Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire Front Load Washer
It filled with water but no water for the rince and spin.
I try to start and it will not fill with water. The timer seems to be moving but no water to rinse.
  • 89 Answers
Your timer has contacts inside of the main module that makes your machine switch cycles even though it may be going round the contacts are probablyeither burnt or carboned up so bad they are not making contact the fact that it is going round pretty well confirms with me thats your whole problem good luck
Posted on Aug 26, 2008
MY FRIGIDAIRE FRONT LOAD WASHER WONT FILL WITH WATER OR SPIN . HAVE TRIED CLEANING THE DOOR LOCK & UNPLUGGING IT FOR EXTENDED PERIODS OF TIME.
Sounds like the fill water solenoid has bust, they are cheap to replace and fairly easy. make sure you disconnect from power supply and water supply before trying.
Jan 30, 2014 | Frigidaire GLTF2940ES Front Load Washer
My washing machine fills up with water, but want start washing after it fills. I can turn the knob to rince, spin, and drain, and it works. What is my problem? Is the timer ok?
Yes, i do agree, the timer will be the problem. Everything runs through the door limit to start then through the pressure switch then to the timer. The fact that you cag get the motor to spin when forwarding the timer means the pressure switch must be ok.(im taking it that the water switches off when required water level is reached. Also, if water does not switch off, make sure the drain pipe is the same height as 3/4 the tub height
Aug 20, 2010 | Frigidaire GLWS1233A Top Load Washer
My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
Hello there:
If your cycle does not complete or The cycle doesn't advance
When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire washer starts to fill with water then stops
That is not the solution.
Start the machine and immediatly press the "Start" and "Pause/cancel" button at the same time. Then you will get and ERROR code. Look on the cheat sheet packed with the machine to find out what is really wrong. That will give you the real answer.
Appliancepartssuppliers.com
Sep 20, 2009 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Frigidaire FTF530F won't advance
Possibly the timer. next time it wont stop filling turn off the washer. if it still fills you have a water valve issue. Hope for the valve. Timers are big bucks.
Jan 24, 2009 | Frigidaire FTF530FS Front Load Washer
Whirlpool AWO3761 stuck mid-cycle
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • Jul 06, 2008 | Whirlpool AWM6100 Front Load Washer
    Frigidaire front load washing machine won't stop filling
    it sounds like your water valve is bad or you pressure switch is bad or hose from pressure switch to tub is cloged
    Feb 07, 2008 | Frigidaire ATF6000ES Front Load Washer
    Frigidaire ATF6000ES Front Load Washer Logo
    Top Frigidaire Washing Machines Experts
    Electrolux
    Electrolux
    Richard Roth
    Richard Roth
    Dan Webster
    Dan Webster
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
