Question about Microsoft Xbox 360 Controller
Controller wont power up.
Tried everything other pack from controller #2 , the bending of the wire on pack, new batterys everything.
  • 3 Answers
Yeah you have the same problem as me...its probably bad batteries that may have leaked...you should buy a new controller...thats what im going to do :(
Posted on Sep 10, 2008
Ho w to fix x box from controller to x box is really slow how to make it normal
Learn how to connect a wireless or wired controller to your Xbox 360 console.
Connect a wireless Xbox controller
  1. Turn on your console.
  2. Press and hold the Guide button on the controller until the controller turns on.
  1. Press and release the connect button on the console.
Xbox 360 E console fbbfb609-f7ed-4e6e-bd35-7543b1c20d61.png?n=xbox360-connect-m-s.png Xbox 360 S console Original Xbox 360 console 342c6e70-9e56-43d8-bb3a-05f5411040bd.png?v=1#xbox360s-connect-m-m.png 170df81e-0a79-49be-8236-a0fb68eec37b.png?v=1#xbox360-connect-m-m.png
  1. Within 20 seconds, press and release the connect button on the controller.
  1. When the lights surrounding the power button on the console stop flashing, the controller is connected.
On the Xbox 360 S console, each connected controller is assigned to one of four positions. Each position corresponds to a lighted section around the console power button and the controller Guide button. On the 360 E console, a solid green light on the front of the console indicates that the controller is connected. To determine the player position associated with your accessory, look at the ring of light that surrounds the Guide button on the controller.
c9341988-8ed5-4217-9b87-353de50efbec.png?v=1#connect-xbox-controller-m-m.png 5e4ab6ab-8cb0-41e6-a037-b88221a430c7.png?n=connect-xbox-controller-360-m-s.png
71add0b7-ddf2-4439-b4b4-f50f156d92b7.png?v=1#controller-batteries-m-m.png If the controller does not turn on, check the batteries. Insert fresh AA batteries, making sure they are correctly positioned in the battery case.
You can also use the Xbox 360 Play & Charge Kit or the Xbox 360 Quick Charge Kit to power the controller. Learn more about Xbox controllers and chargers.
To connect additional controllers, follow these same steps again. You can connect up to four controllers to the console. Each connected controller is assigned a position that corresponds with the lighted sections that appear around the console's power button and around the Guide button located in the middle of each controller.
  • To disconnect a wireless controller, press and hold the Guide button for three seconds, and then choose to turn the controller off.
  • When you turn off the console, the controller will reconnect the next time you turn on the console.
  • The controller can be connected to only one console at a time. You can connect the controller to a different console, but the connection to the previously connected console will be lost.
Connect a wired Xbox controller
5fb17f50-7448-45d5-a294-9ea90994f55b.png?v=1#controller-wired-m-m.png Plug the Xbox 360 Wired Controller into a USB port on the Xbox 360 console. There are two USB ports on the front of the console. To disconnect the controller, pull on the connector, not the cable.
cbe46bf0-3a46-4d53-9d8c-6697aa57622a.png?v=1#controller-cable-release-m-m.png The cable on the Xbox 360 Wired Controller has an inline release. The inline release on the controller cable is a safety feature designed to reduce the chance of the Xbox 360 console falling if the cable is pulled.
Wireless controller troubleshooting
If your wireless controller disconnects or cannot connect to your console, see Xbox 360 Wireless Controller disconnects or can't connect.
If your wireless controller does not turn on or loses power, try the following solutions:
Solution 1: Replace the batteries
Insert a new set of AA alkaline batteries into the Xbox 360 Wireless Controller, and then try to turn it on.
Solution 2: Try a different battery pack
If you have another Xbox 360 Wireless Controller, take the battery pack off that controller and attach it to your controller. Then try to turn your controller on.
If your controller works with the different battery pack, your original battery pack might be defective. If your controller is under warranty, you can order a replacement battery pack from Xbox Support . See the Assistance section at the bottom of this page for more information.
