Question about Panasonic Lumix DMC-FZ10 Digital Camera
Minimum focal distance
What is the minimum focal distance of the FZ10 at full 12X zoom?
    Master:
  • 903 Answers
"The macro mode on the FZ10 allows you to get as close to your subject as 5 cm / 0.16 ft at wide-angle, and 2 m / 6.6 ft at telephoto"
Posted on Sep 06, 2005
SOURCE:
I have a konica minolta model 2806-301 and i need an instruction manual for it can you help me?
Really, you are talking about Konica Minolta Dimage Z6 6MP Digital Camera with 12x Anti-Shake Zoom:
MPN: 2806-301
Model: 2806-301
Optical Zoom: 12
Digital Zoom: 4
Maximum Aperture: 2.8
Maximum Focal Length: 69.9
Minimum Focal Length: 5.83
Maximum Resolution: 6
Maximum Vertical Resolution: 2112
In this link coudl find your User Guide: Konica Minolta DiMAGE Z6 (down page, enter verification code to download user manual).
Hope helps (for free, remember to rate this answer).
May 16, 2011 | Konica Minolta Cameras
What does 35-88mm mean in feet? This is a telephoto lens on a Nikon F50 SLR. Thank you. Amadeus
35mm is about 0.115 feet (a bit under an inch and a half). 88mm is about .289 feet (a bit under three and a half inches). They refer to the minimum and maximum focal lengths of the zoom lens. They have nothing to do with the distance from the camera to the subject.
The focal length of a lens is a measure of an optical quantity. It may or may not have anything to do with the physical length of the lens.
Jan 10, 2011 | Canon 35-70mm f/3.5-4.5 FD Lens
I am trying to take pictures of pennies and I can't get the camera to focus and get a clear picture. Do you have any ideas?
All cameras have a minimum focal length. That is the minimum distance they have to be from an object in order to focus clearly. If you have a digital camera with changeable lenses, that minimum focal length is determined by the lens and how it is constructed. If you have a fixed lens digital camera then the manual should tell you what the minimum focal length is.
One other thing to keep in mind is that on most fixed lens digital cameras, there is what is called a macro setting. If you switch to macro mode, it will allow you to get closer to the object and still get a good focus. Your manual should tell you how to turn on that mode.
Dec 31, 2008 | Cameras
What is the distance at Macro mode?
In wide-angle macro mode, the minimum focus range is as close as 30cm from CCD (21cm from the lens front.) At this point, the magnification is 0.03x (equivalent to 0.12x in 35mm format).(Focal length is 7.2mm. At maximum magnification 283mm x 213mm of the subject can be captured.) In telephoto macro mode, the minimum focus range is 25cm from CCD (13 cm from the lens front) and the magnification is 0.18x (equivalent to 0.7x in 35mm format). (Focal length is 42.7mm to 50.8mm. At maximum magnification 52mm x 39mm of the subject can be captured.)
Sep 15, 2005 | Konica Minolta DiMAGE A200 Digital Camera
In wide-angle macro mode, the minimum focus range is as close as 30cm from CCD(21cm from the lens front.) At this point, the magnification is 0.03x (equivalent to 0.12x in 35mm format). (Focal length is7.2mm. At maximum magnification 283mmx213mm of the subject can be captured.) In telephoto macro mode, the minimum focus range is 25cm from CCD(13cm from the lens front )and the magnification is 0.177x (equivalent to 0.7x in 35mm format). (Focal length is42.7mm to 50.8mm. At maximum magnification 50mmx37mm of the subject can be captured.)
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
If you zoom to less than 12x
The macro setting on the fz series allows you to get within a couple of centimeters of the subject and obtain focus. That is pretty close. That is too close. The camera will throw a shadow. You need some room. Most high zoom cameras (notably Olympus) have macro capabilty throughout the zoom which not only increases the magnification but also allows you (requires you) to put some distance between the lens and the subject. The panasonic fz series is different. They do not have macroability at zooms greater than 2x-3x. Beyond that there is no increase in magnification. Why? I dont know. Maybe this feature was designed on a Monday. Fortunately this can all be rectified with the use of a closeup lens. Now the fz series will react like most other high zoom cameras and do it well. The Olympus b-macro is such a lens. There are many others
Sep 06, 2005 | Panasonic Lumix DMC-FZ10 Digital Camera
Sorry you're having such a problem with the fz1 w/b-macro. Here is a shot of the stock fz1 w/b-macro at full 12x zoom - resized only. Try practicing on still objects such as coins or jewlery. If you are beyond 10-12 inches you are probably too far away.
Sep 06, 2005 | Panasonic Lumix DMC-FZ1 Digital Camera
Minimum focusing distance In the Super Macro mode
In super macro mode, pictures can be taken as close as 2 inches. Subjects measuring up to approximately 1.9 inches by 1.4 inches can be captured on the monitor.
Sep 04, 2005 | Olympus Camedia C-8080 Wide Zoom Digital...
The minimum focusing distance
Shooting can be performed at a minimum focusing distance of 3cm. An approximate 2.1 cm x 2.8 cm subject can be captured on the monitor.
Sep 04, 2005 | Olympus Camedia C-5060 Wide Zoom Digital...
Focusing distance in macro mode
Using the Macro mode, it is possible to zoom through all ranges from telephoto to wide down to a minimum distance of 7.9 inches.
Sep 01, 2005 | Olympus Camedia D-550 Zoom Digital Camera
Panasonic Lumix DMC-FZ10 Digital Camera Logo
60 people viewed this question
Top Panasonic Cameras Experts
rajiv6089
Level 1 Expert
AJMAL KHAN
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
