Question about Panasonic Lumix DMC-FZ10 Digital Camera
Buffer size
What is the buffer size on the FZ10? I've seen it can take 4 consecutive shots a second at full resolution, but how many can it take before the buffer fills up? And how long before the next shot once the buffer is full? And how long for the buffer completely empty?
    Genius:
  • 2,985 Answers
The manual sholud tell you this - check out the PDF file on the software disk
Posted on Aug 03, 2007
When I try to open Call of duty it apperas the error 998 and the message buffer overrun detected
Any time I've seen this error appear when playing a game it is caused by a bad graphics driver. I would suggest going to the website of the retailer that your graphics devices comes from and updating to the most recent driver and giving it a shot.
Many different things can cause buffer overruns. This is a common attack that hackers use to exploit bad C code. In this case, since it's a video game...I'm going to say graphics driver.
You can actually see an example of the same behavior here:
http://www.techsupportforum.com/forums/f59/solved-buffer-overrun-detected-error-on-call-of-duty-1-a-459612.html
I hope this helps! If this did help you, please give a thumbs up!
Thank you for choosing FixYa!
Jun 28, 2011 | Computers & Internet
Nikon D70 The flash won't pop up and a clicking sound when I push the shutter. Also get r03 error. Jenean Stone
HI,
Remove lense, replace
Remove battery, replace
Change shooting mode - try full auto, jpeg not raw
Reset camera to factory defaults
Replace/format CF card
Nov 01, 2008 | Cameras
Nikon D100 shutter freezes up after taking about 5-10 pictures in a row, same lighting same postion some pictures end up out of focus?
are you shooting in raw format? and in hi resolution or low resolution ? If you are shooting in RAW then the buffer of the d100 is full and it needs to empty its buffer before you can shoot anymore pictures
May 06, 2010 | Nikon D100 Digital Camera
Hi K akima...have followed your advice, but no luck. When I go to continuous mode, it only lets me shoot a single shot, the display briefly reads r 08 then returns to r 09 again. I`ve tried my other lenses...
nikon r09,r11, etc . it mean memory buffer of your camera. memory buffer is a temporary memory for your captured images before it store to memory card.
if r00 it mean, you can't take a picture, even 1 picture... that because the camera buffer memory is full.
the number of memory buffer will also drop if noise reduction on
Feb 14, 2010 | Nikon D80 Digital Camera with 18-135mm...
My canon EOS 40D with 18 - 55 IS , when continuous shooting mode is selected, slows down after taking 6 shots. However as per the spec its capable of taking 75 jpegs or 17 RAW images.Please resolve this...
Slow down after taking 6 RAW files ...
A RAW file is Approx. 12.4MB.
The memory usage is approx. 74,4 MB
The internal memory (Buffer) has a size for up to 75 JPEG compressed images.
Which size has the smallest jpg?
JPEG/Small: Approx. 1.2MB (1,936 x 1,288)
The Buffer is approx. 80 MB.
The data are calculated under Canons laboratory conditions.
The maximum Burst (the 17 shoots) means that the camera is writing to the card and the buffer is full. Than the cam will stopping taking pictures.
Which kind of Card do you use?
Check the spec for the card (write speed) and maybe buy a faster card.
Jun 07, 2009 | Canon EOS 40D Digital Camera
Shutter speed won't go over 5 frames a sec. on d300
Even if your camera is rated at shooting more than five continuous frames at a time, those are stored in a memory buffer in the camera, when the buffer is full the camera writes the images to your flash memory card. How fast the memory card can accept the data will determine who fast space is made available in the buffer for a sixth or seventh shot.
The main limitation on how many images can be shot in continuous mode is based on the storage capacity of the memory buffer and also how fast images can be written to your inserted memory card.
So, the higher the resolution the image the more space it takes in the memory buffer. Should you shoot in a smaller resolution you should be able to shoot more frames continuously. However, there are a few variables involved. If the Camera is preset at the factory to not store any more than five images no matter what the resolution than there is no way around this encumbered feature. And, or the speed at which the memory card you use can accept written data will also decide how fast the buffer is cleared for new data.
The highest speed flash memory conforms with Version 6 and has a write speed of 188x.
So, the things to double check is if a limitation is built into your camera of five images and no more than five no matter what the resolution. This is not uncommon. The second is the speed at which data can be cleared from the buffer and written to the memory card, less common but a newer standard now that faster flash memory cards are becoming available.
Now, all that being said, There are 'firmware' updates released from time to time that make adjustments to camera features than can change these variables
Most Nikons use Compact Flash so see if you can get a high speed card that is version 6 compliant. But, first, check the sony support site for your camera and see if 5 is the limit no matter what. And if so, see if there is a firmware update under downloads at the support site that increases the number of shots that can be stored in buffer while being written to the flash memory card.
I have a client wtih a D60 who when she switched over to 133x Compact Flash was able to shoot more frames faster in continuous mode.
Please don't hesitate to use the comment text box below for any further assistance, such as the support page at Sony for your camera if you don't have in in yoru manual. Or any information you may need regarding shooting in high speed mode and what format to use. Most Pros that consult with me are using JPEG uncompressed. If you have questions please provide more detail on how you have your camera setup and under what conditions you are shooting in when attempting to capture more frames per continuous mode shotting.
