Question about Maytag Dryers
Loud sort of grinding noise while drying stops then restarts again maytag front loading mdg308daww need help as to how to get panels off to access drum and motor
  • 550 Answers
Unplug dryer
front panel screws are mounted in the bend at the bottom of the panel, hidden from easy view by the bend.
  • may be torx secure screws, either cut a slot in the screw head and use a flat screwdriver, or buy a torx secure #2 bit at the local alltools
swing front panel up and forward, unplug door switch wires, set panel aside,
examine roller bearings,
drum felts,
belt tensioner
for wear
takes longer to type than to open the dryer
good luck
Posted on Aug 27, 2008
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
My LG Front-load dryer is making a loud noise during the drying cycle. If i press on the lower left front panel - the noise is muffled quite a bit. Model # DLE5977
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
gfg
Sep 27, 2010 | LG DLE5977 Electric Dryer
My maytag dryer was making a loud screeching noise and then stopped spinning or heating
heatman101
dgsghs
Feb 10, 2010 | Maytag LSG7806A Front Load Stacked Washer...
MAKING SQUEALING NOISE
heatman101
fgsj
Oct 19, 2009 | Whirlpool GGW9250PL Gas Dryer
When it fills with water and begains the wash cycle it makes loud grinding noise and dose not rotate properly
you might have something in the pump. you will need to remove the bottom panel, to do this you will need a putty knife. place the putty knife between the front panel and top panel. place it just inside the coners about 3 inches. press the tabs and the top will lift off. you will then need a 5/16ths nut driver to remove the 2 screws just inside the lip. then the front panel will fall forward from the top. you will then have access to the inside of the unit. put the unit in a wash cycle and watch and listen to where the noise is comming from. you will then know what could be wrong with your unit. Let me know if you have other questoins.
Oct 16, 2009 | Maytag PAV2300 Top Load Washer
Maytag Neptune Dryer makes loud noise while drying.
heatman101
ergfgfjk
Sep 06, 2009 | LG DLE2514 Electric Dryer
Maytag Dryer clunking noise
Sounds like you need a blower wheel.you will need to remove the front panel and the houseing under the front panel.It is located on the bottom front laft side. if you need help on assembly or disassembly let me know hope i fixya :)
May 20, 2009 | Dryers
Maytag Neptune FAV6800AW Top Loading Washer Noise
Hello gwatson01,
Wondering if you could rate my clarification request as a solution? I joined this forum as a owner DIY’er to help other owners. The machine is just too expensive to junk and as you found fairly easy to work on. As a forum member as you I receive no compensation for my support to other owners. Thank you in advance for your support. Rich
My solution;
I’m an owner/DIY’er of the machine. Please take a look at this post and see if your mechanical noise may be coming from underneath the tumblers, maybe some coins grinding around under the tumblers. If you think it is take a look at the service manual link in that post. It will take you thru the tumbler removal process, see if you feel comfortable with the process, the manual does not call out a #20 Torx driver is required to remove the tumbler.
If you think the grinding noise is very metallic and not muffled by a tub of water the grinding noise may be coming from the transmission/clutch area and removing the machine front vertical cover will be necessary to better sound isolate the suspect area of the machine. Do you feel OK to remove the front panel? If so see this post.
The 1st link I sent you to shows that this owner had issues after the coin removal. I would also like you try a Spin Only cycle with no clothes in the wash basket. Can you let me know if that cycle runs with no noise? We can’t totally rule out an issue with the clutch/transmission components with the info supplied so far. To help you remotely diagnose this issue detail information is needed. Let’s try to sound isolate the grinding noise source location. Follow all safety rules in the Service Manual. If you don’t feel comfortable to proceed I would recommend you call in a qualified FAV6800AWW repair service for support.
Apr 03, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag atlantis washer making loud grinding noise
The belt are tear and slap to the near obtacle need to replace /
The water magnetic valve are leaking ned to replace /the coil open or valve rusted.
Jan 09, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Loud noise -- water pump??
Yes you definately need a new pump assembly part number 21001906 $59.95. That is a maytag part number and it is a very common repair. The new pump is a revised design and will look different but will mount the same. Axcess through front panel.
Nov 25, 2007 | Maytag MAV7200 Top Load Washer
Dryers Logo
109 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
