Question about GE Microwave Ovens
I recently purchased this home, and the kitchen is equipped with GE appliances, one of which is the GE Profile Advantium 120 Microwave (Model SCA1000DBB03) (Serial No. HA0037 48K). I'm not familiar with the oven, and the former owner left no instruction booklet for operating. Please help. Thank you.
  • 1 more comment
  • unis117 Aug 26, 2008
    Hi there, I downloaded 24 pages about GE Microwaves..but this particular microwave is different, in that it is also a convection oven...that convection part is the problem...Also the controls are so different from any microwave I've ever used! There are no numbers to use to time cooking. Like I said before, it is the GE Advantium 120...really a beautiful appliance..but entirely different. Nothing in the 24 pages I downloaded address the differences I've encountered. Now what?
    Hi there....Thank you so much for the 48 pages of helpful info. for my particular microwave. It's good to have this information; now I can begin to learn all about this magnificent machine! Again, thank you.
  • unis117 Aug 27, 2008
    Hi again. Now that I have the manual for my Advantium 120 GE Microwave, I see that there is a part missing....wouldn't have known that if I hadn't downloaded the complete Use and Care Book from you. Now, where can I get the Black MetalTray/Baking Sheet for Model #SCA1000 DBB03? Thanks.
  • 363 Answers
The manual is available on the GE web site
http://www.geappliances.com/service_and_support/literature/
Type in the model number
Good Luck.
Posted on Aug 26, 2008
  • Martin B
    Martin B Aug 27, 2008
    Glad to help and thanks for the FixYa!
  • Martin B
    You could order it through your local domestic appliance dealer.
    But I just found the part on the GE web site.
    Click http://www.geappliances.com/service_and_...
    I recommend you search the above link by appliance number SCA1000DBB03 then it will show a list of all parts.
    You want the 'oven cavity' parts list then you can display a diagram of everything available and order it straight from GE.
    I think you want part number WB49X10053.
My GE Profile Advantium 120 microwave sparks when I try to sterlize a kitchen sponge
Wayne,
If your sponge has any metal in it, that would be the cause of the sparking. The only other thing that could cause sparks is grease built up behind the wave guide cover or the magnetron is going bad.
Jun 13, 2015 | GE Profile Advantium 120 Above-the-Cooktop...
GE Profile Advantium 120 oven: Clock is on and stuck, unit will not work otherwise.
Unplug the microwave oven for 60 seconds to reset microprocessor, hopefully this will cure the problem.
Jul 05, 2012 | GE Profile Advantium 120 Wall Oven
The electricty to my home went out when it came back on the advantium reads demo & I can't get it back to regular settings.
Getting appliances out of demo mode usually involves touching a special sequence or a combination of buttons. You might call an appliance store that sells that brand and ask a salesman for some guidance.
Oct 10, 2009 | GE Advantium 120 Convection/Microwave Oven
Need to replace fuse in GE Profile advantium oven
remove outer shell/cover, the fuse will be in a fuse holder about 1" long X 1/8" in diameter and is called a ceramic fuse,take it out,look on ends for current rating go to hardware store they have repl fuses, if the new fuse blows it could be your h.v. diode, capacitor, or the magnetron tube
Sep 05, 2009 | GE Advantium 120 Convection/Microwave Oven
I have a GE profile advantium 120 . The panel lights up I do not get an error code the timer works but it does not heat up. what could cause this
Check your power setting, making sure that you are cooking at 100%. Adjust if necessary.
It could also be a bad magnetron.
Regards, --W/D--
Jul 05, 2009 | GE Advantium 120 Convection/Microwave Oven
The door handle on my GE Profile ADvantium 120 Microwave is broke
appliancepartspros.com. part number AP3187809 $56.40 plus shipping
Apr 27, 2009 | GE Advantium SCA1001SS Convection /...
GE Advantium 120 Opinion
I have had an Advantium for about 3 or 4 yrs and would use nothing else! When this one wears out I will buy another one! I hardly ever use my regular oven any more! Hope this helps.
Feb 02, 2009 | GE Advantium 120 Convection/Microwave Oven
GE Advantium SCA 1001HS
Should be able to get to the lamp by removing the grill.
Oct 04, 2007 | GE Advantium SCA1000H Convection /...
Open Questions:
GE Microwave JVM1441BH04: Safe to reconnect replacement stirrer & turntable motors after accidentally burning out the turntable motor? GE JVM1441BH04 Over Stove Microwave: Tapping noise was coming from the 21v AC stirrer motor which sits atop the cooking chamber. I disconnected the two connecting leads, unfastened the single screw holding it on, placed in on my scanner glass to get a high rez photo of all the specifics listed on the motor label. Bad news: While waiting for the scan to finish, I warmed my coffee in the microwave on the highest heat for 30 seconds. I subsequently discovered the 21v AC turntable motor, which had been working just fine, was now no longer working, with infinite resistance across its terminals, and a burnt electrical smell. Both the stirrer and turntable motors are powered by a 24v tap off the magnetron fan. My theory: By running the microwave with the stirrer motor out of the circuit, I delivered excessive voltage to the turntable motor, which quickly fried. The 24v tap off the magnetron fan motor currently shows the correct 24v output. However, with both the stirrer motor and turntable motor disconnected, running the microwave for a few seconds shows approx 95v across the wire leads for both of the 21v motors. I have obtained replacement motors for both the noisy stirrer motor and the fried turntable motor. My question: Can I simply reconnect both motors in their proper locations, vow never again to run one without the other connected, and all will be well? Or will the newly installed motors simply be fried in a matter of seconds?
Jan 04, 2018 | GE Microwave Ovens
Microwave Ovens Logo
188 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
