Question about Sony SDM-HS73P 17" LCD Monitor
17" Sony monitor black, on/off switch yellow
My husband is not tech savvy, neither am I. Would it be more economical to have it fixed or buy a new one? It was just working this morning. Bot it in May 06.
  • Anonymous Nov 28, 2008
    I have the same issue with all my menu buttons, sometimes they work, sometimes they don't. It's a hit or miss...
It may not be a inverter problem if your light is orange, if when you turn it on it says "no signal going to power save" then it is not the inverter because you can see the message. i am having the same problem with my sony sdm-hs73, and through my research the problem seems to be coming from the video/controller board. i dont know where to find one of these to replace my bad one though. any help would be apreciated.
Posted on Dec 29, 2008
    Champion:
  • 293 Answers
Hi...there,
It's seems your backlight inverter finally burnt out on ya... Need to replaced a new inverter or you can repaired yourself and show your hubby who the boss in the house...hehehe... Only need to replaced a couple of capacitors...that cost about $10 bucks! Well...good lucks!
Posted on Oct 15, 2008
I m having samsung SyncMaster 753s 17" black it
It sounds like your monitor has bad capacitors in the power supply that are slow to charge up. Repeatedly turning the power on as you do eventually charges them to the point where the monitor comes on. It isn't clear from your description if the monitor works properly when it finally comes on, so I don't know if it has other problems as well.
The shop you took it to probably didn't want to be bothered trying to diagnose the bad parts, because it's not economical to repair. They would need to charge you more for the repair parts and labor than the monitor is worth, and it's impossible to tell what other parts are ready to fail because of their age. I don't blame them. New LCD monitors are inexpensive, and it would probably cost less to buy a new one than to fix your CRT monitor.
My suggestion is to replace the monitor.
Dec 28, 2010 | Samsung SyncMaster 753S 17" CRT Monitor
Viewsonic vp171s lcd flickers on start up then goes black.
This is typical of a back-light problem, especially when you view the LCD screen at a sharp angle and you see a dim Windows image. This fault is caused by either a faulty inverter board or a faulty CCFL lamp.
The inverter supplies high voltage to the CCFL lamp. the CCFL lamp is a mini fluro lamp which fails with age and use.
This LCD screen can be repaired, the cost of an inverter board and CCFL lamp is a lot cheaper than a new LCD screen, but this is an opportunity/excuse to buy a larger size LCD screen as these monitors have dropped in price.
For service, parts and DIY info check out LCD Parts WEB site, please click on this link to their site :-
www.lcdparts.net
Feb 08, 2010 | Computers & Internet
Acer LCD AL1916W
This usually means the Power Inverter board is going bad. If you're a bit savvy with tech repair, you can look up and order a replacement board - LCD inverters for MANY LCD models are available on ebay and amazon - they're relatively easy to replace. Just make sure the power is UNPLUGGED before to start taking apart the display!
Feb 13, 2009 | Acer AL1715 (Black, Silver) 17" LCD...
17" Sony Monitor Goes Black and No Light Shows On The Switch
Sounds like your backlight bulbs are wearing out.It is a common problem with Sony LCDs. Difficult to replace then.
Monitor Mike
Jan 03, 2009 | Sony SDM-HS73P 17" LCD Monitor
NO PICTURE
Make sure it is plugged in with both cables.
Jun 17, 2008 | Sony SDM-HS75PB (Black) 17" LCD Monitor
Monitor is blank/black
It is probably the inverter board inside the monitor.
(if the screen does properly display ever then it is not the screen)
It CAN be fixed but I do not suggest anyone open up a monitor (LCD or CRT)
who is not "technically inclined." If you really want to fix this
particular one then take it to a local tech and get an estimate first. If it's almost as much as a new monitor then buy a new one.
Mar 14, 2008 | Star Logic 17" LCD Monitor
Laptop Display goes black:
Motherboard, (mainboard) problem. I can only recommend replacing it to fix the problem.
So you can look on ebay to get another motherboard, and take it to a local tech to install it.
I warn that this will probably be almost as expensive as buying a new Laptop. So unless you are sentimental to this one, buy a new one.
Mar 08, 2008 | CTX S762A 17" LCD Monitor
Screen is yellow
use the LCD's Auto Adjust Function. If fails try checking all cables and connections on the back.
Sep 15, 2007 | LG Flatron L1751S-SN 17" Flat Panel LCD...
Open Questions:
Sony SDM-HS73P 17" LCD Monitor Logo
248 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
