Question about Epson Stylus CX6600 All-In-One InkJet Printer
Epson 820 waste ink pad replacement - Epson Stylus CX6600 All-In-One InkJet Printer
  • Anonymous Aug 30, 2008
    Waste ink pad in the printer is saturated
    Product EPSON C90
  • 353 Answers
The printer must be dismantled to replace the waste ink pads. Get hold of the service manual (free) from
http://www.eserviceinfo.com/index.php. You will also need to download the free SSC utility from http://www.ssclg.com/epsone.shtml to reset the protection counter.
Posted on Jan 31, 2009
  • Gerry Millward
    Gerry Millward Jan 31, 2009
    Oh - what I should have said is that you can overcome this problem temporarily bu using the SSC utility to reset the Protection Counter. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens.
I have a problem with my printer epson stylus C90. may i know what todo when parts of my printer are near the end of their life service.?how can i fix it?
It means waste ink pad full or nearly full. Reset waste ink counter using SSC ver 4.30. Find at indoreset.blogspot.com. Don' forget to replace pad, washing or extend outlite pipe to outside of printer.
Jul 23, 2009 | Epson Office Equipment & Supplies
Printer won't printer as message says parts are
Part are end life cycle : waste ink pad full. Need to reset waste ink counter. SSc ver 4.3 support RX 620 and 640. U can try using printer model RX 640. Menu Protection Counter, Show current value for checking. Reset protection counter. Or Try to find RX630 adjusment at indoreset,blogspot.com. Don't forget to replace or wash the pad. Or extend outlet waste ink pipe to outside.
Jun 28, 2009 | Epson RX620 All-In-One InkJet Photo...
I have a warning that my ink pad is saturated and needs replacing contack dealer for assistance (help)
Ink means pad for waste ink nearly full. Epson program read and count all waste ink from head cleaning and ink charge. Next, you need reset waste ink counter, and replace or washing pad. You can extend outlet pipe to outside of printer, so next time you don't need replace pad again.
Jun 27, 2009 | Epson Printer
Need replacement waste ink pad
Hi...
so bye bye waste pad... can't find any replacements but this is my recommendation for you a waste tank... It's what I did on my 2 Epson Printers... Click the link to get the idea...
waste tank
Or you can use some tissue papers to replace what was thrown away.
Happy Fixya...
Feb 28, 2009 | Epson Stylus Photo 925 InkJet Printer
Trouble codes - red and green light flashing alternately
The Waste Ink Pads in your printer are saturated with ink and the waste ink counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
and reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. If you want to have a go at doing this yourself, the 820 service manual can be downloaded from here:
810/820 http://www.mediafire.com/?m6ouftizois
Jan 11, 2009 | Epson Stylus Photo 820 InkJet Printer
Printer Parts Worn Out
This is usually a sign that the Waste Ink Pads in your printer are saturated with ink and the waste ink counter has exceeded its limit. However, your two printer lights should also be flashing alternately.
If this is the case, the Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
If the printer lights are not flashing, you really need a technician to have a look at it for you.
Oct 21, 2008 | Epson Stylus Photo 820 InkJet Printer
Epson stylus 830Uink pads full not printing help
and reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. Should you decide to have a go at changing the waste ink pads, the 830 service manual can be downloaded from here:
Jul 13, 2008 | Epson Stylus Photo 820 InkJet Printer
Epson stylus photo 820
Hi Ikarp9090
If both lights are flashing, it usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from:
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (820), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. You should see that the current count is above the limit; then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help. It is a pretty simple job once someone explains how to get the case apart!
If this solution helps you, please rate it; if it doesn't, please provide further information by posting a new comment.
Apr 29, 2008 | Epson Stylus Photo 820 InkJet Printer
EPSON 2200 - Waste Ink Pad Replacement
You can replace the pads yourself.... I wouldn't really mess with it though. There are other ways Google search "Waste Ink Epson 2200" to see how to setup an external tank.. I have mine setup this way and its been no problem.... If you're set on taking them out remove the screws from the sides and middle and the bottom will drop away and reveal the pads.
Mar 25, 2008 | Epson Stylus 2200 InkJet Photo Printer
Epson Stylus CX6600 All-In-One InkJet Printer Logo
747 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
