Question about Engel MT-35F-U1 34 Qt Portable Refrigerator & Freezer
Follow up on engel mt27f
Ihad already checked that far. Finally got the circuit boards out of case and found the burnt part it is L4 on the power source board. What is it and can it be changed or repaired or shorted over?
  • 2,322 Answers
L4 is an inductor and is use as protection in this case. I would suggest to bypass it just to test the appliance but that part should be there if you're planning to use the 12V.
I've searched for an schematic but not able to locate one. Call the manufacturers and ask if they could send you the schematics.
Posted on Aug 26, 2008
Mt27f-u1 12v not working
Try tracing the wires from the 12 volts plug to the other end of the wires. You might find a broken conductor or a blown fuse in there.
Aug 26, 2008 | Engel MT-35F-U1 34 Qt Portable...
LG LED TV no sound or pictures
If you have already been inside of the back circuit board area, make sure that you don't use any type of magnetic screw drivers or any thing that can statically discharge a capacitor etc. Next since you say there are 3 boards present,the board, you are looking for is the power board.How to identify the correct one, follow the AC cord from the plug into the board that it first attaches to.That is the power board.Carefully disconnect any 6 pin or any multi pin connector and mark them for re assembly.There should be 6-8 screws that are removed then remove board.Have a very bright light on hand and carefully examine the board for any broken circuits or burnt components.If found ,go online and search eBay Amazon etc. For replacement board. Assembly is reversed order of removal.
May 19, 2016 | LG Televison & Video
So I found out I need a circuit board for my panasonic sa-ht80.where can i get one from I tried everything. Please help
Guess you already tried ebay and the manufacturer.. But just keep checking because sooner or later it will appear. Today they had the entire receiver.
Did you check out the questionable circuit board for bad caps that are bulging or leaking? Burnt resistors? Diodes? U might get lucky.
U have nothing to lose and all to gain at this juncture.
Sep 16, 2015 | Panasonic Audio Players & Recorders
No power - samsung model mfsui80ncc-t2
i have a samsung washing machine model wa91u3 no power supply. i check electronic board totally burn. board model mfsui80ncc-t2. please help me to buy sparepart. I need to change new electronic board.
Oct 09, 2012 | Washing Machines
I've opened the back of the amp case and see no visual problems or obviously burned components, there are no burnt smells and I really just need this exact amp working again as I have a custom rack and...
follow the power circuit on the board if it is burnt up u will see solder a wire from where it is burnt up it will work as a jumper understand? if it is not burnt u have a connection problem
Feb 13, 2011 | Car Audio & Video
The buttons on my Whirlpool dishwasher have gone haywire and have a mind of their own. I can't push a button to start the dishwasher
Hi!!
Try disconnecting the power cord for 5 min. to see if the unit will reset itself. If that does not work, disconnect the power cord and remove the inside panel behind the control board to check the circuit board for burnt marks or smell. If found defective, click on the following link to ID and order the correct part. http://www.repairclinic.com/Circuit-Board-Or-Timer-Parts?s=t-GU3600XTS-%3d%3dec13
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Dec 02, 2010 | Whirlpool GU3600XTS Dishwasher
Part number: 316809100002-R02
I too have the same power board burnt out ... did anyone ever find the part you was looking for ... Thanks
Nov 20, 2008 | Computers & Internet
RCA F20632SE 20" TV
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jun 01, 2017 | RCA F20632SE 20" TV
Engel MT-35F-U1 34 Qt Portable Refrigerator & Freezer Logo
267 people viewed this question
Top Engel Refrigerators Experts
Jaime Hernandez
christian nielsen
cwradio73
Are you an Engel Refrigerator Expert? Answer questions, earn points and help others
