Maytag Neptune Front Loading
I have the maytag neptune stackable washer, dryer, it does not spin, I have had 3 people look at it....
(More)
I have the maytag neptune stackable washer, dryer, it does not spin, I have had 3 people look at it. None can figure it out. Please Help. The wash runs up to the spin cycle then just stops.
Maytag model MAH3000 won't shut off after final rinse. Trouble shooting document in washer control...
(More)
Maytag model MAH3000 won't shut off after final rinse. Trouble shooting document in washer control panel says ''End of cycle signal ON/OFF'' Machine control connector/wire = P5 (WH11) & P2 / 1 (PU21) 24VDc ON O Vdc OFF; Timer Contract = Not Involved. Does this mean the board is bad because the Timer is not involved?
The unit keeps filling until water leaks from the door. Unless we hit the stop button the machine...
(More)
The unit keeps filling until water leaks from the door. Unless we hit the stop button the machine seems to be willing to keep filling, even while it is in 'drain' mode.
