Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Hotpoint WD640 Washer/Dryer
Please can you tell me whether our washing machine needs a spate feed for the hot water or whether it heats up itself?
Many Thanks
  • hayley4 Aug 26, 2008
    I mean separate feed!!
  • 639 Answers
ngfam1 here for you!
I am happy to be of assistance!
Todays detergents can wash just as good with cold water and save you the expense of heating the water!
Also a dryer gets so hot that all molds viruses and microbes get killed!!!!
Unless you hang the clothes outside instead of the dryer!!
hope this came in handy for you!
If you ever need service in the future!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business! they answer 24/7
Not expensive!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
Posted on Aug 26, 2008
How do I control the temp of wash
make sure the hoses,s r in the rite place or remove the hot hose and let it heat the water from cold if that dosent fix it the thermostat my b faulty
Oct 09, 2014 | Hotpoint Aquarius WD640 Front Load...
Dryer does not work drum rotates but does not dry on hotpoint aquarius washer dryer model wd64. all other functions operate ok
Probably open circuit heater element, or thermostat/s
Remove top cover, and you will see the heater manifold on the top of the drum.
It is a long aluminium box.
The element and stats are located here..
You will need a meter to test the appropiate components for continuity.
Please rate my solution.
Nov 22, 2009 | Hotpoint Aquarius WD640 Front Load...
Hot point aquarius 1100 - does this have a heating element for cold water feed ? or does is need direct hot water feed ? (there is a inlet at back for both hot and cold so presume no heating element ?)
All Hotpoint washers have heater element regardless of whether they are cold fill only, or hot and cold fill.
if 2 connections at rear, then it is hot and cold fill, if only 1 connection, then it is cold fill only.
Jul 24, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Inlet hose leaking a top branch
There are 2 versions of the Hotpoint WD640, a cold fill only version, and a hot and cold fill version..
From your question, I conclude you have the hot and cold fill version, which requires a hot and cold fill supply..
I do not understand what you mean by leaking from top banch, perhaps you can clarify.
Feb 06, 2009 | Hotpoint Aquarius WD640 Front Load...
I have a hotpoint aquarius wd640 my boiler has broke so could you tell me if my washer drier is a hot or cold water fill
Most washers made today, are cold fill only, best way to check is look at rear of washer, and if there is only one hose, then it is cold fill only, if 2 hoses, then hot and cold fill..
So if your boiler is not working, then it should be o/k to use if cold fill only.
Plz rate my solution.
Jan 25, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint WD440 Drawer overflowing
I would check the inlet hose from the bottom of the soap dispenser where it goes into the drum for a soap blockage.
undesolved powder can build up here and prevent the water entering the drum
You can access this hose by removing top cover.
the hose is on the left side front.
This should solve your problem.
Please leave feed back.
Nov 25, 2008 | Hotpoint Aquarius WD640 Front Load...
Fault code on washer/dryer
F05 means pressure jammed on full or pump not draining.If pump o/k, then you will neeed to call an engineer.
Nov 23, 2008 | Hotpoint Aquarius WD640 Front Load...
'test' displayed on washing machine
After pressing different buttons and waiting 10 to 15 seconds after turning the power off, I have finally found the solution.
When you have pressed the "Start/Cancel" button to start your wash programme the LCD shows "test".
You must then press the "Start/Cancel" button which will give you the normal temperature and washing time and then importantly you must depress both the "Start/Cancel" button with the "On/Off" button which will give you a different LCD message and then it will automatically resets itself.
Jul 31, 2008 | Hotpoint Aquarius WD640 Front Load...
Cold feed only
i don't see why not, you only be able to wash in cold water and i hope u have a drain and power in that room.
Dec 03, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
37 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
