Question about Hoover Washing Machines
Water enerting on a drying cycle - Hoover Washing Machines
  • 639 Answers
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
What do you mean????water enerting on a drying cycle
What brand and model number is your washer or dryer ???????????
For "water to enter a Dryer", the outside vent must be open to the rain! or your clothes came out of the dryer so wet that the spin cycle of the washer is not working???????????????
Or do you have one machine that does both wash and dry????
Here is a good service that I recommend to my customers,
in our 65 year old appliance business! they answer 24/7
Not expensive!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 26, 2008
Water not heating up and not drying
Hello
If your dishwasher is not heating properly, troubleshoot the issue. You can often repair this problem and eliminate service fees.
Incoming Water
Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
Thermostat
The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
Heating Element/Drying Fan
The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
Additional Concerns
If your dishwasher isn't drying your dishes properly, see if you have selected a heated drying cycle. An air drying cycle doesn't completely dry your dishes. Never overload the dishwasher, as this prevents heat from circulating around your dishes, keeping them from drying properly. Plastic and Teflon dishes don't usually completely dry. You must towel-dry these items.
Sep 12, 2011 | Bosch 24 in. SGS43C12 Classixx...
The machine fills with water during drying cycle and does not fill for the wash cycle
First, did you know that this machine steam dries clothes? The first thing it does on the dry cycle is to wet the clothes which it then heats to dry with condensation. There are better answers regarding this feature on fixya. But assuming that the dry cycle is working as well as it ever does, it appears that your wash cycle is not functioning properly. I would need more info to figure out why it is not filling with water / working at all.
Mar 31, 2010 | Malber WD1000 Front Load Washer/Dryer
The washing machine never runs a complete cycle...it never performs the rinse and spin...always displays a 'nf' code it has never run a cycle completely through
- Foreign material is entering the water supply valve.
- The water supply valve terminal is not connected.
(Wire disconnected)
- The warm water and rinse connectors are wrongly
connected to each other.
- This occurs if the PCB terminal from the drain hose
to the detergent drawer is not connected. Check
whether the transparent hose is folded or torn.
- The cold and warm water supply hoses are wrongly
engaged into each other.
- The temperature of the water supplied through the dry
valve during a dry cycle is sensed as higher than 70
˚C.
The water
supplied for 1
minute drying
the drying cycle
is 0.3 ~ 0.4 L.
- The water temperature is sensed as higher than 50 ˚C
in the Wool or Lingerie courses.
Dec 27, 2009 | Samsung WF338AAB 4.0 cu. ft. Front Load...
Machine keeps stopping and showing fo5
ALARM CODES
E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
E22 Problems with water drain during drying or drying
condenser blocked E20 Heating phase skipped 8.5
E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
with door closed 8.6
E32 Incorrect calibration of analogic (electronic) pressure
switch --- Cycle PAUSED 8.7
E33
Incongruency between level of analogic (electronic)
pressure switch and level of anti-boiling pressure
switch 1
--- Cycle blocked
with door closed 8.8
E34 Incongruency between level of electronic pressure
switch and level of anti-boiling pressure switch 2 --- Cycle blocked
with door closed 8.9
E35 Water level too high --- Cycle blocked with door
closed and water drain 8.10
E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
with door closed 8.11
E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
E38 Pressure chamber blocked --- Heating phase skipped 8.12
E41 Door open E40 Cycle PAUSED 8.13-14
E42 Problems with door closure E40 Cycle PAUSED 8.15-16
E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
with door closed 8.19
E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
closed (after 5 attempts) 8.20
E52 No signal from tachometric generator --- Cycle blocked with door
closed (after 5 attempts) 8.21-22
E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
with door closed 8.23
E54 Relays (motor) contacts faulty --- Cycle blocked with door
closed (after 5 attempts) 8.23
E61 Insufficient heating during washing --- Heating phase skipped 8.24
E62 Overheating during washing --- Drain, end of cycle 8.25
E63 Insufficient heating during drying Heating phase skipped 8.26
E64 Overheating during drying --- Heating phase skipped 8.27
E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
E71 NTC wash sensor faulty --- Heating phase skipped 8.29
E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
(door open) 8.32
E85 Circulation pump faulty --- Drain, end of cycle
(door open) 8.33
E91 Communications error between main PCB and user
interface --- --- 8.34
E93 Configuration error E90 Cycle blocked 8.34
E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
EF1 Drain filter blocked LED-EF0 --- 8.35
EF2 Excessive detergent LED-EF0 --- 8.35
Regards David Marsh
Oct 22, 2009 | Washing Machines
Model # dwu7702aae has heat delay light coming on during cycle. Why?
Heater is used to both heat water during clean cycle and dry dishes after wash cycle. Most washers have either a separate switch for Heat or Dry for optional use, or some have the water heat and dish dry options built into cycle set options.
You can save money by turning off the Dish Dry option since it is a very in-efficient way to dry dishes. Instead, open the wishwasher door after washing cycle completes, just enough so fresh air can get into, and humid air can escape, dishwasher.
Water Heat option is only needed for dried food on dishes, and is never needed if dishes are either rised off before putting them in the dishwasher, or rinsed off inside the dishwaser with a Rinse cycle, if they are to stand for a time waiting for a full dishwasher for wash.
Feb 22, 2009 | Maytag Dishwashers
LG all in one washer dryer fills with water on the drying cycle
the unit is made to bring water in in the drying cycle ,,the water dont touch the clothes..the water is to take the lint away and to cool the drum,,you must remember that you can was 22 pounds but you can only dry 11 pound..so you must dry about half of what you wash..and drying the 11 pounds it will take 3 to 4 hours,,no exhaust...
Sep 21, 2008 | LG WD-3274RHD Front Load Washer / Dryer
Water is being used in the drying cycle
This is normal operation. Water is used by the condensor to liquidfy the steam from drying.
Mar 27, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Dishwasher not drying
A technician told me that the dry cycle depends on the heat from the water during the wash cycle. If your water heater is far away from your dishwasher, turn on your tab at the sink and make sure the water is hot before you start your dishwasher. Otherwise, the dishwasher is using cold water and thus when it gets to the dry cycle, the dishes won't dry.
Oct 14, 2007 | Thermador 24 in. DWHD64CS Stainless Steel...
E20 During Drying Cycle
if the wash cycle runs ok then unlikely to be the drain pump or hoses. put drain hose into a bucket and check waster comes out during dry - it wont be large amounts of water. can you hear the drain pump running during the dry cycle?
Mar 08, 2007 | AEG Lavamat 16810 Front Load Washer/Dryer
Washing Machines Logo
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
