Question about JVC Cybercam GR-D200US Mini DV Digital Camcorder
Can't transfer dubbed audio (secondary sound) using firewire.
Hi, I dubbed secondary sound track on minidivi which had movie along with original (primary) sound. When I transfer the movie using USB on my PC and play back, I can hear both primary and secondary (dubbed) audios . but When I do the same transfer using Firewire (IEEE-1394), i can't hear secondary dubbded sound in the playback. I am using sony TRV-33 camcorder. USB is using USB sound card and firewire should be using IEEE-1394 sound card (I guess !!) Is it something wrong with firewire cable or something else ?
    Master:
  • 473 Answers
Audio Dubbing on DV: Here's how you do this: Play your tape on the TRV-9 and feed the signal into the TRV-900, using the Firewire connector. Set the TRV-900's audio option to record in the 12-bit mode. When this is done, you will have the video re-recorded on the TRV-900 and the audio laid down on the primary 12-bit audio channel. Then, you can run the tape back through for a 2nd pass in the TRV-900, with the recorder set to the audio-dubbing mode. The audio you put into the TRV-900 this time, will be recorded on the secondary 12-bit channel. You can select either 12-bit channel when you play the edited tape back or you can mix both stereo channels into the output. Once you record on the 16-bit channel, you can't dub audio back onto that recording, without erasing the original channel, as the recording space for both 12-bit channels is occupied. You can't selectively re-record just audio onto the 16-bit channel either, without the video being re-recorded along with it. Both video and audio are sent over the same Firewire connector, so you can't input them from mixed sources, as you can with analog recordings. Only the secondary 12-bit audio channel can be used in the audio-dubbing mode. You can't dub onto the 16-bit channel or onto the primary 12-bit channel. The primary 12-bit channel can be used only when you're recording video along with it.
Posted on Sep 05, 2005
How do you record without sound
There does not appear to be any provision on the camcorder menu, to mute the audio.
As an alternative, I would recommend you connect the camcorder to your computer or laptop (via firewire if possible) and transfer the footage onto your computer's hard drive.
You can then use your computer's Movie Maker application to edit the footage - here you can either remove the audio track, or overlay your new audio soundtrack.
Good luck !
"if this has helped you, please rate this solution"
Dec 03, 2009 | JVC GZ-MG330 HDD Camcorder
Cant use my sony dcr h30e because i'm using windows vista
Why do you need that **** software from Sony?If you have a firewire port on your computer and a firewire cable you can transfer your footage with Windows Movie Maker.In Movie Maker you can choose the DV-AVI option to preserve the full quality of your footage.Later you can use the DV-AVI in Virtual Dub/After Effects/Premiere for editing or encoding.
Mar 14, 2009 | Sony Handycam DCR-HC30E Mini DV Digital...
JVC GR-D870 digital camera, how to transfer Min Div tape to PC
Hi, You need to use 4 pin firewire cable to connect to the PC. Switch on the cam. Open Windows Movie Maker and import the video from device.
Dec 28, 2008 | JVC Cybercam GR-D200US Mini DV Digital...
Can't record audio
I have converted home videos on my PC this way. I have a Sony camcorder whose output connects
to my firewire card in the PC. I also use windows Movie maker. While it is recording, I don't hear the audio. After saving the file and playing it back, I hear the audio, along with seeing the movie. Windows movie maker allows me to stop, start, and record the movie. It has complete control over the
Sony camcorder by using the firewire port on the PC.
Dec 21, 2008 | HP Pavilion Media Center TV m7350n...
Difference between 16 & 12 bit analog signal
In audio 12 bit selection, you can add audio (audio dub) without deleting or damaging original sound track. Like narrating some introduction in your voice and keeping background / original sound as well. 4 bit difference is used to add additional sound in same sound file without deleting previous audio data.
16 bit audio selection will not give you this option and audio-dub option will be disabled. If you want to add more audio, you have to over write complete sound track in movie file.
I'm not sure that I conveyed it to you correctly. Need further info, let me know.
Dec 18, 2008 | Canon DM-XM2 Mini DV Digital Camcorder
Transferring VHS-C tapes from a Panasonic NV-RX14B to my PC
Search Ebay for peripherals to transfer tape to PC - they come with all leads and software.
Mar 28, 2017 | Panasonic NV-VZ14 VHS-C Analog Camcorder
Cannot transfer video to Laptop computer through USB
try getting a ExpressCard or if you have a later modle try a CardBus that has firewire then use a firewire cadle to transfer the video
Mar 11, 2008 | JVC GR-D290 Mini DV Digital Camcorder
Sound dubbing seems off
Is this only on some movies? Look to see in your options is you have and decoder settings. What audio format do you prefer, DTS or Dolby?
Sometimes you may get a unit in which the decoder is faulty. If you have warranty options, first use those to get you a new unit.
Jan 06, 2008 | Philips DVP3040 DVD Player
Recording sound on video.
Audio Dubbing may vary by model. Most Digital Camcorders are equipped with this feature. To verify that your model is, please view the User Manual. Audio Dubbing * The AUDIO DUBBING function only works in PLAYER Mode. * You can add sound to the original sound on a pre-recorded tape, recorded in SP mode with 12bit sound. * Use the internal and external microphones or other audio equipment. * The original sound will not be erased. Dubbing sound 1. Set the camcorder to PLAYER mode. * If you want to use an external microphone, connect the microphone to the external MIC input jack on the camcorder. * When you wish to dub using the External A/V input, connect the AUDIO/VIDEO cable to the camcorder by inserting the cable jack into the A/V in/out terminal at the left side of the camcorder. - Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. - Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. 2. Press the (PLAY/STILL) button and find the timeframe of the scene to be dubbed. 3. Press the (PLAY/STILL) button to pause the scene. 4. Press the A.DUB button on the Remote Control. * A.DUB will be displayed on the LCD. * The camcorder is in a ready-to-dub state for dubbing. 5. Press the (PLAY/STILL) button to start dubbing. * Press the (STOP) button to stop the dubbing. Notes: * You can not use the audio dubbing function while playing a write protected video tape. * When you wish to dub using the External A/V input, you must connect the AUDIO/VIDEO cable to the audio system from which you wish to record. * You cannot dub sound on a pre-recorded tape in LP or 16 bit mode. Dubbed audio Playback 1. Insert the dubbed tape and press MENU button. 2. Turn the MENU DIAL to highlight A/V. 3. Press the ENTER button to enter the sub-menu. 4. Use the MENU DIAL to select AUDIO SELECT from the submenu. 5. Press the ENTER button to enter the sub-menu. 6. Using the MENU DIAL, select the AUDIO playback channel. Press the ENTER button to confirm the audio playback channel. * SOUND1 : play the original sound. * SOUND2 : play the dubbed sound. * MIX(1+2) : play back SOUND1 and 2 equally mixed. 7. To exit, press the MENU button. 8. Press the (PLAY/STILL) button to playback the dubbed tape. Note: When you playback added sound (SOUND2 or MIX mode), you may experience loss of sound quality.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
To Transfer from DV Camcorder to PC
hi, I bought a firewire cable and a card and it is possible to transfer movie from my camcorder to pc.
Sep 06, 2005 | Panasonic AG-185 Camcorder
JVC Cybercam GR-D200US Mini DV Digital Camcorder Logo
182 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Marvin
Marvin
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