Regards,
Worldvet
Jan 14, 2009 | Nikon D300 Body Only Digital Camera
Busy signal while taking a picture
Have you been taking shots in continuous mode (burst)?  The camera has a built in buffer of fast memory where photos are stored before being written to the slower CF card.  Once the memory gets full the camera will not take another picture unless some of the images complete transfer to the CF card. You will notice a number inside your viewfinder (bottom left) the number goes down when you take a picture that is how much space is left in the buffer when it hits 0 the buffer is full it will go up as the buffer clears.  Note that RAW takes up more space and fills the buffer quickly.
If you get the "Busy" message even after just 1 shot then there is something wrong with either your CF card or your camera and you should take try another card or it to canon for service.
Nov 26, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Not functioning d200
Nikon D200 High Speed Performance
© 2006 KenRockwell.com Film vs. Digital About these reviews
enlarge
I bought mine from Ritz here. I bought another D200 from Adorama here. Also try Amazon here. Adorama usually has D200/18-70 kits in stock here. It helps me keep adding to this site when you click these links to get yours.
HIGH SPEED PERFORMANCE
General:
My D200 is fast, smooth and quiet. Unlike my D1H, my D200 makes less noise and vibration. It doesn't feel as macho, and allows me to shoot in more places more discreetly. At five frames per second it just hums along sweetly, compared to my bigger cameras which always felt like something was going to come flying off of them from all the clattering.
Buffers versus Memory Card Memory
The D200 uses two very different kinds of memory for storing images.
We're all familiar with the CF cards used to store hundreds of images. These aren't that fast and card makers rate them for write speed. The D200 uses these for recording your images.
The D200, like all professional digital cameras, has a second very high speed internal cache memory called a buffer. You never touch this. This buffer memory stores 25 frames of JPGs, 21 frames of raw or 19 frames of raw + JPG.
The buffer memory is fast enough to store all these frames at the full 5FPS rate, or faster.
The D200 is never slowed by memory speed card. The D200, like other professional cameras, has a second independent set of processors which handle writing the contents of the fast buffer memory to the slower CF card. Because this writing is done with a second set of processors you never know it's working except for the green CF light on the back. The D200 can be busy for over a minute writing to the CF card and you still have the complete ability to shoot at 5 FPS and play back.
The buffer is so deep that even under the heaviest shooting it's unlikely that you'll ever fill it. Even if you fill the buffer you can still make photos and playback, just that the maximum shooting rate will lower a bit until the buffer write and frees up at least one frame.
It takes it a 100 seconds to write 400 MB of data from 19 uncompressed RAW + Large FINE JPG files to my 40x 1GB Lexar card. As a photographer you don't care how long it takes to write. So long as the buffer isn't full the camera works as fast as ever. Even if it is full you can shoot the next shot as soon as the buffer clears enough room. You don't have to wait for everything to write to make a next shot. Even with my slow 40x lexar 1GB card, a constipated buffer and huge compressed raw + JPG Large Fine files I can make a new shot every 3.2 seconds. With uncompressed raw + JPG Fine Large I can get off a new shot with a full buffer every 3.7 seconds. If you ever get to these limits you're doing something stupid. Just shoot JPG and you'll never be able to fill up the buffer faster than you can shoot. With Large FINE Optimal Quality JPGs the buffer clears at the rate of 1 FPS. With Large Basic Optimal Quality JPGs I can run at 2 FPS even with a full buffer. Use the smaller image sizes or the Size Priority JPG setting and you can shoot as fast with the buffer full as empty!
I've had to do seriously stupid tests to fill it up.
Shot Buffer Readout
A shot buffer is fast memory inside the camera which stores the shots you've just made. Your memory card is written from this buffer. Even with the slowest card on earth you can shoot as fast as you want, since it all sits in the buffer until written. Your card is recorded in the background while you shoot. The green CF light tells you this is happening.
The size of this buffer is how many shots it can hold while allowing you to shoot at 5 FPS. If it gets full the camera slows to only as fast as your card will accept data, which is about one frame per second . These buffers are why you don't need to worry about card speed.
I've never filled up more than 9 shots in a buffer. I don't shoot that fast. With a 25 frame buffer the D200 has far more than I'll ever use.
This is the number you see while the shutter button is pressed halfway. It usually looks like [r25], which means it's empty and can hold 25 more shots. Normally you'll see a big number like [527] or [ 1.3]k, which is how many shots are left on your card. As you shoot fast sequences you can see this number drop. When it drops to [r00] your buffer is full and the camera slows down its shooting until the buffer is recorded to the card. It's fun to look at when you get your camera, but since I never fill it up I don't worry about it. You'd have to be shooting many long high speed sequences continuously with a slow card ever to use much of this.
Jan 27, 2008 | Nikon D200 Digital Camera with 18-200mm...
CD400 Buffer Capacity.
well the camera has a 3 burst shot mode so I would have to say 3.
Sep 13, 2005 | Sony Mavica MVC-CD400 Digital Camera
Unlimited consecutive shooting function
This functionality allows unlimited consecutive shooting up to the capacity of the SD Memory Card in the camera—ideal for capturing fast-moving objects in high resolution. The number of shots may vary depending on memory card size, picture size, and compression.
Aug 30, 2005 | Panasonic Lumix DMC-FZ10 Digital Camera
Panasonic Lumix DMC-FZ10 Digital Camera Logo
124 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
