Question about Sunbeam SBM1000 Microwave Oven
Rotating ring need rotating ring assembly for sbm1000w microwave the is broken like to get a replacement for it
  • 100 Answers
The part number is 5889W2A014C.
It's available from www.microwaveglasstrays.com (toll free 1-877-894-0035)
Posted on Sep 06, 2008
Turntable does not turn, Replaced Rotating ring assembly still not turning?
It may be the servo motor that powers the turntable or the belt has snapped or come off. It is unlikely that you can get to the motor as the case is fitted with security screws. If so, you will need to take it to a service engineer.
Mar 18, 2016 | GE Advantium 120 Convection/Microwave Oven
Broken rotating ring assembly
you open the microwave and take out. see the video attached.
God bless you
Dec 17, 2013 | GE JVM1540SMSS Microwave Oven
Food Heats fine, but turntable wont rotate. Makes a loud noise until we press the
see this tips for to repair:
Inspect the plastic drive coupling that the tray sits on, as well as the ring-and-roller assembly, to make sure that they're working properly.
First, make sure the turntable coupler under the glass dish is not broken. Second, on the control board, find the turntable relay and test for voltage. Some turntable motors are 24 volts DC, so make sure your testing the correct voltage. If no voltage from the control board, then replace the control board. Otherwise head towards the turntable motor.On OTR models, you can get to the motor by un-screwing the bottom panel on the microwave. On countertop models, there will either be a knockout or screw on access panel. Check for voltage at the motor. If no voltage, check the wiring back towards the control. If voltage, then replace the turntable motor. The component list below also shows how to test a turntable motor.
Sep 09, 2012 | GE JVM1860 Microwave Oven
Won't Turn on
The turntable motor on the base of the machine may have failed. Take the plate out, put a small plastic jug of water in the microwave corner (out of the way of any roller), set for 30 seconds, and see if the spiggot/roller ring rotates. It also could be the spindle of the turntable motor has broken off in the spigott/roller ring.
Mar 21, 2009 | Microwave Ovens
Turntable wheel under glass tray broken
If the microwave comes with a roller ring to rotate the glass turntable then I would recommend that it needs to be used when the microwave is operating, as the turntable rotates the food so it can be heated evenly.
I would recommend checking with your local Panasonic repairer he may have access to a new roller or even a second hand one to tide you over.
Mar 20, 2009 | Panasonic Microwave Ovens
Broken glass on full sized microwave door
Unfortunately, you would have to replace the complete door assembly, you can find a replacement door assembly for this model at this link:
LG LRM1230W Replacement Part Complete Door Assembly
Jan 07, 2009 | LG LRM1230W Microwave Oven
Kenmore microwave 721.80803401 rotating table pops up and stops turning.
I would bet the arm ("ring assembly") is either worn or warped from heat? and is not meshing well with the motor shaft or glass tray.
That is part number 4351W1A003A and you can get it for only $6.30 (compared to over sixteen via Sears) from Tritronics.
The motor is part # 6549W1S018C and if it's the culprit, you can get that for $24.84 from Tritronics, compared to almost thirty-two from Sears.
You should look again and see how loose the arm is on the shaft and which might be worn or warped or out of perpendicular. I think that one of these is the problem.
Dec 21, 2008 | Microwave Ovens
Microwave rotating assembly jumps up and stops turning.
Turn table
See the following suggestions from Repairclinic:
The carousel won't turnAlthough the carousel is usually driven by a small motor that's unrelated to the heating function of the microwave, the microwave cabinet needs to be opened to repair it. So we recommend that you seek the assistance of a qualified appliance repair technician. Inspect the plastic drive coupling that the tray sits on, as well as the ring-and-roller assembly, to make sure that they're working properly.
Oct 24, 2008 | GE XL1800 1100 Watts Microwave Oven
Maytag Microwave Model 5200 - need plastic rotating ring
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
But it needs to be the full model number, not the partial you show in your post.
We're happy to help you and we'd appreciate yourthoughtful rating of our answer.
Jul 29, 2008 | Microwave Ovens
Sunbeam SBM1000 Microwave Oven Logo
183 people viewed this question
Top Sunbeam Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sunbeam Microwave Oven Expert? Answer questions, earn points and help others
