Question about Pioneer VSX-D412 Receiver
Turntable I still own a turntable, "Record Player" :) Where do I plug it into the back of my receiver? Thanks, Russ
You need to connect to the Analog out which is located on the top left of the receiver. If you do not have a Pre-Amp you will not be able to hear the turntable. It is smarter just to purchase a turntable with a built in preamp. they sell for under $100.00. Or if your really smart throw this receiver in the trash and purchase a true two channel receiver with all the necessary rca in's and outs to include a phono plug. These can be had for anywere from $100-$200. This receiver is made more for video and home surround systems than for stereo music systems...
Posted on Feb 20, 2009
    Scholar:
  • 47 Answers
Hi Harpwailer,
I was unable to locate an owner's manual for VSX-D412 on the Pioneer website. I did find a VSX-D411, which I believe is very similar. Since there are no turntable jacks, I would try any set of open analog (RCA cable, like the ones that come out of your turntable and are probably red and white) jacks. Just plug the red cable into the red input jack, and the white into the white. The only thing to be careful of is to make sure that you use the input jacks, since some components (like tape decks) have input and output jacks, so that you can record to/from them.
This will work fine assuming that the output from your turntable is strong enough. Many turntables are designed to go through a pre-amp circuit; if this is the case with yours, you'll know it since the output volume will be very low, even when turned up very high. If this is the case, you'll need to purchase a pre-amp to put in the circuit between your turntable and the receiver, or else buy another turntable that outputs at a higher level (they can still be had rather inexpensively, surprisingly enough!). Also, you'll probably have a ground wire coming out from your turntable as well. You'll need to hook it to a chassis screw on the amp to prevent an electrical hum from being picked up and output through your speakers.
I hope this helps, and good luck listening to your vinyl. If you deem it appropriate, I would appreciate a rating on the help I have provided. Thanks!
Bob
Posted on Oct 16, 2008
I have a Yamaha RV-V450 receiver. Where can I hook up my turntable. I have tried many different options. I can hear very faintly the record playing but only after turning the volume up. I am having trouble...
Turntables generally do not have a strong enough signal to drive an amplifier. You can check on the back of your turntable and see if it has a switch to change from phono to line level. Most do not, but a few will.
If your turntable does not have this switch, you will need to purchase a phono amplifier to boost the signal to standard line level. You can get these on ebay for around $15.
You connect the turntable to the phono amp input and then connect the phono amp output to any of the inputs on the back of your receiver (aux, cd, etc).
NEW BOZAK Phono Preamp Pre Amp Record Player Vinyl LP Album Amplifier eBay
Dec 30, 2017 | Yamaha Audio Players & Recorders
Shaky sounding records
Some things to check:-
Is anything preventing the turntable from rotating smoothly, this would cause a judder.
Perhaps the records are sliding on the turntable, a rubber mat will cure this.
Ensure the record player is on a level surface.
Dec 27, 2013 | Crosley Cr704 Turntable Am/fm Radio Record...
I have a brand new emerson 3 speed record player, amfm radio, cd player combo. I am having trouble with the turntable rubbing even after we tighten the shipping screw down
Shipping screws are used the hold down the turntable during shipping.
These shipping screws need to be removed after shipping and installation.
Nov 19, 2012 | Emerson 3 Speed Vinil Classic Lp Turntable...
I have vestax 05pro2. Left channel works but out of one speaker. The turntable input is good. Im thinking Its either the channel fader, or the rca inputs for that side. Has anyone had this problem?
Here's a solution to see if you have a problem with either your receiver or turntable.
The turntable has 2 RCA's one red for right channel, and one white or black for left channel, which plug into the back of the amplifier.
  • Unplug both RCA from rear of amplifier.
  • Plug in a cd or dvd player into those inputs on the amplifier, the sound will be lower but it will give you an indication if the amplifier is ok or not.
  • If you have sound on both channels left and right then the amplifier is good
  • If you still only have sound on left channel, then there is a problem with the right channel input on the amp.
  • If your amp, is good, unplug the cd /dvd player.
  • Put a record on and start playing the record
  • Plug the white or black RCA from the turntable into the rear of the amplifier marked left, you should have sound.
  • now unplug it from the left and plug in into the right red RCA socket, if you have sound the amplifier is working fine.
  • if there is no sound there may be a problem with the stylus cartridge on the turntable
  • now lets reverse the test
  • unplug both RCA from amp.
  • Plug the red RCA into the left socket on amplifier, if there is sound, turntable is working fine, if no sound there is a problem with either the stylus cartridge or that red RCA cable.
  • now unplug the red RCA from the left side and plug it into the right side socket
  • if there is no sound there may be a problem with the stylus cartridge or RCA cable.
I hope this helps
MobileJB
Jul 15, 2011 | Audio Players & Recorders
I have a Technics Double Cassette Deck RS-TR212. On the rear it has Output and Input connections. Output goes off to the Amplifier. Can the Input be used to record or play from a record Turntable? I have...
your receiver has (or should have) input and output connections,, your turntable needs to be hooked to the receiver,, then with the output cables that feed your cassette player you need to go, in to out and out to in ( receiver output to the input of the tape player, and out of the tape player to the in on the receiver, while playing a record if you hit record on the tape player it will record the record, depending on the receiver it will show you the meter readings for either the in or out,, they vary
Apr 11, 2011 | Audio Players & Recorders
I expected that the RCA leads from my turntable would just plug into the back of the RCD-W500C, but the manual indicates a somewhat complex cabling arrangement through the amplifier. I have not been able...
Your new cd player/recorder is a "component piece" as is your turntable,cassette player, reel to reel or CD player. Connect it as you would any other component piece of stereo equipment. Set up your recorder to "record" in real time(not high speed or synch record). Your tape recorder records anything that is playing through your reciever to your speakers. So, treat your "CD" recorder as you would a "CASSETTE TAPE" recorder. Play your vinyl record on your turntable and record to CD on your CD recorder ! Pay special attention to the dubbing speed, you will not use "synch or high speed !! Good Luck
Feb 26, 2011 | Audio Players & Recorders
I need to connect to a Marantz SR-19 a record player How do i do it
On the back of the receiver there are connections, usually record player should be hooked up on Phono slot. If Phono is not available, trying using Aux or another slot that isn't being used. After hooking it up, remember the place you hooked it up, turn on the turntable, play a record, then hit the button on the receiver where the turntable is hooked up.
Sep 20, 2010 | Marantz SR-19 Receiver
Stanton Turntable Problem with receiver/audio
You need a turntable pre-amp, or a receiver with turntable inputs.. The turntable is functioning properly, until recently no turntable had this built-in. Search ebay for turntable pre-amp and you should be good.
Oct 04, 2009 | Audio Players & Recorders
My record player works but makes an aweful noise like the turntable in rubbing up against somethin
If it is a loud hum besure there is a ground wire connected to the back of the receiver from the turntable.
Apr 24, 2009 | Audio Players & Recorders
Connecting a Technics SL-BD20D turntable to a Yamaha RX-V463 Rece
After further research, I learned that I need to plug the turntable into a preamp before plugging it into my newer receiver. As with cassettes, record players are fading away. I ordered a preamp, but won't be able to experience success until it arrives.
Jan 16, 2009 | Yamaha RX-V463 Receiver
Pioneer VSX-D412 Receiver Logo
310 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
