Condensing unit willnot turn off - Heating & Cooling
  • buttons336 Aug 27, 2008
    Power is there on contactor, coil voltage and high voltage??
First check for power, to the contactor ,if no power then backtrack for power, If got power and nothing happens, the its the capicator out due to power surge, see if the capacitor is bulged on the top or bottom! Thank-you-very-much!
Posted on Aug 27, 2008
Our dehumidifier is about 2 years old. It turns on and sounds fine, but it no longer condenses any moisture from the air. Does the refridgerant need rechargeing?
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 13, 2011 | LG LHD45EL Dehumidifier
The fan runs, but no water condenses. It seems like the condensor does not run. Is this death to the unit?
heatman101
Jul 08, 2011 | Whirlpool AD50USS Dehumidifier
Unit not getting cold enough to condense Poss low refrigerant .. I don't see charging port
heatman101
May 25, 2011 | Whirlpool Dehumidifiers
The compresser keeps turning on and off without and condensation Is it worth trying to fix, or should I just buy a new one
Hi, You will probably be money ahead to buy a new one...
heatman101
May 17, 2011 | Maytag M3DH30B2A Dehumidifier
I unpluged my fridg about 3 months ago now i pluged it back in and it willnot cool
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 27, 2011 | Kenmore Refrigerators
HDN455 worked fine last fall. Turned off for winter. Started this week. Sounds and runs fine but not a drop of water condenses. Coils are not frosted over. Unit is warm along bottom. Air discharge is at...
heatman101
Feb 19, 2011 | Haier HDN455 Dehumidifier
Turn indicators quit working ,both sides ,all at once. changed turning flasher square underdash unit still willnot work 1989 chevy 1500 v-8
check for a feed to flasher unit if no feed try changing the hazard warning light switch they are interconnected
Jan 05, 2011 | Chevrolet C1500 Cars & Trucks
Refrigerator willnot cool and ice is melting
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Sep 29, 2010 | Refrigerators
Everytime my central air unit kicks on my circuit breaker trips. It didn't do this last year or even earlier this year
A circuit breaker 'tripping' everytime the AC unit kicks on 'most always' indicates a direct short (somewhere in the condensing unit), although it is possible that the breaker itself is bad - (but not likely).
Usually the cause of this 'short' will be - either the condenser motor in the condensing unit (outside unit) or the compressor - also in the condensing unit.
If you're mechanically inclined - and "very careful" around electricity - there is a fairly simple way to find out which component is causing the short.
Step 1 - Make sure the condensing unit (outside unit) is completely disconnected (electrically) , i.e. pull the fuses/turn off circuit breaker on outside unit and turn off thermostat.
Step 2 - disconnect the condenser motor (this is the outside fan motor). Note: when you disconnect the wires of the condenser motor "be sure" you mark/write their location, and wrap them in electric tape.
Step 3 - start the AC unit. If the breaker trips again you can pretty much rest assured it's the compressor that is shorted.
To prove it (without a doubt) - go to next step.
Step 4 - "be sure circuit breaker and thermostat is turned off" - and - 'reconnect' the condenser motor - and - then disconnect the compressor wires (mark wires and tape them).
Step 5 - Start AC.
If breaker doesn't trip - you know it's the compressor that is shorted.
If breaker 'does' trip again - then it's possible the breaker itself is bad (not likely) or there is a 'short' in the condensing unit's "wiring" somewhere (not likely).
My guess is that either the condenser motor or compressor is shorted.
Hope this helps.
Good Luck!
Jun 10, 2010 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
