SMC Barricade g SMCWBR14-G (662698582192) Router Logo
Dee Cee Posted on Jul 12, 2011
I have an old SMC Barricade WBR14-G Wireless Router that still works fine. I stopped using it when I switched to 2wire from att. I want to use the SMC's repeater function to boost the signal to a pc located in the kitchen. That pc has a usb wifi adapter and the signal is a little weak. How do I "physically" set up the smc. Do I need to attach a Lan. I tried to go online to the admin page of the smc but couldn't. is this a lost cause? any help will be appreciated. Thanks, DC
5 Related Answers
ramji duraiswamy
  • 193 Answers
  • Posted on Oct 31, 2007
SOURCE: SMC signal suddenly extremely weak
login with ur router and change the channels>and use channel 11>1 and check with antena weather its straight looking the roof>and if its not works down grade or upgrade firm ware or use with out any security like wap or wep rate me solved if its help full thx
Anonymous
  • 143 Answers
  • Posted on Oct 07, 2008
SOURCE: SMC Barricade 2804WBR.
just hardwired a computer to the router and open a web browser. on the address bar of the web browser type http://192.168.2.1 (default ip address of the router) and you will be prompted with the login screen. by default you don't need to type anything on the password field. now you will prompted with the router's page and from there you can set it up.
click here for the manual.
hope this'll help you
ciao
Anonymous
  • 5 Answers
  • Posted on May 23, 2009
SOURCE: SMC Barricade wireless router needs to be reset constantly
Maybe it is an electricity problem, or it's nearing the end of it's life. I bought 2 routers till now.each one worked fine for 2 years and then never worked.You should buy a new one or check if there's something with the electricity . Maybe a higher voltage
Anonymous
  • 184 Answers
  • Posted on Aug 29, 2009
SOURCE: WPA enable SMC Barricade
Turn on wireless, then WEP encryption, then add passphrase.
Anonymous
  • 5 Answers
  • Posted on Sep 07, 2009
SOURCE: cannot set up security on wireless router "wireless card nt found
Are you trying to configure the router wirelessly. Connect your computer to the router with a lan cable and then access the router and change its wireless settings. since you cannot change the wireless settings wirelessly as you will get disconnected.
I just set up my SMC WBR14S-N4 Barricade N router yesterday and I think I did something wrong in the initial settings due to the fact that the router can only connect to one wireless device while the other...
change the channel num of the wireless. Log into the router, then go to wireless settings on the top and go to advanced on the left hand side.. changed the frequency channel to channel 6 or 11..
In wireless basic settings, the access policy must be DISABLED.
If still doesn't work, try to change the network name and security mode as OPEN, encrypt WEP and Default key : 1, them type 10 digit num in key 1...
Must work.. All d best..
-- Ali..
Using the SMC100 Barricade as a Wireless Access Point
use the wrt310n router as the router for the internet (where dsl modem is connected) then just connect the ethernet port (not wan port or internet port) of the SMC to the ethernet port of wrt310n
Cant put a lcok on my smc router
Manual for WBR14-G2 router [6.2 MB] in pdf format:
http://www.smc.com/files/AG/MN_SMCWBR14-G2.pdf
Keeping others from connecting to your router:
1. Have an "wired only" router login access or for this router "change and disable your SSID". This way you avoid that others can login to
to the router changing your settings: See page 48 of the manual.
1.1 Wireless Network Name (SSID): change the default name SMC
to "any private name" ( and remember for later login )
1.2 Broadcast Wireless Network Name: change from default ENABLE
to DISABLE .
2. Make a secure wireless encryption key for your connection:
see page 87.
2.1 For most secure key select WPA / WPA2 only and SAVE SETTINGS .
2.2 See page 91 for entering and saving your secure key: the password
that must be entered to get access to the router.
SMC Barricade g SMCWBRT14T-G router
You need to open the port that Utorrent is using check this link for the step by step way on how to do that on the utorrent and on the router http://portforward.com/english/routers/port_forwarding/SMC/WBR14T-G/Utorrent.htm
Hope that helps..............
Intermitent signal strength
It is not unusual for the radio transmitters to fail in wireless routers after a year or two of use, especially if they're used in a location with poor ventilation or dust buildup. "Kaput" is probably a good term for it, but it would be worth finding someone with another laptop to try connecting through your router...just to verify that it's really a problem in the router and not in the wireless adapter in your computer.
1helpful
PS3 and Laptop issues
the new unit you have is the PS3 is not compatible to the SMC barricade router that you had,, you must find a compatible just only for the PS3 unit,, you can ask from authorization wer you bought it!!
Top SMC Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
