Question about Saeco Incanto Classic Espresso Machine
Incanto coffee button blinking
The green button for making a big cup is green and when I press it instead of making me coffee it start blinking fast and the grinder does no work.
no coffee comes out.
preground is working fine
  • amosamos Aug 28, 2008
    no, it's the same .... grinder does not work
  • 515 Answers
Can you brew a small cup?
/Mirran
Posted on Aug 27, 2008
  • Mirko Blas
    Mirko Blas Aug 28, 2008
    I think there will be something with your grinder.
    It can also be a microswitch that not is working and have to be replaced.
    /Mirran
Coffee is too strong. How to dose Saeco Incanto classic? i tried to adjust SBS and beans regulator but coffee is strong and big coffee fills only quarter of cup.
press and hold the big coffee button while coffee is making,when you thing that amount is enough ,take of yuor finger ,Thats it. Next time just press the big coffee button once .
Sep 29, 2013 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Rondo right red light is on and I cannot make coffee. The machine grinds the beans but does not dispense any coffee.
Try to set the machine to grind finer. Common problem with this machine when the grinder grinds too coarse, and the coffee will not fit in the brew unit during the cycle. Grinding finer will allow the brew unit to compress and the machine should complete the cycle.
If this does not work there may be another thing to try, Let me know support@cerinicoffee.com
www.CeriniCoffee.com
Apr 09, 2011 | Saeco Incanto Rondo Fully Automatic Coffee...
The machine pours too much coffee for an expresso and even for a normal cup. We have been using it for 3 years and this just started a few weeks ago. I reset the machine to factory settings and it still...
You don't mention if you've programmed the quantity since it started behaving strangely, so....
instead of pressing the 'coffee cup ' icon button once, hold it down all the way through the brewing procedure (it will bip) until the correct amount of coffee has been pumped into your cup, then release the button. This quantity has now been programmed into the memory and should produce the same amount of coffee every time, on a sigle press.
Mar 04, 2011 | Saeco Incanto Sirius Fully Automatic...
One of the coffee buttons does not work. If I
The only thing that comes to mind is the grind, it might be to fine or the amount of coffee being added to the brew chamber.
Feb 25, 2010 | Saeco Incanto Classic Espresso Machine
SAECO Incanto Type Sup021 grinds and jettison grounds - no coffee
Here's how to fix your problem, remove the brew unit and clean the shower screen located at the top, under the red o-ring. Remove the screen and clean, then try coffee again this time adjust grind about 2 numbers coarser.
Jul 30, 2009 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Issue
Make sure the magnet in water tank flow up when you fill it with water.
Let me know if you need any instruction.
/Mirran
Aug 15, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Incanto not grinding
Hi Chris,
The leaking is your steam valve that has to be replaced, you can see this if you open the door and look up in the right corner there you will see water drip.
If not then you have a pipe or boiler leak.
How old is your machine?
How often do you descale the machine?
When you try to make a cup of coffee, starts the grinder for two seconds or is it dead?
Hope this will help you.
Jul 19, 2008 | Coffee Makers & Espresso Machines
Saeco Incanto
how tight is the coffee packed in the dripper, the flow rate is determine by how tight the coffee is, thats why you always see the barista press the coffee against the disk of the grinder dispenser in a coffee store
Jul 06, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Incanto -- no coffee coming out
After I posted this I decided to descale the machine again, even though I'd just done it a couple of weeks ago. After descaling and rinsing I tried running water through the brew group by pressing the pre-ground button, then holding down the big cup button. Still no water, but then I turned the little knob on the coffee dispenser counterclockwise, about half a turn. It worked! I rinsed it well, then made a cup of delicious espresso.
Mar 01, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Classic Espresso Machine Logo
90 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
