I am probably doing something wrong. I want to use a DVD RW to store data but it seems the MS Media center is all I have. Is there a way to use these types of removable storage like a CD-RW? Could I need another program? I would like to go to Windows Explorer and be able to open a file stored on a DVD RW. I have a Philips DVD -RW SDVD8441 drive in a Gateway MX6455 laptop. Thanks in advance for you help!
  • cbhome Aug 28, 2008
    The suggestion to use Nero appears to work out. Of course, I have a lot to learn about the ins and oust of the program. Initially I was able to store some data and remove it from my hard drive which was the primary aim. Thanks C B Bonham
    Master:
  • 521 Answers
Yes you need another program.
Posted on Aug 26, 2008
  • tech expert12 Aug 26, 2008
    I am going to walk you through burning a DVD rewritable today. After inserting the DVD into your system and choosing open finder as your default action, you will see an icon on your desktop for the DVD. The DVD rewritable holds much more space than regular CD writable or CD rewritable disks. DVDRW holds 4.7 gigabytes of information and it is great for burning home movies and backing up your system. The advantage to a rewritable disk is that it allows you to constantly update the information and the contents on your disk as well as you can burn your disk for one time use and then completely write over whatever you had on there before and to format a rewritable DVD after you burned content. Open your finder window for your hard drive and click on the application. From here you can access the utilities folder which has a lot of useful system utilities including the disk utility. The disk utility will show you your DVD and your list of media and clicking on that brings up a lot of different options. One of those is erase and you can use the erase option to quickly and safely remove all the information from your DVD rewritable media
    go to this link for more help with proper step by step directions.
    http://www.computing.net/answers/windows...
    pls do rate the solution
    thanks.
    regards.
    fixya expert team
  • 928 Answers
You can use programs like Nero to burn data onto a disc such as a CD-RW. Since you already have a DVD burner you can even use a DVD-RW to burn your data
My dvd-rw file is corrupt at a certain point how do i fix it
Sometimes these disks reach the end of their life after a couple of uses and can no longer erase/write. CDs and DVDs have a shelf life of about 10 years, but sometimes data can be lost in as little as 2 years. CDs and DVDs are best for storing music and video, where loss of data bits is not noticable. Back up critical data files in several media types (Hard disk, CD, DVD, Flash drive) to prevent loss.
Oct 26, 2013 | Optorite DVD+-RW DUAL TED80Y BLK RT...
What is the difference between dvd-r and dvd+r
Most of the time you can find this out by looking at the drawer front of your drive it will say something Like DVD+RW or -RW to let you know the difference, if it says MULTI Recorder or has DVD/+-RW it uses both.
If the drawer does not say something, then your best bet would be to open the control panel and device manager, click on the dvd drive and find the model of it and google it for specs and you can find that way.
Jan 05, 2013 | Sony Mini DVD-RW 1.4GB 30 minute ( 8cm - 3...
What is the difference between a DVD+RW and a DVD-RW.
DVD-RW
It is the re-recordable version of the DVD-R. To use this type of media you will need to buy a DVD-RW recorder. The DVD-RW recorders usually record DVD-R, CD-R and CD-RW media, too. Similarly to what happens to DVD-R, DVD-RW disks can be played in newer commercial DVD players without any problems. Older commercial devices cannot recognize the media, refusing to play the disk. To play a DVD-RW disk, commercial players need the disk to be finished. After finishing the disk, you can only record new data in it by reformatting it, which makes you lose all the recorded data.
DVD+RW
It is the re-recordable version of the DVD+R and everything that was said about the DVD+R is valid for the DVD+RW. Only the newest DVD players play movies recorded in disks using this format. There are recorders on the market that can record both DVD-RW disks and DVD+RW ones. These recorders are called DVD?±RW. Similarly to the DVD-RW, the disk needs to be finished to be played in commercial DVD players, and to record new data in the disk after having finished it requires reformatting it, which makes all the data in it to be erased. DVD+RW recorders are usually capable of reading DVD-RW disks (but not of recording them) and vice-versa.
There you are.
Aug 22, 2011 | Acer Computers & Internet
I have a Compaq SR1650NX (Windows XP Media Center with MS Office 2003) computer. My DVD+RW will not open. I can open it manually but my computer does not recognize the DVD. If I change out the DVD+RW,...
