Question about Panasonic Lumix DMC-FZ10 Digital Camera
Battery like the FZ1
Does it take a proprietary battery like the FZ1?
    Master:
  • 903 Answers
It's said to use exactly the same battery as the FZ1, the CGA-S002E battery.
Posted on Sep 06, 2005
SOURCE:
Hello, My 2013 Fz1 wouldn't start? Have checked battery, fuses, TPS, APS
Hi, Tanuj before testing any electrical component in the Starter Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amps causing the battery to be faulty and must be replaced, especially "AGM" batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Security alarm needs a reset.
10. Starter relay, solenoid, starter have failed or circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. The electric starter is working but starter clutch has failed.
14. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
http://www.r6-forum.com/forums/57-garage-mechanical-help/162715-will-not-start-good-battery-no-clicking-but-no-turn-over.html
Bike won turn over Weird buzzing sound
Yamaha FZ1 Service Manual
OEM parts for Yamaha
YAMAHA FZ1 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 06, 2017 | 2013 Yamaha FZ 1
Spark plug change 2011 fz1
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Spark plug change
FZ1 Sparkplug Change
http://www.partsfish.com/page/oem-parts-for-honda
Jul 10, 2013 | 2011 Yamaha FZ1
Location of 2006 FZ1 regulator
Hi, John_harr167 for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
2006 FZ1 regulator location Google Search
2007 2008 Yamaha r1 STATOR FAULT not charging Regulator Rectifier location...
Yamaha FZ1 Owner Manual
Mar 15, 2013 | 2008 Yamaha FZ1 ABS
Will R1 wheels fit on a FZ1 second generation
Hi, Specialclay for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
R1 wheels on first gen FZ1 is it possible FZ1OA Message Board
R1 Wheel for the FZ
Sep 18, 2012 | 2009 Yamaha FZ1
Fz1 clutch replacement
Hi, Sb_bhaskar for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
How to change your clutch plates and springs
How to replace 2002 Yamaha FZ1 Clutch Gen 1
May 26, 2012 | 2009 Yamaha FZ1
How many way to charge ?
You cannot charge the battery using the USB cable.
Here are the battery specs for this camers.
Power Battery Form Factor: Proprietary D-LI8 Usable Battery Types: Lithium Ion rechargeable Batteries Included: Proprietary D-LI8 Lithium-Ion rechargeable Battery Charger Included: Yes
Mar 11, 2012 | Pentax Optio S5i Digital Camera
I have a 2005 FZ1 with under 11,000 miles and I haven risen it much this week. I tried starting this morning it is a little chilly. It started and I stalled pulling out the driveway and now the lights all...
Hi, Wejohnson98 before testing any electrical component in the Starter Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amps causing the battery to be faulty and must be replaced, especially "AGM" batteries.
What to do When Your Motorcycle Won Start
Yamaha FZ1 2007 Service Manual
Sep 17, 2011 | 2005 Yamaha FZ1
My datatool alarm will not turn off when I connect a new battery. Why?
Hi, Anonymous I would contact Datatool for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Datatool S4 won disable
Datatool Alarm and bike battery removal question in Fazer 1000 FZ1 corner...
Support Datatool
Yamaha YZF600 YZF600R 1994 2007 Service Repair Manual PDF Download Manuals...
Yamaha YZF600RP Owner Manual
Jun 28, 2010 | 2000 Yamaha YZF 600 R thunder cat
Panasonic DMC-FZ1 Flash still not working
If you have a lightning symbol followed by “A” in the upper left corner of display, try to change it to forced flash (only lightning symbol) or reduce iso settings because probably the camera “thinks” there’s sufficient light for the photo.
Oct 08, 2007 | Panasonic Lumix DMC-FZ1 Digital Camera
My camera's LCD screen goes black every so often. Is there something wrong with the camera?
No. All Lumix® Digital Cameras have a built-in feature to conserve battery power. After a certain amount of inactivity, the LCD will power down to preserve the battery. Simply hit the SHTR button, and the LCD will turn ON.
Aug 30, 2005 | Panasonic Lumix DMC-FZ1 Digital Camera
Panasonic Lumix DMC-FZ10 Digital Camera Logo
47 people viewed this question
Top Panasonic Cameras Experts
rajiv6089
Level 1 Expert
AJMAL KHAN
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
