Question about Casio Cassiopeia EM-500 Pocket PC
EM-500 music transfer
I need help figuring out how to put music onto my PDA. I'm totally clueless, someone help! sorry if this has been asked before!
    Master:
  • 551 Answers
When I bought my Casio EM 500 it came with an application to manage media files on the PPC. It run on your desktop pc and will convert mp3's to wma and then copy them to the ppc . This means that as wma files are roughly half the size of mp3's you will get a lot more music per mb of storage space ! As the previous post says you have got to get a SD or MMC card to store any signifcant amout of music
Posted on Sep 05, 2005
    Master:
  • 551 Answers
Seeing that you are using a EM500 with only 16mb of RAM, you might want to get a SD/MMC Card. With that being said, let's do this, shall we? Connect your PPC to your desktop using ActiveSync, then press on the TAB "Explore" then "My Pocket PC". You are interest in the "My Documents" folder, that is where you will place your .WMA, MP3, OGG files. Just copy the music file from your desktop that you want on your PPC, and then paste it to the "My Documents" folder of your PPC. Now if you have a storage card (MMC/SD), you will have to create a folder on the storage card and name it to "My Documents". So you will then have 2 My Documents folders, one on storage card, and 1 on the PPC. If you want the Music file on the storage card to save space on your PPC, then do the following. Connect the PPC to your desktop using activesync, then press on the TAB "Explore" then "My Pocket PC". You then need to click on the "Storage Card" folder, there you will see your "My Documents" folder you created. Just copy the music file from your desktop that you want on your PPC, then paste it to that folder. To speed things up, you can also use a MMC/SD Reader. you can then copy and paste directly on the memory card, without going thru ActiveSync. Goodluck, and have fun!
SOURCE:
Putting music onto phone
i can guide you through the prossess of connecting it through a usb cable, and can suggest other options that will enable you to get music onto your phone if this fails.
You cannot put music strait onto youe phone from the cd first it needs to be ripped onto your computer, and converted into an mp3 file so that the phone can play this. if you cannot do this, then reply to this solution, or post it as another question.
USB Cable Link
  1. turn on your phone and pc and plug the cable into both
  2. look on the phone screen to see if it is asking anything. if it asks what mode you wish to use, choose FILE TRANSFER.
  3. depending on your computor different things may happen, but it should install automatically.
  4. once this is done, your phone will act and appear on your computor the same a memory stick would.
  5. to add music (or any other type of file) just got to my computor, double click on your phone, go to the music file, and simply paste the music you have ripped from your cd there
if you have any questions or trouble will this contact me on my account
please take the time to rate this solution thanks :)
Aug 30, 2009 | Sony Ericsson W200i Cellular Phone
Tip
Put music on SD card
1. Start Real Player on desktop
2. Hook PDA to PC
3. Run Real Player on PDA
4. In menu below player select burn/transfer
5. Select Music/All Music
6. Select songs to transfer over
Incidentally you can select mutpile songs at one time if you wish if they are all in a row
7. On the right side the songs will show up
8. Don't worry about "Will Not Fit" this only means desktop real player can't see your PDA or your card isn't plugged in all the way. Make sure it is B4 you begin
9. The songs will show on the right "Ready To Transfer"
10. Once you are done, lower left click START TRANSFER
on Jan 02, 2009 | Palm Tungsten E2 Handheld
Have songs from I tunes, need to transfer to a new I pod.How do we do this?
You should be able to drag the songs from iTunes to your iPod (as long as Manually Manage Music is checkmarked). It will then pop up a dialogue box asking if you would like to authorize. Select yes, type in your apple login info (that you use for iTunes) and voila. Success.
If you are trying to get songs off one iPod and onto another -- you can transfer your entire music library from your iPod to your computer, then use them to populate your library. Then put library on new ipod. All you have to do is enable showing of hidden files and folders (on both mac and pc). The folders titled 00 to 49 will have all your music in random letter names. You'll find em :)
Jul 12, 2009 | Apple iTunes
PIM ino lost from ipaq 1950
did a hard reset. booted up ok. did activesync with my other PDA onto computer and then sync'ed with 1950.
Dec 01, 2008 | HP iPAQ rx1950 Pocket PC
My apple iPod will not show up on itunes and i can't turn it on HELP!!!!
Sorry if I'm too obvious, but are you using iTunes?
Yes? Then check your iPod settings on iTunes:
If you want to just drag songs to the iPod you have to set it to "manually manage music" on the iPod "Summary" screen.
Otherwise you need to create playlists in iTunes and synchronise your iPod to those playlists (tick them in the "Music" tab.
Of course, if you already knew all this, sorry! Maybe you have a usb port problem (try restarting computer) or an iPod problem (try resetting your iPod). NOTE: with iPods, you MUST use iTunes to transfer music to iPod, and it is NOT possible to transfer music FROM you ipod TO your computer (say you've loaded songs from someone elses computer to your iPod and you want to put them onto your computer - no can do! Use a flash drive).
Jan 27, 2008 | Apple iPod nano
Music on SD Cards
you should give up uploading music to your PDA and start to creat your own... Try Griff - I can't put mine down!!!
Sep 11, 2005 | Toshiba e400 Pocket PC
Casio em-500 deleting mail programs!!!
I believe they are in unit's ROM, which is non-reprogrammable. Hence, you won't be able to delete anything from there. On the positive side, they don't occupy your main memory, so there's really no harm in letting them dwell in your PDA. :)
Sep 06, 2005 | Casio Cassiopeia EM-500 Pocket PC
Casio EM 500 + Nokia 7650
well there is a solution but im not too sure, but it is to get a cable that conects to ur phone and ur pda..that should work it not....there may be something wrong
Can't delete a program EM-500
If all else fails... Just do a hard reset...you know, hold down the power button and pust the reset button in the hole on the back side of the casio....of course you will loose everything you've installed and will have to reinstall, but sometimes that seems to be the simlest way.
128meg MMC for Casio Em-500
Did you put your mp3 files in the my documents folder on the mmc? because if you place it anywhere else other than my documents the won't play (thanks microsoft). Also, the mp3 files might need conversion in order to actually play. It happend to me also, the files on the mmc would play on my siemens sl45 phone but on the em-500 not, until i use the sl45 connected to my computer to transfer files to the mmc than play with em-500.
Sep 05, 2005 | Casio Cassiopeia EM-500 Pocket PC
Casio Cassiopeia EM-500 Pocket PC Logo
119 people viewed this question
Top Casio Computers & Internet Experts
k24674
Joseph Hoffmann
Joaquim Martins
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
