Question about HP OfficeJet 6210 All-In-One InkJet Printer
Power Failure Unit clicked off and won't turn on! Power supply checks with 16/32 v. Is there a fuse? Phil
  • 40 Answers
Phil try to plug-in the powrcord directly to the wall and then touch the power module after having it plug-in in the power outlet if you could feel that there is a change of the temperature of the powermodule it shows that this is working but if no change on its temperature the power module is not working and needs to be replaced....
Posted on Aug 31, 2008
  • neil  delmonte
    neil delmonte Sep 04, 2008
    what do you fuse phil??on the power module itself???i dont have an idea bout the composition of the powermodule...just try to touch the module if the temperature will change it show that its working fine...but if not it needs to be replaced...
Panasonic TH37PX80B tv won t turn on
Probable power supply failure.
Apr 02, 2014 | Televison & Video
Won't turn on
if no any light indicator at the front panel of the monitor, the cause would be power supply failure. to do the check up, you must need to remove the back cover. the power supply board it was connected the power cord. look for a blown fuse and a bulging electrolytic capacitors at the power supply board.replaced those bulged capacitors, you can find at for parts replacement.
Nov 17, 2012 | ViewSonic VX2255 Monitor
Won't turn on
if no power indicator at the front panel it could be power supply failure, check for blown fuse. if just blinking look for leak or bulging capacitors then replace it.
Sep 27, 2012 | Toshiba 32C110U 32 in. LCD TV
Tv won't turn on
This can be failure off the main power supply which is a switch mode power supply- SMPS. So please check the link for tips but attempt to open the TV and check only if you are equipped.
click on:
Oct 11, 2011 | Polaroid FLM-3732 Television
My 3 year old Sanyo DP50747 tv quit, and now won't come on at all!
Possible failure of the main power supply for the circuit. If you are equipped and have the tech to probe then you can check on the SMPS- switch mode power supply - unit of the TV.
click on :
Aug 11, 2011 | Sanyo DP50747 50 in. Plasma TV
IT Won't power up.
Possible failure of the main power supply unit which is a switch mode power supply.( SMPS).
You need to disconect the power supply to the printer and open the panel to check the SMPS unit.
Please check on the link below for tips to check the SMPS unit. If this is not possible check with a power supply unit to confirm before you order.
Jul 29, 2011 | Kyocera Mita FS-C5016N Printer
Vizio plasma tv will not turn on by button or remote, cable box is lit. We had a loss of power last night due to a storm. What do we do to check it.
hi usually the cause of won't power on problem due to the storm is the current fluctuation which the tendency is power supply failure. now since totally dead set what you need is to open the tv unit then look for the power supply where the power cord is connected. check obvious defective component part like blown fuse and burnt part like resistor and capacitor. just replaced with the same value and ratings to avoid damage from others component.if their is no problem with the power supply the output voltages are good the main board get damaged. good luck thanks for consulting the fixya.
Jul 14, 2011 | Televison & Video
Have a samsung 32in flatscreen that i unpluged and when i pluged it back in it will not come on
hi just unplug again don't use for an hour to discharge excessive voltage store at the power supply usually at the primary capacitor and also to reset the processor which turn on/off the circuit.while you are waiting to discharge the voltage check the power outlet try to plug other equipment just to let you know if the power source is good. now if it is present try to plug and turn on the unit observe if it is working.if still won't power on you will need to open the back cover keep the screw not to loose check first blown fuse at the power supply if no light indicator at the front panel when you turn on the unit it was power supply failure because no stand by supply. check bulged capacitor replace with branded parts use with high temperature rating capacity 105c.check also other obvious defective part. you can order parts at hope it will help you thanks for choosing the fixya good luck.
Jun 24, 2011 | Samsung Televison & Video
Red light flashing, no picture/sound!!!!
HI, this unit has 3 main fuse links on the main board that may be blown. the fuse links should be check before you move further into the diagnosis stage. once you have checked the fuses and they are still in a working state, this will confirm a power supply board failure. this board provides and regulates the current flow and distribution of it throughout the entire unit. If the fuses are fine and the power supply board is damaged, the green light will come on briefly then, the main control will notice that the power supply is not functioning properly. Once the main control board senses an abnormal current, it will shut down the TV rendering the red light warning. The list of fuses to check are below. Remember, if they are fine and working, the issue will be the power supply board itself and, it will need to be replaced.
3A 12v- fuse----(242208600623)
SM 3A 125v-fuse----(242208600657)
500 MA-fuse-----(242208611092)
Please rate and god bless:)
Apr 13, 2009 | Philips 42PF9631D 42 in. Plasma Television
Sounds like the door switches are out of adjustment or broken. There is only one main fuse, so if you have a display, it must be OK. Could also be a failure in the high power that runs the magnatron plus the lamp.
I would take it to a shop for repair. Microwaves are almost always repaired affordably unless it is really old.
Hope ya fix it!
Feb 04, 2008 | Microwave Ovens
HP OfficeJet 6210 All-In-One InkJet Printer Logo
81 people viewed this question
Ben Johnson
