Question about Parks Optical 13.5hp Briggs And Stratton Intek Lawn Mower Engine
I need a wiring diagram for a 13.5 hp briggs and stratton motor. It is replacing a 12.5 hp B&S. There is a fuel solenoid on the new motor. I have purchased a Murray idnition switch which can handle a fuel solenoid but there is also no wiring instructions with it. Murray 421064MA Ignition Switch
  • vanheurck Jul 12, 2011
    Sorry but I couldn't read the diagram. I tried to enlarge it but writing became more blurry. Could you post it as a bigger file?
    Thanks.
  • 24 Answers
This wiring diagram is from a 15HP but it should be the same as your engine.
Posted on Jul 12, 2011
How do I refit linkages and springs and in what order on unidentified lawn mower?
Linkage & Spring replacement on a Briggs & Stratton ...
? 7:13
https://www.youtube.com/watch?v=8atnwA4D5lM
Jun 26, 2010 - Uploaded by paisteboy
In this video I replace the two spings at the linkage on the carburetor of my Murray Lawn Mower that has a ...
4 HP Briggs & Stratton Quatro Motor Spring & Linkage Close ...
Nov 24, 2015 | Garden
13 HP briggs and stratton intek motor on a pull behind weekend warrior brush cutter
Manuals - Briggs & Stratton
https://www.briggsandstratton.com/us/en/.../manuals
Briggs & StrattonFind Briggs & Stratton manuals online by selecting your lawn mower or product type &engine model number. Never worry about losing an owners manual ...
Sep 10, 2015 | Measuring Tools & Sensors
Bownes lawn tractor wont turn over. Battery fully charged and all safety switches were changed. its a briggs and stratton 12 1/2 horsepower
with a volt meter set to DC, pull the wires off of the starter solenoid coil (the small wires) and check for 8 - 12 volts DC at the wires when the key is turned. A poor connection at the solenoid coil will cause slow turning engine cranking or none at all.
If you have 8 - 12 volts there check for voltage to ground on the large cable that goes from the solenoid to the starter motor, one probe on the cable and the other on ground or ( - ) at the battery. Turn the key to start, if you have voltage to the starter motor but it does not turn loosen and retighten the mounting bolts to the starter motor and if that does not help do the same for the engine to ensure you have a good ground. If none of that works your starter motor needs to be replaced, if you have no voltage to the motor the solenoid or battery connections are faulty.
You can also quickly test starter health by conecting a set of jumper cables to a good battery, clamp the neg. to the engine block anywhere and tap the pos. to the starter cable connection from the starter solenoid, if the engine spins over your starter is healthy and the issue is certainly between the key switch and the starter solenoid.
Jul 07, 2014 | Briggs & Stratton Briggs Stratton Intek V...
B&S 17 hp single it only turns over til it hits compression.. good battery,starter turns over another motor ,ground wire,whats up!
The connections on the starter solenoid coil are poor. this is the two smaller wires on the solenoid but all of the wires should be removed and cleaned well at least once a year or more often if conditions warrant.
Jun 16, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Have 303447 briggs 16 hp only fires one cylinder
Have you also changed the spark plug too. The ignition circuit is pretty simple, from the battery, the Coil is energized, the "points" or equivalent, through the "Distributor" or equivalent, and onto the Spark Plug. So it is a simple matter to work along the path, proving the "Integrity" at each, point by testing. IF it still doesn't fire after ensuring all Leads are OK, the Spark Plugs are proven OK, the Cables, the Points, & Distributor, . IT is either that or the Ignition Timing is OFF. Please check all those points.
Apr 23, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs & Stratton wiring, can it handle an electric clutch?
You might have a capacitor in line with the clutch motor that requires feed from the engine to allow the clutch to engage. I think the red lead is charging current to the battery plus post. Get yourself a 270962 repair manual and it will show you how to wire these things.
Apr 13, 2010 | Garden
Changing motors
i think what you are describing is the fuel shut off solenoid. i am not sure how it wires up but the workaround i have used is to replace the carb with an older model,same approx engine. they dont retool the blocks. find an older model 12 1/2 horse without them you should be fine.the wires if i remember right is gray and black from the solenoid
Jul 22, 2009 | Briggs & Stratton Garden
Craftsman 19.5 briggs & stratton mower new battery, new solenoid new brushes on starter. fuse & wiring good shape. when i attemp to start ignition all it does is click.
Check the voltage on the battery to see if it is 12 volts or higher. If not, charge battery.
Then check all starting-related electrical connections-- sounds like there is a dirty connection somewhere if the battery is charged.
May 03, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Parks Optical 13.5hp Briggs And Stratton Intek Lawn Mower Engine Logo
8,367 people viewed this question
Top Parks Optical Garden Experts
Renee Knafel-Bullock
Steve Allison
Steve Allison
Jim Parker
Jim Parker
Are you a Parks Optical Garden Expert? Answer questions, earn points and help others
