Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Water Depenser To Whom This May Concern: Water despenser does not work. old model does not work? Trying to install. with parts from Home depot, The only numbers I could find were 218875160? misswilla@sbcglobal.net
  • Anonymous Sep 05, 2008
    unplugged the refrigerator for a day to thaw it out and now the water dispenser is not putting out any water
  • Frigidaire Master
  • 5,568 Answers
As far as I know, all icemaker-equipped fridges have a filter in line with the water supply and if you have any sediment in yur lines, the filter may be clogged and due for a change.
Posted on Sep 15, 2008
How do I fix toilet almost overflowing?
This is the part that you need,easy to install,your's is the old type,just turn water off,then flush,then remove excess water and install,has instructions with it,Walmart,Home depot,or Lowe's has it,cost less than 10 bucks,I use these.
Jul 26, 2015 | Home
How do I replace DA97-08118n?
Hello Fred;
My name is Peter. I am a retired field service refrigeration technician.
Samsung has a lot of different models.
Send me the model number. It should be on a label on the wall of your fresh food section
Nov 11, 2014 | Samsung Refrigerators
I have a Power Star electric hot water heater, model AE 125, serial # 39-203967, model 45-55130. purchased 5 years ago at Home Depot for $850.00. I love the heater when it works. This is the second time I...
Bosch has 10-year limited warranty.
Probably the seller honors warranty first 90 days and Bosch afterward.
I think warranty is similar to car warranty where parts are covered, and they pay for parts to patch up the blown transmission but not give you a new car. But I hear of cases where the company just send a whole new Tankless unit and you install it yourself.
Contact Home Depot and present them with receipt.
Contact Bosch with the same information given in Fixya question.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Add a comment and say why unit broke down first time, and add what resolution was reached to help others with same question.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 02, 2011 | Bosch PowerStar AE125...
How do i clean it it has white water stains and we have soft water and i can not find my manual. about 3 years old double kitchen sink black from home depot
Question...is this a black enamel coating on the sink? If so, be careful not to use abrasive cleaners on the sink or it will scratch the finish. Hard scrubbing will do the same if the cloth/sponge that you are using is somewhat abrasive. I have used "Lime away" or "CLR" and both have worked fine for me. You can get these solutions at Wal-Mart, Home Depot or Lowes. Note that this will continue to stain unless you resolve your water issue. This may be done by getting a "Home water filtration" device installed. This can be pricey though. Good luck.
Jan 20, 2011 | Pegasus Technologies Home
No water flow to ice maker or water despenser...water lines are clear the filter is clear..could problem be water inlet valve ( dual valve controls water flow to ice maker and water despenser.
Its odd that both parts of the valve went bad at the same time. Personally sounds as if your water filter is clogged up and needs to be changed. I would do that first, before trying to change the water valve itself.
Dec 08, 2010 | Whirlpool Refrigerators
How to install a new regulator?
You can buy the regulator at Home Depot. Just cut the gas hose off at the old regulator and put new regulator on with a hose clamp. $200.00??? Somebody is trying to rip you off !!!!!
Jul 23, 2010 | Weber Genesis Silver B Grill
Ice dispener not working
Is ice in depenser? is despenser blocked? Sometimes a few cubes get too big and block it open.. becareful with your fingers. If all this checks out, then check all connections.
Jul 07, 2010 | Frigidaire FRS3R5EMB Side by Side...
LG Dishwasher - drain hose replacement
Hello, I have just installed a similar model, and took the side panel off to see how it was put together ;)
The drain hose goes in the back of the dishwasher, then loops up the right side (as you are looking at the front)(this is to act as a "trap" to keep sewer gases from coming back into your washer, I assume), and then connects to the drain pump under the washer.
In order the change the hose, you will need to remove the left side panel, and the bottom panel, and this will give you access to the entire hose....
Hope this helps!
Nov 26, 2007 | LG LDF8812 Stainless Steel Built-in...
Ice despenser door not opening
I had this problem. There is a piece of ice jammed in there that is blocking the door. try pouring some warm water into the hole from the inside and naking sure the path is clear.
Apr 14, 2007 | LG LSC26905TT Side by Side Refrigerator
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
73 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
