432dc scanner how do i scan documents with this machine?
    President:
  • 2,072 Answers
You can't with the DC version of the machine, It has to be an ST version. You have to add what is called an ESS module, and that is quite expensive.
YOu can buy a smaller multifunction machine for less than it would cost to upgrage a DC to a ST.
I am assuming you are asking how to scan to the network or P.C. and or Scan to E-mail.
Posted on Aug 26, 2008
How to clear system error L1:00 on sharp ar-m150 machine
Scanner problem, the scanner is the device under the big class the scans the document. Is set to LOCK, check the op manual. Is it off the rail. raise the document feeder press start should see the scanner and light move as to scan a document if not have a tech look at it.
Nov 18, 2015 | Sharp Office Equipment & Supplies
How do I scan document to my pc
To scan using Windows Fax and Scan
  1. Place a document on the scanner, or, if the scanner has a document feeder, place one or more pages in the feeder. ...
  2. Click the Start button , click All Programs, and then click Windows Fax and Scan.
  3. To use Scan view, at the bottom of the left pane, click Scan
More Help:
How to Scan from Printer to Computer
How to Scan Document in Windows 7
Use your computer to print scan and fax
Mar 02, 2015 | Samsung SCX 4623F - multifunction fax /...
Can you also Fax with this One Touch 8900 ?
This is only a scanner. To Fax, you will need a separate fax machine or fax modem. If both the scanner and fax machine are connected to your computer, you will be able to scan the document and then fax it from the computer. (Depending on your OS/software, this could be easy or take several steps. For Windows Vista and Windows 7, you can use Windows Fax and Scan to do both steps. (However, the program doesn't scan to PDFs.) Paperport will also send a scanned document to an installed fax option. PaperPort is part of the third-party software that came on the CD with the scanner.)
Documentation for the Visioneer OneTouch 8900 is available here: http://support.visioneer.com/products/8900/default.asp .
I hope this helps.
(There are some email-to-fax and web-to-fax options but I have not reviewed them.)
Jul 14, 2011 | Visioneer OneTouch 8900 Flatbed Scanner
I need help scanning a document on my hp photosmart C5200 printer/scanner. I can't find the option in menu to scan and save as document
scan by application.On your computer go to Microsoft word, go to insert then picture, from scanner or camera, choose the type of scanner you are using. Custom insert. The scanner scans your document
Sep 03, 2010 | Office Equipment & Supplies
Will not Scan. Gets message..
Is it installed in windows as a scanner? Dont use scan button on machine try using scanners or document imaging software that needs to be in place on your computer, ie Document imaging in office or scanners and camera in windows, one sends scan signal from the PC, can use the scan button on scanner only when configued to do such. Scanner has software as does the printer both can found at HP web
Nov 07, 2009 | HP Photosmart 3210 Printer
I want to scan documents with my Pixma MP 150
Scanning using the Operation Panel 1. Place the document face-down on the platen glass.
2. Press the [Scan] button on the machine.
MP Navigator starts on the connected computer. You can scan in documents placed on the platen glass using MP Navigator.
Oct 21, 2009 | Canon PIXMA MP150 All-In-One InkJet...
How do I scan a document please?!
you can a document using a scanner.
1. you have to find a SCANNER machine that is responsible in scanning the files you want to scan.
2. Then after you find a scanner, next thing to do is to place the document file in the scanner and make sure that your scanner is properly connected and turn on.
3. Click and run the software that is bundled with the scanner to scan the document and then you have to set the path where your scanned file is to be place.
4. Then after the scanning process finished then click the save button to save the scanned files.
Thanks
Sep 15, 2009 | Office Equipment & Supplies
Cannon MP530 scanner won't scan document it shows error code
hello ! reinstall the machine fax and scanner program cd's may be the installation was not completed or is the machine having issues .
Jul 22, 2009 | Canon PIXMA MP530 All-In-One InkJet...
How do I network my xerox 432 DC printer,scanner, copier does the 432DC support emailing documents after they have been scanned?
A DC version can't be networked. It has to be the ST model.
It can be converted though.
A 432dc is simply a digital copier with no print capabilities.
That has to be a 432 st.
May 07, 2008 | Office Equipment & Supplies
66 people viewed this question
k24674
jasbo
jasbo