There is nothing wrong if you want to replace it with generic or branded DVDrom drive. As long as compatible with your motherboard. If you are using IDE or UDMA cable you must buy IDE DVDrom drive but if it's SATA cable you have to buy SATA DVDrom drive.Good Luck
Nov 26, 2010 | Computers & Internet
What type of CDs should I purchase to use with my Sony DVD RW AW-G540A ATA device to write/play video?
Most CDs should work. If you are looking for high quality (least error rate) media, use Taiyo Yuden media, they seem to be one of the best. Verbatim and Ritek are some lesser, but also good brands. If your burner won't work with most CDs, there is likely something wrong with it.
Sep 27, 2010 | Mad Dog Multimedia (md-52xcdex) CD-RW...
I just purchsed a hp 873n pc tower is that wifi ready
No, according to the data below. You can buy a PCI wifi card or a wifi usb from Frys or even Walmart.
Take care WBTech Product Details Discover the ultimate in entertainment with new power and convenience of the HP Media Center PC 873n. Watch or record your favorite TV programs - even pause live TV, instantly replay or skip commercials. Create a slideshow of your family photos, add music and set it to play on your PC during a holiday party. Save your original videos, photos, music or data on DVD+RW/+R or CD-RW discs. Specifications Key Features Operating System Microsoft Windows XP Media Center Edition Form Factor Tower Processor Intel Pentium 4 2.53 GHz Installed Memory 512 MB (DDR SDRAM) Recommended Use Home Use Processor Processor Type Intel Pentium 4 Processor Speed 2.53 GHz Processor Manufacturer Intel Max Processors Qty. 1 Motherboard Bus Speed 533 MHz Video Output Interface AGP 4x Memory RAM Technology DDR SDRAM Installed RAM 512 MB Installed Cache Memory 512 KB Max Supported RAM 2 GB Installed Video Memory 64 MB Hard Drive Hard Drive Capacity 120 GB CD / DVD Optical Drive Type DVD+RW Optical Drive Read Speed 2x (DVD) · 32x (CD) · 8x (DVD) Optical Drive Write Speed 12x (CD-R) Optical Drive ReWrite Speed 10x (CD-RW) · 2.4x (DVD+RW) Other Drives Floppy Drive 3.5" 1.44 MB floppy Audio / Video Audio Output Type Sound Card Video Input Type TV Tuner Modem Modem Type Fax / Modem Networking Data Link Protocol Ethernet · Fast Ethernet Networking Type Network Adapter Dimensions Depth 15.52 in. Height 15.25 in. Width 8.27 in. Weight 35.06 lb. Warranty Warranty 1 Year
Jan 21, 2010 | HP Media Center PC 873n (P9875A#ABA) PC...
Want to make backup disc for my laptop & can't find a single person who can tell me what disc to use - please help. Do i use DVD R or DVD-R. Everyone seems to tell me that i can use either, but there's...
You can use DVD - or + media, it doesn't matter which. When recordable DVD's were just emerging, DVD - was used more for video and + for data for compatability reasons. In this day and age, 99.99% of DVD recorders are compatable with both. There is no benefit or drawback to using either. Keep in mind R media is recordable once while RW media can be erased and re-recorded.
One thing to keep an aya on is the dual layer thing. If you use a dual-layer disc you will need a burner that supports dual-layer and a reader (if need be) that supports dual-layer discs. Most newer DVD recorders and readers will work with dual-layer discs. The benefit to dual-layer is storing around 9 gigabyte of data verses storing around 4 gigabytes on a regular DVD.
Here is another suggestion for backups. Want to create your own backup Restore CDs? This is useful if you don't want to re-install and re-configure anything. If the computer goes down, just put in the discs and it will be just like you never left it when you created the backups. For this, you would need to use a product called Symantec Ghost. It is a part of the Symantec's Norton SystemWorks or something similar to that. I've used Ghost on hundreds of cases.
Hope this helps!
Oct 17, 2008 | Computers & Internet
DVD RW reading problem
Ok it seems as if the drive may be dying or is dead. You said you used these disc before so the problem is with the media(disc) its with the medium*the drive) I dont think flashing the firware in this case will hely you will need to replace the drive :)
Dec 11, 2007 | LaCie d2 DVD-RW Burner
Stopped burning
Its the burner... You'll need to replace it. you sound as if you know what you are doing so i doubth you are doing anything wrong.. Its the burner,,
Nov 10, 2007 | Pioneer DVR-S111B DVD RW Dual Layer Burner
Computers & Internet Logo
David Payne
David Payne
