Question about RCA 3-Device Universal Remote with Dedicated DVD Menu Key
Won't turn on or off.
We have programmed the component RCR4358 and RCR312W for the Sanyo DVD player. It will play, ff, rew, pause, etc, it will just not turn the dvd player on or off. Can you help? What did I do wrong? Thank you in advance for any help you can give me.
  • Anonymous Dec 13, 2008
    I have the same problem and am still looking for a resolution.
Got a remote for my tv. it is a universal remote , cant get the code for it. my tv is a white westinghouse. it shows 5 different codes for it. could you help me.
Posted on Oct 01, 2008
Roku com support
If you're referring to xfinity router and you're getting error code 014, try to do the following:
On your Roku remote, press the following:
Home button 5x
FF once
PLay/Pause once
Rew once
PLay/Pause once
FF once
It should take your to the platform screen. Check if there's an IP address, a valid Ip address which is not all zeros. Then look for Disable NetWork Ping and press ok on it. Then go back to the Home screen then reconnect to your network.
Mar 22, 2014 | Televison & Video
How to set up my memorex DVD remote to control my magnavox TV?
Sorry to be the bearer of bad news, but according to the manual in the link you posted, and from Google image searching to look closely at the remote, it doesn't appear to be a universal. The only way you can control your TV with it would be via the DVD player hooked into the TV, and then you will still only be able to control the standard functions of the DVD player (i.e. pause/play, stop, FF/Rew, menus, subtitles, etc.) but not the functions of the TV (i.e. volume, channel, power, etc.). Assuming you get yourself a new, actual universal remote to replace this with, I recommend this site in the future: http://www.remotecodelist.com/
Sep 11, 2012 | Memorex Televison & Video
The DVD works fine but the VCR doesn't play, rewind or forward tape.
l would have a look inside to see if when a tape is inserted it loads and will ff and rew, if the transport that moves the tape has failed it will account for what is happening.
Aug 27, 2012 | Zenith XBV442 DVD Player/VCR
Teac A170S won't play, RW, FF, or record.
Hello
Can you hear the motor running, when you press any of the Play, Rew or FF buttons?. Just place your ear very close to the player and listen to it. If the answer is 'yes', the drive belt is broken or slipped off. You have to replace the drive belt. If the answer is 'no' the motor of your device's drive mechanism has damaged, and should be replaced. OK.
WISH YOU A PROSPEROUS 2012.
Gopakumar G, Kerala State, South India.
Dec 25, 2011 | Audio Players & Recorders
Power goes off when a cassette is inserted. Tried cleaning heads but it won't even run that. When power is turned back on the cassette is immediately ejected.
Good day!!!
Most common problems
  • VCR refuses to FF or REW and shuts off.
  • VCR shuts off entering PLAY or REC or at random during PLAY or REC.
  • VCR eats tapes.
  • VCR doesn't accept tapes or ejects them without cause.
  • Sound is wavery, fluctuating, or muddy.
The cause for all of these is very often a bad idler tire or other dirty, worn, or tired rubber parts
Sep 12, 2011 | Philips Magnavox DVD/VCR Dual Player
I dropped my DCRTRV250. It landed on the lense/cover corner. Since then I can not play or get a video picture, just a blue screen. I can hear and feel the motor turning the video tape. In fact all the...
am sorry for you,but probably you will have to go for a qualified tech for this problem i got a idea about what hapen inside the camera when she land down
your ccd as been damage and its come whit the lens ***'y ,that an hours jobs about to fix that
and dont try to do it your self its verry touchy.
Feb 25, 2010 | Video Cameras
I have a Sylvania NB501SL9 blu ray player with no remote. i have dish remote and programmed it for the blu ray , the play ,stop and ff/rew. works fine, but i can't get the arrows to work, therefore i cant...
went ont and plunked down 14$ for a new universal remote. could not get the dish remote to do anything other than stop ,play,ff and rew. which just isnt good enough if you want to browse the blu-ray disk @ all !! so gud luk to all. and Merry Christmas !!!
Dec 01, 2008 | Sylvania NB501SL9 Blu-Ray Player
Rcr4358 and rcr312w remote troubles
lost the codes for the remote and need a list of codes rca remote rcr4125 and also have a rca tv
Aug 25, 2008 | RCA 3-Device Universal Remote with...
Sony Camcorder Hi8 CCD-TRV46E Z00M u/s
Switch Control unit, having Stop, Play, FF, Rew, Pause and Tele-Wide switch at top of camera is cause of this problem. Its ribbon wire has been damaged / cracked, going to camera board. You need to replace that complete part because ribbon wire is not available individualy.
Aug 13, 2008 | Video Cameras
No Instruction Manual
1. Insert a blank DVD disc in the DVD deck and
close the disc tray.
2. Insert the VHS video tape you wish to copy into
the VCR deck.
3. Find the place on the VHS tape from which you
want to start dubbing using the PLAY, FF, REW
and PAUSE functions. For best results, pause
playback at the point from which you want to
record.
4. Press the DUBBING button on the Remote
Control or DUB on the front panel.
The Dubbing menu appears.
5. Use the arrow keys to select the desired Record
Mode: EP, LP, SP or XP.
6. Select [Dubbing] then press ENTER or DUBBING
to start copying.
7. To stop dubbing at any other time, press STOP (x).
Dubbing will stop automatically when the VHS tape ends.
Mar 01, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
RCA 3-Device Universal Remote with Dedicated DVD Menu Key Logo
69 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