If your controller is out of warranty, you can buy a new battery pack from a retail store.
Solution 3: Try a rechargeable battery packIf you or a friend has an Xbox 360 Rechargeable Battery Pack, attach that battery pack to your controller and try to use your controller. If your controller works with the rechargeable battery pack attached, you can buy a new battery pack from a retail store or order a replacement battery pack from Xbox Support. See the Assistance section at the bottom of this page for more information.
Feb 08, 2013 | Microsoft Xbox 360 Controller
Controller wont come on and i have brand new batteries it wont sink the light wont even come on
I had a similar problem, I'm not sure if its the same thing, mine was caused by a faulty connection in the back of the battery pack (the silver square in the middle.)
Try with a different battery case, or a pack from a play and charge kit (if you have them), this will determine if it is the battery pack or the controller, if it isn't the battery pack, you could try a repair shop/guide for steps on the controller, sorry I cant be of more help.
Feb 02, 2011 | Microsoft Xbox 360 Console
Wont turn on with new batteries in it and battery pack from my other controller
this is a common problem. this does the same thing with my controller too. its not the answer you'll like, but you will probably have to buy a new controller. this is as a result of the pack coming loose. the coils that hold the batteries in place sometimes bend, this causes the batteries to move. that is why the controller keeps disconnecting. i would recommend switching to a wired controller :( sorry
Mar 20, 2010 | Microsoft Xbox 360 Controller
Xbox controler wont work
if controller does not sync might be a few problems i have noticed on newer 360 controllers they dont work with generic battery packs try a microsoft brand
Dec 27, 2009 | Microsoft Xbox 360 Elite Console
Neither of my xBox 360 wireless controllers will sync with my 360 console. I have tried both contollers with a variaty of battery packs and they still wont sync but i have no problem with my wired...
Remove the batteries from both controllers, and unplug the Xbox for a minute. Now turn the Xbox on by the power button on the console, Install the batteries in your controllers, and hit the Console sync button first, then hit the little sync button on top of the controller.
If this does not work, you can purchase the wired charge pack that you must plug in to the USB port of the console to charge, and this will sync as your wired controller does. When it is synced unplug the wire from the controller and voila. Remember, the charger pack will look like this.
http://www.techsick.com/shop/images/P/xb360-controller-charger-36.jpg
Good luck and be patient.
Dec 19, 2009 | Microsoft Xbox 360 Controller
My Xbox 360 wont sync any of my wireless controllers and the powe
if your wireless controllers wont sync to your xbox, it could be one of 2 things.
assuming your batteries are fully charged, and that you're using a certified xbox controller, it could be that the controller itself. it is really rare that the wireless receiver inside the xbox itself, goes out, but soemtimes, it happens.
the easiest thing or you to do would be to either pick up an after market controller, or another certified controller, and see if they'll work. if you try other controllers, and they STILL dont work, verify that your system settings are correct, or are set to default, and make sure that your xbox isnt sitting close to something that could be interfering with the signal....like a wireless router for example
if this doesnt work, then it's a problem with the xbox, and you should send it back to the service repair center.
Sep 24, 2009 | Microsoft Xbox 360 Wireless Controller
Xbox 360 wirless controller
try lookin at the little tut on how to bend the little prongs up on your battery pack...if not...(like me) buy a new controller :(
Aug 02, 2008 | Microsoft Xbox 360 Controller
Amilo Pro V2055 power problem
the motherboard is damaged from the bend input you will need a new motherboard.
Apr 18, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
Xbox 360 controller will not turn on
If you're using the AA battery pack, try this.
Use a small screwdriver or other such tool to pry up the metal spring on the back of the battery pack as seen here:
This will give you access to the two small metal prongs underneath. Pry these up as well, as far as you can (see below).
Finally, push the metal spring back down just enough so that a little bump of it appears above the battery pack, like so.
Now power it up and test it out!
Mar 17, 2008 | Microsoft Xbox 360 Controller
Microsoft Xbox 360 Controller Logo
210 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
