Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
Auto program message
The television has worked well for more than 3 years. Suddenly there is a dark square message box covering the middle of the screen about initial set up and auto programing of channels (CH+ auto; CH- exit). If I do the necessary steps to auto program the channels, it has no effect, and the box remains. If I try to use the CH+ or CH-, nothing happens. Any suggestions as to removing the message box?
Welcomejee said the problem is a result of dry solder on the 80 pins IC mounted at the rear side of the main board. It can be resoldered.
Posted on Aug 27, 2008
How do i get rid of the square message that appears in the middle of screen?
It sounds that, closed caption function to your TV is ON. Press the 'CC' button on the remote control once to make it OFF.
Aug 27, 2012 | Sony KV-36FS100 36" TV
HOW DO I GET RID OF THE SQUARE MESSAGE BOX?
Press the "CC" button on the remote control once.
My Sony Bravia tv has a problem with the screen getting dark on the right side. Sometimes the screen is normal, and then sometimes it goes dark and/or red. There is a small square (2 inches) that has a...
This tv have a problems with a board that call T-CON decodering board.This T-CON decodering board sit at the bottom in the middle of the LCD screen panel.This T-CON decodering board,decodering the tv incomming broadcasting tv signal before it go into the tv LCD screen panel to produce pictures.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decodering board for the replacement.
Apr 23, 2011 | Televison & Video
When the screen is dark there are lines that run back and forth across the screen which is only noticable when pitcure is dark immage.
the screen bias needs to be turned down-ehind the front cover which is behind the grille there is a small black square about 3 inch square 6 little knobs sticking out 3 say in small letters screen and 3 say focus, don't adjust the focus just the screen for the coresponding color that shows up when picture is dark.best way to do this is darken the room and put it on video input with no signal if lines are white slowly
adjust 1 color after the other counterclockwise untill
lines disappear if only 1 color shows then only adjust the knob with the matching color. this is a very fine adjustment, to much will make your auto focus stop working. check it after you are done
Jun 20, 2010 | Sony KP-51HW40 51" Rear Projection...
Square box in middle of t.v. black everywhere else.
Turn off the closed-captioning. If it's set for text mode, the screen will blank out an area for the text to be displayed. On channels or programs where captions aren't being used you won't see any problems, but other times you'll have the mysterious black box. Many TV remotes have a single button to control captions, so it's easy to get into text mode without knowing it.
May 03, 2009 | Broksonic TV
I get a dark square in the middle of the picture after about 1 minute of play on one channel
Press closed caption button on remote repeatedly until nothing about closed captioning come up on the screen.
Aug 25, 2008 | Sansui TDC2075 20 in. TV/VCR/DVD Combo
Dlp has dark blue areas on screen
Have you tried magic focus? if that doesn't work
replace the pcb convergence board,, It costs $96 and takes 10 minutes to replace you will have to manually line up your convergence afterward as the settings go to factory default. Everyone that owns this set has or will have to replace this part within 3 years
http://www.samsungparts.com/search/search.asp
Or Vance baldwin online
Part number bp94-00155a
Jan 22, 2008 | Samsung HCN4226W 42" Rear Projection...
Suspected Convergence Issue on Toshiba 51H83?
Needs chassis pull & convergence IC's replaced....then
Touch Focus will work again..................T.
Nov 19, 2007 | Toshiba 51H83 51" Rear Projection...
Black square in the middle of my viewing screen.
you have accendly turned on closed caption. the closed caption you have tured on is not the normal closed caption we are used to . it is called colsed caption text. either on your remote or in you manu, find the way to turn off cc & you should work ok. good luck.
Jan 10, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
109 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
