Question about Kenmore 15516 Mechanical Sewing Machine
Problem of pulling the thread up from the bobbin place
My problem is that the sewing machine doesn't hold the thread up from the bobbin well.
  • gendm Aug 27, 2008
    the sewing machine that I am using is Kenmore 15516 hope to find manual for this. hope to hear someone here a help.
    New Friend:
  • 46 Answers
I will be happy to resolve a tension issue with this machine but I need more information. I'm not sur ewhat you mean "hold the bobbin thread up well"
Manual can be ordered at or google kenmore owner's manuals and there are sites that you can download. I don't of any free ones though.
Posted on Nov 06, 2008
Thread keeps coming out of needle when sewing
When you start sewing, make sure the thread is long enough so the machine does not pull the loose end down into the bobbin casing. It is best to drawn both threads (bobbin and top thread) up through the pressure plate before you place the fabric under the pressure foot.
Mar 23, 2016 | Sewing Machines
Tried to thread the bobbin but the machine just have the sound but not doing anything
are you sure you followed all steps? Make sure you followed the
threading diagram correctly. You must pull your thread through a hole in the bobbin,threading from the inside of the bobbin to the out side .hold the thread on the outside of the bobbin and wrap thread around the bobbin shank twice. Hold the thread in place and find the groove on the bobbins' outside then match that to the "wire" on the spindle of the winder. You will then disconnect the drive by turning the small knob inside the hand wheel. Next ,you will push the bobbin spindle against the small wheel to create traction to turn and fill the bobbin. My guess is that either the bobbin was not in place or you forgot to push the winder against the traction area. Happy sewing.
May 14, 2014 | White Sewing 1409 Mechanical Sewing...
Bobin will not pick up
The most common reason I see for bobbin thread not being picked up is that the needle is in backwards. Or the needle is a little bent (sometimes it's so little you can't see it, but the machine knows!). So start by trying a new needle (size 80/12 is what's used for test sewing on most machines). If that doesn't work, turn the needle 180 degrees and try again -- there is a definite front and back to a sewing machine needle.
Make certain that your bobbins are the exact ones recommended for your machine. Many look similiar, but if they are off even slightly in depth, they will not work. Also, make certain your bobbin in locked into position in it's case and the thread is coming from the bobbin in the correct direction. When holding my metal bobbin in my hand, the thread pulls counter clockwise before placing it into my front loading bobbin case. Each machine is different so check your manual.
Jul 12, 2011 | Simplicity Sew Precious SWSP2 Mechanical...
After I sew I can pull the bottom stitching right out. What causes this? Help
The problem is most likely thread tension. First try loosening the upper thread tension (numbered wheel on left side of most machines), if this doesn't rectify the problem then check the bobbin case tension. Correct bobbin case tension can be verified by holding the bobbin case with bobbin inserted and thread extended several inches. If you grasp the thread the bobbin case should not descend rapidly (fall) but should unspool slightly when thread is quickly tugged upward. Please refer to attached picture or your owner's manual.azcouture_1.jpg
May 15, 2011 | Brother LS-1217 Mechanical Sewing Machine
I cannot get the bobbin thread to catch and pull through the footer wen trying to thread the machine?
Make sure your bobbin is placed in correctly. Thread is counterclockwise as you place bobbin in the metal piece. Pull thread end through sliver in metal piece. Hold on to movable metal latch then lock the bobbin in place. Bobbin should not fall out but is able to rotate. Rotate the wheel on the furthest right of your Singer 1507 machine towards you to move the needle downward. The top thread should then be able to catch and pull up the bobbin thread.
Dec 02, 2010 | Singer 1507
How do i thread my needle with the singer handy stitch?
  1. Loosen needle screw & insert needle with shank's flat side facing front of machine. Push needle in all the way, then tighten screw to hold needle in place.
