Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
The ice maker
We came home to the ice maker motor that sends the ice out the door running with both extra ice, cubes, and filter lights on. It runs and will not stop. I have pushed and held down buttons, unplugged to see if that would break the cycle, nothing has helped.
The water does not kick on to flow into ice maker you can still get water from the door
Posted on Sep 18, 2008
Ice maker water will not shout off Model WRS965CIAE it just runs till the tray overfills
Hello Andy;
My name is Peter. I am a retired field service appliance technician.
You have one of two problems.
1.) Ice maker module - Part Number 821515
http://www.ebay.com/bhp/ice-maker-module.
Fortunately, your ice maker is repairable. The module is like a little computer. It has a circuitry, a motor and a rotating gear set. The module tells the water solenoid valve when to turn on and how much water to fill the cube tray. Then it reads a sensor telling the module that the cubes are frozen. Then it turns on a heater under the cube mold. After a period the module tells the motor to turn on and harvest the ice cubes. It also has a lever arm on/off switch.
Watch the video. Remove the module from the ice maker. You may need a small flat head ***** driver to pop off the cover to get to it. Inspect the circuitry for any burn marks.
You will need to jump start the ice maker after reassembly and if you decide to just buy a new one.
1.) Insert a piece of 12 or 14 gauge jumper wire into the two holes on the face of the module marked: "T' and "H".
2.) Hold in the door light switch.
3.) After the module starts wait 5 seconds and remove the jumper, while still holding in the door light switch, until the ice maker has completer it's cycle and fills with water.
This will not solve your problem. This is how to start the icemaker - not shown in the video
Module Cost: Sears $98.56 + Tax
Ebay $25.00
2.) Ice Maker Water Solenoid Valve: Part Number W10341320.
If your ice maker is filling with water, then the solenoid is working, but the spool valve may be sticking and not closing quickly.
See general replacement video.
Solenoid Valve Cost: Sears $80.00
Search the internet for best price including used.
Go into the Sears website and put in your refrigerator model number. You will get diagrams and component part numbers.
Water Filters Lawn Garden Appliance Parts
Mar 16, 2016 | Whirlpool Refrigerators
Samsung refrig, side by side, won't eject ice. How do I turn off the left hand light to quit ice?
How to Repair a Refrigerator Ice Maker ' HomeTips
www.hometips.com/repair-fix/freezer-ice-maker.html
If your ice maker doesn't make ice, check out these expert do-it-yourself ice maker repair ... W. Branner Side by side GE fridge, stopped dispensing ice both cubed and crushed. ... But now that it's cleared the motor won't run to dispense any ice (water .... Our Samsung French door ice maker is not working & is making noise.
Jan 01, 2016 | Samsung Refrigerators
Ice maker not dropping ice
Need more info. Are there ice cubes in the storage section just behind the freezer door? You may have turned the ice-maker OFF. When your depress the ice flipper, does the motor run behind the door? The motor may be burned out or the ice cubes in the storage section are so melted together in a giant glob that the agitator cannot turn.Or, maybe someone turned OFF the water supply.
Aug 10, 2012 | Samsung RF4267HARS Stainless Steel French...
I have a whrilpool refrigerater the ice maker will not fill with water?
Bonjour,
Ice makers can clog. The water valve can stick open or closed or even not work at all. The water fill nozzle can clog with ice or food. If the unit has been moved the water line could be kinked or the water filter may be clogged. Maybe the water valve for the ice maker water line is turned off. Is there one under the sink? Inside most ice makers there is a thermostat that tells the ice maker that the water is frozen and it's time to dump the ice cubes. That starts a geared motor running to dump out the cubes. And in some cases a mold heater is turned on to help break the ice cubes loose. A lot of ice makers have a cam attached to the motor that turns with the shaft. When the ice cubes are gone the cam starts a timer to refill the ice maker with fresh water to make some more ice cubes. Most "fill" cycles of ice makers are "timed fill". The fill cycle has to start and stop to get fresh water into the ice maker. There may be another thermostat that monitors the air temperature where the ice maker is mounted. If that thermostat thinks the air is not cold enough to freeze water nothing happens. If all the steps don't happen at the right time no ice cubes are made.
Jul 11, 2012 | Refrigerators
Ice cube maker makes ice cubes ever once and a while, the condenser fan turns slowly. is this why it doesn't make ice cubes and the frezzer side is not cold enough? condenser fan going out? monogram...
Good day,
The ice maker speed of production is determined by the freezer temperature. If the freezer temperature is warmer than normal then the cycle thermostat in the ice maker will take longer to reset for the next harvest, causing low ice production.
More important, the condenser fan motor running too slowly can cause the compressor to run overheated and cause serious and expensive damage.
If in your opinion, it is running too slow, the issue should be addressed as soon as possible.
Aug 05, 2010 | GE Monogram ZISS480DRSS Stainless Steel
Fridge Freezer model KA58NP90 Ice maker problem
What is most likely your problem is the crushed ice solenoid. This solenoid, which is located next to the auger motor behind the ice bucket, is failing to actuate when you request cubed ice. Its "home" setting is crushed, and actuates to allow cubes past the crushing mechanism in the bucket. To be certain its the problem, remove the ice bucket, and tape the door light switch in the closed position. actuate the ice dispenser lever, for both cubed and crushed ice. you will see a square hole next to the rotating fork, when you select cubes, it should open. If it does open, there is something wrong with your ice bucket, perhaps the arm is broken, or the door inside bucket is off its snap in type hinge or broken altogether. If it doesnt open, replace the solenoid
Expert Refrigerator Repair Service in Chicago and Suburbs
Mar 20, 2010 | Freezers
Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Apr 17, 2009 | Refrigerators
Why doesn't my ice maker work?
You do not list model number, so this will be very generic. If you have cubes in the ice bin, and when you try to dispense them the duct door opens and the auger motor runs, check the auger in the ice bin itself. Check where the spiral auger meets the plastic part on front of the auger. Drive part likely seperated.
Nov 21, 2008 | Refrigerators
Kenmore Bottom Freezer 596.71103101 Ice maker not working right
Did you find icemaker solution? I have the same unit. Ice maker worked perfect. Then moved to new house, icemaker stopped working. One day it worked (old house), the next it stopped (new house)!
Nov 13, 2007 | Refrigerators
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
136 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
