Question about Olympus Camedia C-740 Ultra Zoom Digital Camera
Focus Problem
My C-740 has a new problem. The auto focus takes 2-3 seconds to lock before the shutter snaps. By that time, I've lost the shot. It happens whether I'm using Auto, Portrait or Action modes. I'm wondering whether I set soemthing wrong or if the camera is malfunctioning. Any help would be apppreciated.
    Master:
  • 852 Answers
Low light focus lock can be a problem with this camera. But in normal or bright light there should be no problem with auto focus lock. If this is a new problem, you should check to see if a setting has been changed. With so many options, it is easy to accidently set something that causes unusual results (been there, done that). First ... Go to the Setup Menu and see that the "All Reset" option is selected. This will cause everything to be reset to factory default each time you power-on the camera. Turn the camera off and then turn the camera on. Then take some test photos to see if your auto-focus-lock is improved. If that works, there is no need to check the items below. If that does not work, here are some control changes to try. Remember if you turn off the camera everything gets reset. That camera uses contrast detection for auto focus and it is normally set to "Multi-Area Auto Focus". Try changing it to "Spot Auto Focus" and do some tests, including with the camera set to one of the programs or manual mode. There is another setting called "Autofocus Area", you should investigate. Check your manual to determine what you can do with this control. There is another control called something like "continuous auto focus". Check the manual for further information. If none of the above help, it is time to see about some camera repairs.
Posted on Sep 06, 2005
Olympus SP800UZ Digital Camera takes a long time to focus and take shot
Could be the settings need adjusting.....to help you should check these settings and set to!
ISO to High ISO Auto.
AF to Auto
When taking the photo press the shutter button halfway till the window shows a green light (if the window red then not focused so release button and try again) then continue to press the shutter button till the picture is taken!
let me know how you get on!
Oct 19, 2014 | Cameras
When I press the clicker ( button to take the shot ) it takes like 1 second before the shot is captured, is there a way to speed it up ? I take a lot of pics of bands playing, and I'm all ready &...
You say in your description that you're "focused in". That means that you've pressed the shutter button half-way and allowed the camera to lock in the focus (it will beep). You need to maintain that half-press until the moment you want to snap the picture and then press the rest of the way. That will give you a faster, "instant" picture. Is that what you do?
May 16, 2011 | Cameras
2 problems. I have the Coolpix L100. Sometimes my photos are blurry and also. there is a delay when I snap a photo which isnt good when trying to get action photos.
With autofocus digital cameras, blurred photos are almost always a result of camera shake. You need to hold the camera still even after pressing the button, as there is often a short delay before the shutter fires.
Many digital cameras have a two-stage shutter press- first pressure causes the camera to focus, then the follow through pressure takes the picture. If you are rushing this, you may get unfocussed shots.
If you take lots of action pictures, you will have to work on a technique of partially pressing the shutter to get focus in anticipation of the shot (perhaps focussing on where the action will occur), then holding it part-pressed until the moment you want to capture. This is really no more of a problem than setting an anticipatory focus on a manual focussing film camera use to be. Some more complex digital cameras will allow you to turn off auto focus and focus manually.
Nov 05, 2010 | Nikon COOLPIX L100 Digital Camera
When I push the shutter button down, it takes 3 to 4 seconds before the shutter opens to snap the picture. What's with that ?
You need to press the shutter button half-way and allow the camera to lock in the focus before pressing the rest of the way.
Dec 14, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Nikon D90 Self-Timer does not work when flash is engaged.
The answer to your question can be found at...
This website
All but the very best flashes can not recycle atthat flash rate. For burst mode, you probably want to use focus modeAF-C or AF-A.
Morris
Page 73 in the manual; If the flash fires in L or H mode (pg. 65), only one picture will be taken each time the
shutter-release button is pressed. The shutterrelease may be briefly disabled to protect the flash after it has beenused for several consecutive shots. The flash can be used again after ashort pause.
The flash can take several seconds to recharge andduring that time the shutter is disabled. NR will also reduce thenumber of frames per second that you can take, and of course yourshutter speed has to be fast enough to allow for 4.5 fps.
In AF-S the shutter won’t fire unless the camera has achieved an in-focus state and the focus is locked.
In AF-C the camera continually focuses, but that isnot the same thing as being in focus. As you move the camera or yoursubject moves, the in focus state will come and go, but the camera willattempt to continuously re-focus. BUT, the shutter will fire even ifwhen the AF system has lost the in-focus state and the picture is outof focus.
In the D90 manual it indicates that the AF-A modewill only fire when the green in-focus light is on, just like in AF-S.The problem is that you probably won’t get 4.5 fps unless both thecamera and the subject are stationary and no time is lost between shotswhile the camera re-focuses.
Brooks
http://bmiddleton.smugmug.com/
Mar 06, 2009 | Nikon D90 Digital Camera with 18-105mm...
Auto focus does not work in the creative zone
Sounds like your custom functions have been changed to work this way. On the EOS 350 D it is Custom Function #04. To change it back to default you need navigate through Canon's menus. Here's how to get there: while in one of the creative zones go to your camera menu and navigate to the 5th tab on the right. Select “Custom Functions (C. Fn)” from this tab. This will open a submenu of numbered options. Select #04 and set it to 0: the default AF/AE lock on a half depress of the shutter. That should get your camera back to the expected auto focus with the shutter button.
Happy shooting :-)
Feb 06, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Shutter Speed
Two things to try, 1) The release button is a two stage process. Pushing the release button 1/2 way allows the camera to focus on the subject. It needs a few milli-seconds to do this. A full depress releases the shutter, but it you don't allow the camera to focus, things get messed up.
2) Holding a camera of this type with outstretched arms is a sure way to get poor shots. I use my Fuji S5000 with the viewfinder rather than the LCD display for framing shots just like I was using an SLR/DSLR
Mar 01, 2008 | DXG Technology DXG-608 Digital Camera
3100Z Focus Problems
re you sure the out of focus condition is due to the actually focus or do to motion blur? I think the 3100Z in auto and flash on will set the shutter speed fairly low like 1/30th of a second for wide angle and 1/90th for full telephoto. This may not be fast enough to avoid motion blur. I would suggest using manual mode and shutter priority and set the shutter speed to 1/100th of a second. This won't effect the flash output but will reduce the amount of ambient light being captured which could cause long range shots to become darker in the distance. Name of the game, don't be afraid to take it off auto mode and experiment with manual setting.
Sep 13, 2005 | Epson PhotoPC 3100Z Digital Camera
Auto Focus Problem
Way to check settings is to take the batteries out for a while, it should revert to factory default settings. I tell a lot of People to try this, it works an amazing number of times. Auto focus looks for vertical lines, what are You shooting at? Try rotating the camera 90 degrees, if it locks better,Bingo. Subjects without much contrast are hard to lock focus on
Sep 12, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
Shutterlag S70?
I have the S70 now.. and it's a long shutterlag, that is correct.. but i've taken photos all the day now and it's not a big problem, you get used to it right away.. I can recommend this camera very much! It's just fabulous! I had the Fuji MX-700 and Canon S10 before and this one is soo much better in all aspects.. And the manual focus, aperture/shutter controls are VERY easy to use.. but it's only a few preset focuses to choose from. The camera was bigger than i thought but the quality of most pictures i've taken are just amazing. One thing i miss from the Canon is the infra-red focus assist.. the night shots are very amazing! well.. ask whatever you want to know and i'll tell you ;-)
Sep 11, 2005 | Sony Cyber-Shot DSC-S70 Digital Camera
Olympus Camedia C-740 Ultra Zoom Digital Camera Logo
135 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
