Question about Casio Cassiopeia E-125 Pocket PC
E125 Speaker Click
I'm hearing a click coming from the speaker in my E125 at the beginning of sound events or at the very beginning of audio playback. Just happens for a moment, but sounds like a power surge to the speaker prior to playback. Any ideas how to remedy this?
    Master:
  • 551 Answers
Solution to CF Recorder Click Noise Problem! Hi, ever since I got my Netbook, I was annoyed about the click noise, most Netbook users hear, when recording straight to a Compact Flash Disk. Problem To test if you are suffering from this problem, make the following test: 1. Make sure you have a CF disk in D: (or E: ) 2. Start the Recorder application. 3. Select File/New File and enter any name using the drive the CF is in (D or E) 4. Make a recording, for about 10 seconds, preferably in a quiet room without saying anything. 5. Playback the recording. You will hear a clicking sound often about once every second (varies according to CF-Card used)! 6. If you hear no clicking sound and the recording sounds clean, you have no problem! Solution I have just spent a couple of days at Photokina (the world's largest photographic trade fair currently on in Cologne, Germany) visiting CF-Manufacturers with my Netbook to get to the bottom of the problem. Basically, the problem is caused by the buffer in the CF-Controller emptying faster than it is being supplied with data. This affects a lot of CF card manufacturers and the only solution (apart from recording on C) is to use a CF card with an Hitachi Controller as that is the only controller which takes account of this problem and handles the data stream correctly. I tested a number of CF-Cards at the show (only Dane-Elec refused to let me test their card) and this is the result of my hard work: CF-Cards that Work Correctly: SimpleTech (all SimpleTech CF-Cards use the Hitachi Controller) Casio (Hitachi Controller) Hitachi (of course) DataFab (the sample I tested worked, they did not know which controller) Extrememory (Some work, some do not) Note: Large CF-Cards can still have problems. Even the SimpleTech 512MB CF-Card produced the click noise whereas the 256MB card was OK! CF-Cards with Click Problem: Sandisk (incl. Ultra) Toshiba (all 3 controllers tested) Dane-Elec (not tested, but uses Toshiba controller) Those were the cards I tested. Perhaps the members of this forum can post their findings on other makes not mentioned above. I personally made the mistake of buying a Toshiba card and had no end of problems. I must say that the people at Toshiba were very helpful and let me test a range of their cards. I will now be returning my Toshiba card and ordering a CF-Card from Simpletech as the cards I tested worked well. I have no connection with any of these card manufacturers! However, I do recommend that before buying a CF card for the Netbook, from any manufacturer, you should always do the above test, first! Remember, in most cases I could only test 1 card per manufacturer so each card could differ. Test before you buy is very important in this case! I hope this helps!
Posted on Sep 05, 2005
Kenwood A722L no sound and volume led blinking
This could be due to a faulty speaker relay (if your unit uses one). Normally, the unit will "wait" a couple of seconds after you turn the unit on. Then you will hear a "click" and the sound will begin coming through the speakers. If the relay is faulty, it would cause the problem you describe.
Aug 01, 2014 | Kenwood Audio Players & Recorders
Audio not coming after installing driver
First, make sure you installed the correct driver.
Then go to the control panel and under "sound" check to see if the speakers are muted. Also, check the speaker volume.
Go to the sounds tab and see if, when you click an event that has a sound assigned to it, the little arrow for preview is dark. If it is dark and the volume is up and not muted, you should hear sound. If it is grayed out, you your computer doesn't recognize the sound card or drivers.
Aug 30, 2011 | Lenovo 3000 N100 0689 Notebook
When i press "matrix" i hear no sound coming out
you might try uninstall both the sound card and its drivers then restart your computer before reinstalling them only do this if your sound card and its drivers have these on a disc
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
Jan 25, 2011 | Logitech X-540 Computer Speakers
We hooked them up to a Dell computer, but there is no sound. We checked the audio drivers and they are all working properly. What can be the problem and possible solution?
You can try to plug in an external headphone to see if the issue is with your sound card, if external headphone works, obviously the speaker is faulty but if same problem persist. Check if your using an expansion sound card (usually for gaming computers) and make sure it was set primary sound device on BIOS and the integrated Audio is disabled. On windows you can check the sound settings on playback make sure that primary Audio Device is Set to default and no Hdmi Sound Audio is connected Hope this can help you!
Dec 07, 2010 | Dell A215 Computer Speakers
I dont have sound in my computer.how i know what is required
Please perform the following tests to isolate your sound problem.
Following is the keyin sequence for Windows XP - The key-ins will differ somewhat for other Windows operating systems:
Click on START
Click on CONTROL PANEL
Select the Classic View (If not already displayed)
Click on SOUNDS AND AUDIO DEVICES
Double Click on AUDIO DEVICES
Click on the AUDIO tab.
In the Sound Playback dialog box your sound device (AC 97 Audio) should be listed. If it is not, click on the pull-down menu and select it if you can..
If it is NOT listed, perform the checks listed under CORRECTIVE ACTION in this procedure.