  2. Install a fully wound bobbin by loosening bobbin nut & placing bobbin on top. Re-attach bobbin nut & tighten. If standard thread spool will be used, then attach spool pin to bobbin shaft & place thread spool onto shaft. Attach white spool cap on end of thread spool, then tighten. Bobbin/spool should unwind facing forward toward needle.
  3. Bring end of thread through thread guides & over tension control. Pass end of thread through needle eye, from back to front, & pull it out about two inches.
  4. A spring pushes pressor foot onto fabric that is being sewn, so lift pressor foot & place fabric underneath.
  5. Turn large handwheel on side of machine (handwheel can be turned in either direction) to raise needle arm to its highest position.
  6. Holding the Handy Stitch in place with your right hand, press on power switch & begin sewing. Guide fabric (being sewn) with your left hand.
  7. To end this sewing session, turn off power. Turn handwheel to raise needle to its highest position. Carefully pull out about three inches of thread through needle & snip, then lift pressor foot to remove fabric. Turn fabric over & loop needle threader through last stitch. Place end of thread from underside through eye of needle threader, & pull to loop through. Pull to tighten and snip end of thread.
Nov 11, 2010 | As Seen On TV Handy Stitch Mechanical...
The machine stopped sewing, the top thread doesn't pick up the bobbin thread, even when I just installed a new bobbin and try to just run the machine by hand to pick up the bobbin thread.
Have installed your bobbin right? By this, I mean drop the bobbin in but make sure that you pull the thread through the tension spring by putting your finger to hold the bobbin in place, then pull on the thread to get the tension. Let me know if this works.
Jul 24, 2010 | Brother LS-2125 Mechanical Sewing Machine
How do i thread my sewing machine if it doesnt
Place the bobbin flat on the table with the thread winding clockwise (comes off the top of the bobbin and points right).
Place the bobbin-case with the hole pointing up, insert the bobbin without changing directions.
Find the slot in the bobbin case, and pull the thread up and past the end of the spring until it clicks into place.
Insert the bobbin and bobbin case into the machine.
Thread the Needle, and give it about 6" extra thread past the needle, hold the thread taunt (from the needle) and rotate the handwheel (top comes toward you), after a turn or 2, gently pull the thread from the needle and lift up the bobbin thread from the slot.
Break a Leg
Jan 03, 2010 | Sewing Machines
Top thread gets caught on crescent piece holding in bobbin case
If you have the manual take a better look at how to put the bobbin in the case,
sounds like you are putting it in wrong,
make sure you put the bobbin in with the thread com-ming off the bobbin in the right direction (left or right) if not put in the right way you will get what you are saying
ALSO: bring up the bobbin thread your self by turning the hand wheal and bring the thread a few inches to the back of the needle and hold when starting to sew the first 2-5 stitches.
when you do not hold the thread the machine will pull the thread in the bobbin area and cause problems.
you will get use to holding and it will get easier.
hope this helps
Sep 03, 2009 | Kenmore 15208 Mechanical Sewing Machine
Kenmore 15516 bobbin
1. Remove the bobbin case
2. Release the clutch by pulling out the handwheel
3. Draw the thread from the spool andguide the thread throught the hole in the bobbin from the inside to the outside
4. Put the bobbin on the bobbin spindle
5. Push the bobbin to the right
6. Hold the free end of the thread and depress the foot control, wind until full
7. Push the handwheel in (to wngage the clutch)
8. Push the bobbin spindle back tot he left to resume sewing mode.
9. Place the bobbin in the bobbin case (thread should feed clockwise)
10. Draw the thread through the slot in the bobbin case
11. Continue to draw the thread under the tension spring and through the opening Pull out about 4"' of thread
12. Holding the latch open position the bobbin case into the shuttle and release the latch
13. Case should lock into place when released
Hope this helps!
Sep 27, 2008 | Kenmore 15516 Mechanical Sewing Machine
Kenmore 15516 Mechanical Sewing Machine Logo
80 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
