Computers & Internet Logo
Anonymous Posted on Nov 27, 2017
Will the 5-port linksys workgroup work on my ps3? i have been using a wireless linksys for over 5yrs now and i think it finally broken. comcast said that they are seeing and great signal coming from my modem. how can you tell if the router is not working. i mean all the light come on, so i don't kmow what at this point
Brett Duxbury
Level 3:
  • Linksys Master 4,352 Answers
  • Posted on May 07, 2018
Brett Duxbury
Linksys Master
Level 3:
Answers
4352
Questions
0
Helped
1119142
Points
13423
Try down powering your router for 30 seconds and turn it back on.
on a p.c connected to the wi fi. go to the command promt and type in tracert www.fixya.com
and see if the path takes you to your router ip address .
5 Related Answers
Anonymous
  • 113 Answers
  • Posted on Mar 10, 2007
SOURCE: linksys wireless broadband router and wireless access point
Hi I would love to help you with all the resources and knowledge I have, however, this would require online chatting kind of. You either reach me using the live chat feature of Fixya or just add my msn id in your messenger : [email protected]. Whenever I am online, I would assist you. Again, if the above given suggestion is not possible, please give me the following details: 1. exact model no (on the bottom panel) 2. firmware version (if possible) 3. no. of hard wired PCs (directly connect) 4. No of wireless computers 5. ISP 6. any other device connected to the router 7. status of internet on the hard wired PCs 8. status of wireless computers 9. The status of lights on the router (dont forget to specify the labels on top of the lights to make things clearer) thank you
A
Anonymous
  • Posted on Oct 07, 2008
SOURCE: Linksys 5-port Workgroup Hub
OH so thats why my hub isnt working. I need a router
Anonymous
  • 33 Answers
  • Posted on Jan 25, 2009
SOURCE: my linksys wrt54g v8 will not recognize the internet
Try to do a hard reset on the router. Hold down the button on the back of the router for 10 seconds. This will clear all of the settings out of its memory. Then try to connect again. If this doesnt work power down both your router and your cable modem. Let them sit for a minute and then plug in the modem and wait 30 seconds. THen plug in the Wireless router. The issue should resolve itself.
Gary
Anonymous
  • 88 Answers
  • Posted on Feb 13, 2009
SOURCE: Linksys N router drops signal
Its not dropping you because of the spectrums, it works on line of sight. If you are in a basement and your router is upstairs it has to go thru a floor and the strength is weakened. Go into your router and increase the signal strength. But you have to mod your firmware.
http://www.coderetard.com/2008/05/30/install-dd-wrt-firmware-on-linksys-wrt150n-wrt160n-wireless-routers/
Here is a link to update your firmware.
Jim Brauer
  • 50 Answers
  • Posted on Mar 10, 2009
SOURCE: portforwarding on Linksys WAG200G wireless modem/router
Bind the IP address to that port UDP or TCP (or both..your preference) #5060 in the forwarding section of your router. check the box to enable it. Click APPLY or OK or NEXT...wait for changes.
I want to add a LINKSYS workgroup switch EZXS55W behind my wireless routher LINKSYS BEFW11S4 v2 via uplink cable connection. When hardwiring my anything to the switch port 1-4 does not get internet access
Are those 4 ports in different Vlan ?
If you connect your wireless access point to the 1st port are you able to access the internet through 2nd port or 3rd port ?
Are the ports 1-4 admin down ?
How can i use my PS3 and computer at the same time?
plug in your ethernet cables to the 5 port switch
set the ip addess's up too and it should be able to go
on the internet at the same time,
2answers
I play NHL09 online with my PS3. I have Comcast
I think you may find that this will be entirely your isp. do you have a particular broadband cap and have you used it all? have you tried it with any success with any other online multiplayer games? One thing you can try is to hardwire your ps3 to your router and see how you go
Can u help me retrieve my wifi password?
You need to do a factory reset of your wireless router. This should clear the password in it. There is no password for your 5-port switch.
Want to have wireless with my Limksys Sr2016 switch
Go to: www.speedtest.net with a laptop on your network.
Find your speed. now repeat on same laptop plugged directly into the cable madem.
Do the settingsa change much?
If so, your network is at fault. If not, Comcast is lying to you.
2helpful
Cannot share my cable modem connection
You need to connect a router to the cable modem.  The router then gets an IP address from Comcast and provides a gateway between the computers connected to the router.
The modem expects to communicate with a single Ethernet device, and provides an IP address to the first device that provides a piece of data called a MAC address.  By placing a router in-between, the router gets the IP address that lets you communicate on the Internet.  It provides local IP addresses to the equipment connected to the local Ethernet and "routes" those to the Internet.  You can either hook your two devices into the router if it has enough ports, or hook you switch to the router and hook your PC and PS3 into the switch.
PS3: i can obtain ip adress but fail to connect to internet.
I would suggest that first you stop using the first modem. Then plug your computer into the modem and install using the comcast cd that came with your welcome package. If that doesn't work please tell me.
2answers
EZXS55W 5-Port Workgroup Switch
This is a wired network switch your inquiring about. Is this plugged into a wireless router?
If so what brand is the router.
Ps3
Are you going to connect your PS3 wired to your router or wireless?
1. check first if ps3 is working behind rca modem.
2. then connect a pc directly to your linksys router
3. open configuration page of linksys by typing your gateway on your browser. (usually it is by default 192.168.1.1)
4. go to applications and gaming tab
5. you'll find there port forwarding..key in your number there
> i guess your numbers are like 88 and 3764 (something like that)
6. if your trying to connect your playstation wirelessly, you need to know your wireless security (if your router is secured).
> go to wireless tab and look for wireless security
> get your key
7. go back to playstation and try to view your wireless network
> connect and type in your key
3answers
Hi Tman,
Here is a link to the Xbox ports. http://support.microsoft.com/kb/908874
In the firewall option, direct those ports to the IP of your Xbox. I don't have an xbox, but I would think there is someway to set a static IP on it. That way DHCP won't change your xbox ip when you reboot it. Some routers allow you to assign a specific IP to the xbox, but not sure about yours.
Visit this site, http://portforward.com/routers.htm It may have your router, and will tell you how to setup the ports for your xbox step by step.
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
