Question about Hotpoint Ultima WF860 Front Load Washer
Error code F08
Cleaned the filter as I have done before but this time F08 is being displayed.
Can you tell me what this means?
  • Anonymous Mar 25, 2014
    has error code f08
  • 639 Answers
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
It means you should try to unplug the machine for three minutes and then plug it back in and restart it! If this fails you will need to call service for error codes!!
Sounds like you need both knob and screw!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business! they answer 24/7
Not expensive!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 26, 2008
F08 error code
F08 error code: Door open when program started
May 01, 2015 | Bosch Washing Machines
Whirlpool f08
whirlpool f08
f08 e03 error codeF8E2 is DISPENSER SYSTEM ERROR - Dispenser motor is unable to reach the desired position. Possible causes: Check the mechanical linkage from the dispensor motor to top of dispenser. See TEST #12 (Dispensor Distribution System) on page 21. Someone else can post to contents of Page 21. Good luck.
Read more: http://forum.appliancepartspros.com/washer-repair/529426-f08-e02-error-codes.html#ixzz34yTou7Nz
Yes, it is a dispenser system error. The technician manual says to check the mechanical linkage from dispenser motor to top of dispenser.
However, in my case this page from whirlpool was helpful:
https://www.whirlpool.com/product-he...r-code/PH5260/
It says a common solution for this error (f8 e2) is:
The detergent drawer or detergent cartridge might be clogged with detergent. Clean out the detergent cartridge per Use and Care Instructions.
If cleaning the detergent cartridge did not correct the problem, please contact us.
For any additional questions, please call our Customer eXperience Center toll-free at 1-866-698-2538, Monday through Friday 8AM-8PM Eastern Standard Time.
You will be asked to provide the model and serial number which is found on the front door rim after opening the door.
So I washed out my dispenser and now it's working again.
Read more: http://forum.appliancepartspros.com/washer-repair/529426-f08-e02-error-codes.html#ixzz34yTzjNdt
May 15, 2014 | Whirlpool WFW94HEAW Duet Front Load Washer
Hi I have a hotpoint wf630 washing machine and it keeps flashing error codes f08. Could you tell me what this codes means. many thanks, Stuart
Most Hotpoint, Ariston and Indesit (who make the other two) use similar fault codes. Although I cannot confirm it on your particular machine, f08 means there is a problem with the heater/its relay/its control. Often a cure is to re-seat the cables/wiring to and from these items.
REMOVE POWER BEFORE ATTEMPTING ANYTHING OF COURSE.
Good luck,
John C
Mar 09, 2011 | Washing Machines
Displaying IE fault code
This is an inlet error. Shut the water valves off and remove the hoses one at a time. Shine a flashlite in to where the hose screws into the machine. Check the filter screens in there for any type of debris. Yiu can remove these filter screens with needle nose pliers. Once they are cleaned and re-installed, try it again. If is still showing an error, you have a connection/valve/or control problem.
Jan 13, 2010 | LG WD-1045FH Front Load Washer
Screen display reads f-08
  1. Error code F08 indicates heater relay stuck
  2. Check pressure switch connections
  3. Check heater connections
  4. Check module connections.
  5. Check pump and or pump filter for blockage.
Please rate ,my solution.
Thanks.
Nov 15, 2009 | Hotpoint Ultima WF860 Front Load Washer
F-08 is on the display
Error code F08 indicates heater relay stuck.
  1. Check pressure switch connections.
  2. Check heater connections.
  3. Check module connections.
  4. Check and clean pump and or pump filter.
Please rate my solution.
Thanks.
Nov 15, 2009 | Ariston Technologies AW125NA 13 lbs. Load...
Hotpoint Ultima WF860 Front Load Washer Logo
980 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
