Most likely the Hinge screws have become loose and the feeder is out of alignment. Make a copy on the platen glass, if it comes out straight then it is definitely a misaligned feeder. Hope this helps.
If your device cames with PS, yes you can.
With MacOs You need Post Script to print with any printer. I know that the latest versions of Mac already print with PCL. I can not tell you if your version is the latest. Although you can take a look on this web site http://gimp-print.sourceforge.net/MacOSX.php.
See you!
In your machine (model) you have to enter in SP mode to reset your error code.
Try this:
Yellow key.
1-0-7 on the key pad
Red key at least 3 sec.
Press "copy sp"
On the key pad press 5 810 and #.
Press execute
Exit all the way out.
Turn the machine off and on.
yes... either the network cable got unplugged from teh copier or you have an ip conflict... here is how to tell... if you have an ip confilict... unplug the network cable from your pc... print a network status page or go into the print driver and pull the ip address from it and then, on your pc, press start, accessories, command prompt and then type ping and type in copier's ip address then press enter... it should look like this ping 192.168.168.168 if you don't get four time outs... then you have an ip conflict and you need to change the ip address of the copier to one thats not in your ip range... generally thats a low ip address...something that ends in a number less than 100
Make sure that the phone cord is plugged into "line" and not "phone" You can also check by pressing "on hook" button to see if you get a dial tone. Also, Call the fax number to see if the machine is trying to receive.....you should get high pitched, varying tones (hand shake is what they call it) this will let you know if the fax part is talking to phone line.
