Question about Epson Stylus CX6000 All-In-One InkJet Printer
Printer gave a loud noise & stopped scanning & printing
Printer gave a loud nois & stopped scanning & printing
  • Anonymous Sep 06, 2008
    Mijn EPSON STYLUS PHOTO RX520 gaf na het verwisselen van een
    nieuwe inktcartride een hoop lawaai en stopte met de foutmelding
    E90 met het tekentje 3 radertjes
Error e-91
Posted on Sep 05, 2008
The scan head moves when I start the printer, but then stops after making a loud noise, and the window reads, Printer error.
If visible check the print head track for some kind of blockage. Please include your model # and brand name next time.
Mar 18, 2015 | Office Equipment & Supplies
Hp 2200dtn prints fine but makes loud friction noise
Old age printer, Remove right,left, back & top doors. check fuser assm screws tighten or slacked? if its slacked use more lengthy screws for tighten the fuser.Apply grease for the gears to avoid the friction. Open main motor assembly clean entire gears, lubricate & fix it back..Check any gears are warn out, replace it if possible...Best of luck..
Jan 04, 2012 | HP LaserJet 2200dtn Printer
Hey dude,
First check with the interface cable from system to printer.If when the printout is given it starts making noise,then the communication is ok.Now check with the Print driver ,try to uninstall and reinstall it.i assure it'll help so.
With hope,
Mar 06, 2011 | HP LaserJet 1000 Printer
My printer makes a loud rumbling sound when i
You will see ther is two black levers in the inside left and right the side were the nois come form is broken if you remove the cover you will see that there is a spring inside and a pease of plastic. you need to replace that part.
Mar 04, 2010 | Samsung SCX-4216F All-In-One Laser Printer
Lexmark C510 is making grinding noises while printing large jobs
I found another posting stating that the culprit was the black toner cartridge. Sure enough I changed our black cartridge and the grinding noise has stopped. No wonder the grinding noise was not happening all the time only when the black cartridge got low. Thanks for the help!
Oct 15, 2009 | Lexmark C510 Laser Printer
Loud ratchet noise
Have you been using ink cartridges other than store bought? Reason I'm asking is that i used a refill kit, and tried those half price refill places, only to find ink was leaking out when not in use & clogged up the ends where the cartridge moves across. take a flashlight & look at the ends of the track that the cartridges slide across on, you may see a build up of ink, that won't allow the cartridge to travel as far as it needs to go to run properly.
Nov 06, 2008 | HP LaserJet 3330 All-In-One Printer
Trouble scanning or faxing
yeppers..that's the mechanism under the glass..sounds like either it's stuck or the belt is going bad..service level issue, I'm afraid.
Aug 20, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Is my printer broken?
there may be some paper jammed inside..but otherwise you may find that you will need to print a shorter run. turn it off, let it cool down(can be thermally related) the paper unusually thick, by chance?
Feb 19, 2008 | HP DeskJet 895cse InkJet Printer
Loud grinding noice before starting to print
Mine makes a grinding noise when scanning or making copies. As long as everything is working, I just tolerate the noise in which the rest of the staff find amusing at first and then ignore it as I do.
Jan 25, 2008 | HP PSC 1210 All-In-One InkJet Printer
Epson Stylus  CX6000 All-In-One InkJet Printer Logo
236 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
