Question about Tomtom GO 700 GPS Receiver
Tom Tom 700 will not turn on.
It's off and resetting (bent paper clip) doesn't bring it back. It is charged, the green light lower left of screen is on when plugged into house current. Goes out when unplugged. Blank unlighted screen.
Will not respond
  • ali raza Aug 28, 2008
    i too have the same problem any idea's, also tryed the rest for 15 sec and power for 5 sec but no respons
    Novelist:
  • 158 Answers
Take a look inside your tomtom go . The photo's uploaded are of the GO and Go 300 / 500 / 700 Tom Tom 700 will not turn on. - 10676aa.jpgseries so yours might not look exactly the same but will be similar to these. SEE PHOTO of the IC's highlighted RED. U24 is on the same side of the circuit board as the card reader. U25 is on the same side of the board as the power socket. These are the 2 chips / IC's that will be blown if reversed supply or more than about 6 volts has been applied. The blown components are usually blown due to attaching the WRONG charger or a faulty charger. ( the tomtom cigarette lighter leads often go faulty ) These IC's are very very small ( just 3.5mm across ) and the 10 pins ( 5 on each side ) are even smaller and very close together therefore normal soldering ability will not allow a novice to replace them. Special soldering irons are needed , magnifying glass or special microscope for electronics + a steady hand and good light. Its highly unlikely that a home repair is possible. Besides that , even engineers with years of soldering experience have great difficulty replacing these components and it often takes me 30 minutes just to replace one of these IC's and I have a steady hand. Most normal electronics repair companys cannot repair this type of component as they will normally deal with bigger things. So unfortunatly, your "corner of the street" TV repair shop won't be able to fix it for ya either. As far as I know TomTom don't repair these IC's either as its too fiddly and time consuming and for them not worth the effort. Your only hope is one of the repair people offering this service on online . Try a look on ebay under "faulty tomtom" .
Posted on Sep 15, 2008
I turn on my tom tom go 700 and the screen appears with a picture of the tom tom in a green box and then it stops and i wont turn of
If your TomTom GO/ONE/RIDER is frozen, won’t turn on or does not behave as it should, it can be fixed by resetting or restarting your TomTom device.
A reset will not delete any data from your device, with the exception of SMS messages on TomTom GO500/700.
  1. Connect your GO/ONE/RIDER to the power charger. If you have a power charger, use it to power your TomTom GO/ONE/RIDER. If you do not have a power charger, make sure that the battery in your TomTom GO/ONE is fully charged.
    Note: You need to charge your GO/ONE for at least 2 hours using the 12-24V cigarette lighter adapter.
  2. Reset your GO/ONE/RIDER. To reset the unit, you simply have to push a straightened paper clip (or something similar) into the RESET hole on the device.
    • On TomTom GO 910/710/510, the RESET hole is located on the bottom of the device.
    • On TomTom GO 700/500/300, the RESET hole is located on the bottom of the device with the word RESET right next to it.
    • On TomTom ONE, the RESET hole is located on the bottom of the device, with the word RESET right next to it (just below the SD card slot).
    • On TomTom RIDER, the RESET hole is on the bottom of the device, behind the SD card door. When opening the SD card door you will see the RESET hole on the left, right underneath the SD card slot.
  3. Your TomTom GO/ONE/RIDER is now reset. Finally, press and hold the power button for 2 seconds.
Dec 16, 2009 | Tomtom GO 700 GPS Receiver
Tom tom will not turn on, but charge light works.
Please connect your tom tom to the power adapter first.Get a paper clip and press the reset button under the SD card slot of your tom tom.Reset button is a very small small hole at the back near the sd card slot.Keep pressing the reset button for 2mins and also press the power button till the light comes on.
This should fix the issue.Let me know if you need any more help.
Jul 08, 2009 | GPS
TOM TOM GO 910 TROUBLE SHOOTING
There is a tiny reset button on the back of the device where the mount goes. Its hard to spot so `go to the tom tom web site to get help with this if you can't spot it. Use a paper clip and press it in this recess hole for 30 seconds. This will reset the device and should work after that. make sure you back up your device and keep a paper clip in the car!
Nov 19, 2008 | Tomtom GO 910
Seeking the repair of my tomtom Go 910
One suggestion is to plug the Tom Tom using the temporary power cord to you home circuit (not the power source from the car). That worked for me. Sometime the Tom Tom shuts down when left in the hot car requiring a reset. Then the best way is to plug in at home and restart. Try it, otherwise I can't help.
Jim
Aug 19, 2008 | Tomtom GO 910 GPS Receiver
Unit will not come on green light is on and is docked to computer
tom tom kicked reset button[510]called customer assistance. use paper clip bent to a point turn unit upside down so ser# can be read you will see one gold ternimal on left side and about a dozen small terminals to the right just above last three terminals is a notch in plastic cover reset button is in middle of slot push with paper clip two or three times not overly hard.mine started working.when plugging to cig. lighter button kicked.easy fix hooray for TomTom.hope this helps.greetings from Music City.
May 29, 2008 | GPS
TOM TOM ONE GO GPS
remove the tomtom from the power source get a small paper clip and on the underside of the tomtom you will see a small pin hole it syas resetthe hole is where it looks like a sd card or something goes (but nothing goes there)
push that little reset button (in the hole) with the paper clip
hold it down for atleast 3 secs
then power the unit on give it a second itl be fine
remeber this happens a lot so keep that paper clip handy i keep it in my car all the time
hope i helped you
Feb 23, 2008 | Tomtom GO 700 GPS NAVIGATION BRAND ONLY...
Lcd screen do not light up
Reset the unit by pushing a bent paperclip or pin into the hole on the bottom marked 'reset' turn it back on, plug it in & charge it via USB overnight or as long as you can in the car, make sure the led on the top is green, tap the bottom right of the screen & check the battery symbol on the unit says charging underneath.
If this doesn't help.
contact them about the problem...
http://www.tomtom.com/support/support.php?ID=2
Dec 14, 2007 | Tomtom GO 700 GPS Receiver
Hi my tom tom go 700 dosnt turn on
I had the same issue. I used a paper clip to press the reset button on the bottom of the device.
I hope that works for you. Good Luck
Dec 12, 2007 | Tomtom GO 700 GPS Receiver
Tom tom go 510
There is a reset button (hole) underneath by the plug-in bar. It is real small, you'll need a small paper clip straighten out
Nov 05, 2007 | Tomtom GO 510 GPS Receiver
Tomtom GO 700 GPS Receiver Logo
2,392 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
