Question about Casio Cassiopeia EM-500 Pocket PC
Is it possible to sync with Outlook from miles away?
've got to buy a PDA for my boss (which is not much "computer fan"...) the only wish he has is : "when I'm travelling, I need to synchronize an agenda with the Outlook of my computer in the factory" factory doesn't have ADSL and my boss's computer can reach the net via a LAN workgroup and RNIS (it can reach but it can't be reached... 8o/ and my boss already have a Nokia phone he wants to keep. So, the questions are : => is it possible ? => how ? => and wich PDA(s) ? by the way... I still haven't chose between Palm and PocketPC, so don't hesitate to tell me why you prefere PocketPC... ; o ) thanks evrybody..
    Master:
  • 551 Answers
Yes it is, But I think it's difficult to run. I found out this. "Gateway public IP Adres Lan Adres Host (vast IP adres, dus geen DHCP) Poort setting VPN en Firewall (hard en software settings !) Type router, bv 3Com 3CR856-95 (Secure Gateway) en eventueel firmware releases. (ivm Firewall opties)." This is what a friend of me uses to acces his pc with his communicator, yes I know it's a symbian os device, but I think it should be possible with any device... ?not? It reads that you should run a Bitween's Remote Control application an fill in this fields in this protocol an you can "Hack"into your own system an with this tool can sync. So it can be done but how exacly I couldn't find out.... Sorry. Good luck figuring out how!
Posted on Sep 05, 2005
My boss wants his Microsoft 2007 Outlook Calendar on his Iphone.
http://support.apple.com/kb/TS1347
i googled your question and found the apple page. in case it doesn't load or is blocked, run the setup wizard for outlook first, then sync after because outlook will not sync unless it has made the file first
Jul 02, 2009 | Computers & Internet
Serious Issue re ActiveSync 4.5, HTC Touch, WM6
pls tell me what do u want to do with active sync bcoz this small piece of software gives lot of trouble in winxp , vista WMDC works ok , i know u are frustrated with microsoft support infact support one some issues does not even exist at all , this problem is not from ur PDA it is from this malfunc software that is called active sync , pls let me know if u use active sync to backup ur contacts then u can do it with SPB backup better than active sync without errors u can losd it it to ur pda and can make backups from ur pda not pc dependent at all
pls let me know abt ur usage of this software
pls rate me if u find me helping
Mar 09, 2009 | Computers & Internet
Outlook and Iphone syncing
Yes you will be able to sync MS outlook.
For more information ask me
Thank you, Apple Care Technical Support
Jul 04, 2008 | Apple iPhone Smartphone
Active Sync Installation not recognizing Outlook on PDA
Remove the Activesync software...reinstall it.
Thats the best and fastest suggestion I can give you.
I have the same problem off and on.
Nov 21, 2007 | HP iPAQ rx5915
SPV M3100 - sync problems
Pleset let me know that are you using MIcrosoft Active Synk...if not you can download the this form http://www.microsoft.com/windowsmobile/activesync/registration.mspx with the help of this Active synk you can explore your PDA from your computer.
i hope this would help you
wish you luck
Was this solution helpful? Show your Appreciation by rating it:
Oct 11, 2007 | Orange SPV M1000
Email forwarding
You can only sync your inbox through Activesync with Outlook not Outlook express. There is a full version of Outlook on the CD that came with the Axim. You should be able to move your data from OE into Outlook.
Sep 19, 2005 | Dell Axim X3 Pocket PC
Sync problem
I assume you use activesync. Check in the options that it is set to synchronise this data. if you have already done this try reinstalling activesync or installing the newest version, 4.0.
Sep 15, 2005 | Dell Axim X3 Pocket PC
Sync problem
I am assuming you use activesync. Check in the options that it is set to synchronise this data. If you have already done this try reinstalling activesync or installing the newest version, 4.0.
Sync Doubling Calendar & Contacts in Outlook 2002
your t5 is UNSTABLE possibly due syncing to an old username from an old PDA. To correct this: -delete manually the doubles (PDS has a tool but none for outlook) -perform hard reset on your t5 -hotsync - creating a new user name (do not use the old one) -you will be asked to use the same profile name for the outlook Then you should be good to go.
Sep 12, 2005 | Palm Tungsten T5 - Multilingual Handheld
Does the ipaq 2215 work with Outlook 2002?
Active Sync will work with many version of outlook. Your PDA interfaces with Active Sync. Certain versions of Windows Mobile software and/or PDA's require higher versions of active sync to sync correctly.
Sep 12, 2005 | HP iPAQ H2215 Pocket PC
Casio Cassiopeia EM-500 Pocket PC Logo
177 people viewed this question
Top Casio Computers & Internet Experts
k24674
jackcity
jackcity
Level 1 Expert
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
