Question about Panasonic CT-36SL13 32" TV
Tv lock i have a panasonic ct 32SL just change the fuse and when plug in it come on by it self i have no control over it no buttons work can you help thanks
    President:
  • 196 Answers
PRESS POWER SWITCH AND ACTION FOR 3 SECOND
Posted on Sep 10, 2008
CT-32SL 13 antenna busted off, how can we hook up
you can use your rca connectors for your cable if your cable box have rca all you need is rca jacks if you don't have a box and all you have is the coax , then you can use a vcr or a dvd with coax input and rca output "hope i explain this right {" tv-----rca's--2---rca jack output vcr ---coax input ---hook up coax CABLE
May 14, 2010 | Panasonic CT-32SL14 32" TV
Tv won't turn on at all
no remote but tv was working with front power key? unplug from ac outlet and plug back and listen for any type of indication (noise or chirp) that something energizes inside if theres nothing then suspect a power supply problem, main fuse blown, shorted low volt rectifiers other components could be at fault.
Aug 05, 2009 | Panasonic CT-32SL13 32" TV
Where Is The Fuse Located In A Panasonic CT-32SL-23G ?
You will need to remove the back of the TV. Don't worry, it's not that bad.
There are 4 screws across the top, one on each side on the bottom toward the front, one right next to where the power cord goes into the back of the case, and the two more by all of the video connections **These are the most important to remove because they attach the main board to the back of the case.
Once you have remove the screws then the entire back of the set will slide off. If you look where the power cord attaches to the board you will see a small fuse. This is a 6.3 Amp 125 volt fuse. You can replace it with a 6.3 Amp 250 volt fuse from your local Radio Shack. A four pack costs between $3 and $5.
Make sure that you check that it works before putting it all back together. Check for any loose connection cables while you're back there. I found a few when I did this.
Jan 24, 2009 | Panasonic CT-32SL13 32" TV
TV Won't Turn On
there is no reset button - the main fuse has probably blown and needs replacing (6.3A 250 V)
Dec 26, 2008 | Panasonic CT-32HX42 32" TV
Won't turn on
Once you take the back off there is a glass gma fuse withing a few inches of where the power cord plugs into the board at. This should be a 6.3 or 6.5 gma fuse. Very common to blow in your model because the degausing coil is a little to big for it. There are other reasons for it to blow but 99% of the time you change change it and the set will work again. Let me know if you need more help or info!
Tim Nolan
Sep 11, 2008 | Panasonic CT-32HX41 32" TV
Cant turn off panasonic PIP
To turn off the "stuck" pip on a Panasonic tv without a remote, turn off the tv. Then hold down the "Action" button on the front of the tv and press the power button. This will activate a reset and self check of the systems and voila! The pesky pip screen will be gone! This is on an approximately 10 year old regular crt "CT-xxxxx" series tv.
Jun 12, 2008 | Panasonic CT-36D32 36" TV
TV does not power up
Check Power Cord is Plugged into Active Outlet
Adjust Brightness and Audio Controls Change Channel Check Cable Connections Program the Remote Control Again Check Second Video Source Operation As warranty has expired, check if fuse at power supply input is ok.
Consult online manual for troubleshooting.
http://www.fixya.com/support/p232673-panasonic_ct_36sl13_32_tv/manual-7023/page-22
Feb 14, 2008 | Panasonic CT-36SL13 32" TV
Re: Vchip code
you need is factory setting!
Oct 05, 2007 | Panasonic PV-C1321 13 in. TV/VCR Combo
CHANGE CHANNEL
TRY manually if it does not help your problem 1 remote contacts. 2 remote. 3 problem in tuner 4 problem in system control circuit relating to tuner.
Sep 26, 2007 | Televison & Video
Panasonic CT-36SL13 32" TV Logo
180 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