If it is listed, perform the following tests:
Click on the SOUNDS tab
Set the Sound Scheme to WINDOWS DEFAULT
Click on APPLY and OK
In the Program Events dialog box, click on any event that has a speaker Icon to the left of it
Underneath the Program Events dialog box you will see a small box with a triangle inside
If the triangle is black that means that the operating system has recognized your sound playback devive (sound card).
Click on the triangle.
You should hear the sound through your speakers (the triange will change to a rectangle while the sound is playing)
After the sound plays the black triangle will re-appear.
If the triangle is black and changes to a rectangle when you click on it and you DO NOT hear sound through your speakers either your speakers are plugged into the wrong jack or you have a problem with your speakers. Test or replace the speakers.
If the triange is gray that means that the operating system does not recognize your sound playback device (sound card). Perform the apropriate corrective action below.
CORRECTIVE ACTION
If the playback device is built into the motherboard, the device may not be enabled in the BIOS. Check your BIOS settings. If your sound device is disabled, enable it and repeat this procedure.
If your playback device (AC97 Audio) is enabled you may require a driver update and it's time to seek some professional help from a qualified PC Technician.
If you believe that this information was helpful to you, please rate me on the FiXya website.
Regards,
Yavacotech
Nov 29, 2010 | Intel 845GE Motherboard
I can only hear the person I am talking to through headphones, I want to hear them on my speaker
To solve this problem ,do this; goto start menu >control panel>sound and audio devices
in volume tab under speaker settings , click on "advanced" in speakers tab speaker setup:select desktop stereo speakers
click performance tab Hardware acceleration =full sample rate conversation quality=best. click on apply,and ok
select audio tab in sound and audio output. click on volume ,unmute all . increase all volume to high. close it.
select voice tab in click on volume ,unmute all . increase all volume to high. close it.
click on apply and ok.
then open your audio manager .increase play back volume and unmute all .
important :select default device (sound play back) .to your audio manager's default device . after apply all settings .click ok and close it. in sound and audio output. tick on "use only default devices". . do it and solve it
Sep 08, 2010 | Skype IM
My laptop brings out no sound
Go to the Control Panel - click on Sounds and Audio Devices - click on the Sounds tab - click on any of the Program events and click the play button. If you hear a sound from the speakers the audio driver is correctly installed. Also connect a headphone to the laptop and repeat this test.
If you don't hear any sounds and the play button is greyed out, it means the correct version of the audio driver wasn't installed.
You can check if this is true - go to Control Panel - System - Hardware tab - Device Manager and look for any devices that have a yellow ? against the device. This indicates a device driver is required to make this device work.
You need to download the correct device driver for your model laptop, and it must be a XP or Vista version that matches the Windows version that is installed on your laptop.
Jun 03, 2009 | Acer Aspire 1642ZWLMi Notebook
Plz i wanna help,my computer toshiba satellite m35x-s149 does't have sound,plz send me the programme for download.thanks
We need to know what is happening when you try to play a sound.
Do you hear anything?
This is a laptop and you can turn the sound on and off by using your keyboard--pressing the function key at the bottom left of your keyboard and then pressing the sound volume key which is one of the function keys at the top of the keyboard (the ones with the little speaker pictures on them).
Your Toshiba may also have a volume control on the side of the machine.
You must also check the control panel (the icon that says sounds and audio devices). Does it show a sound device when you click on it? Check to see if the "mute" box is checked. If so, uncheck it.
When you click on the Sounds tab, can you see Windows events at the bottom of the screen with little speakers beside them? If so, can you click on one of the events and then click on the right arrow just to the right of the sound events? Is the arrow dark or light when you click on the sound event? If it's dark, you should hear the sound. If it's light, you need to go to Toshiba's website and download the correct sound drivers for your computer.
Jan 29, 2009 | Toshiba Satellite M35X-S149 Notebook
No sound comming from audio volume
First check if you have the speakers pin (green) connected in tothe proper green socket on the back of the computer.
If yes, then right click on the sound / speaker icon that is near to your clock on the right bottom, and click "Adjust audio properties"
Now click the sounds tab in the audio properties.
Select any sound from the list under program events, and click the play button near the browse button. It should play a sound.
If you are not able to hear any sound BUT the play icon changes to the stop icon for a few  moments, it means the sounds play alright but something is wrong with the speakers or the connections.
HTH,
Deboo
Jan 18, 2009 | E-Machines eMachines Refurbished EMA...
Audio do not play
Unplug speaker connection. Go to Control Panel, double-click on "Sounds and Audio Devices" and on "Volume" tab make sure "mute" is not checked and that volume is sufficiently up there. If thats ok select "Sounds" tab and go to "Program events", select any Windows sounds and check to see if you can hear the sound by clicking on the arrow next to it. If you can hear sound its ok so then check your speakers connection to correct sound output jack and that external speaker is powered on.
Dec 29, 2008 | Dell Latitude D500 Notebook
Open Questions:
Casio Cassiopeia E-125 Pocket PC Logo
94 people viewed this question
Top Casio Computers & Internet Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
