Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire Front Load Washer - does not rinse and spin
It goes through the wash cycle but no rinse or spin?
Thanks
Karen 951-506-3220
karen.pack@erdas.com
  • 89 Answers
Sounds like the timer went out replace it should solve problem
Posted on Aug 26, 2008
I have a top loading Haier washing machine. Model HWT10MW1and I'm hoping you can help.
unless the machine has a programmable board , I doubt it
talk with the Haier service people and ask if there is a programmable board or what you is what you get
Feb 04, 2018 | Haier Washing Machines
Hi,I used dettol to clean washing machine but my clothes smell of dettol now. Do I need to air washing machine well before using? Thanks
Hey Karen,
Try using straight Clorox instead of detergent...(with a couple old white towels that you can spare).. then run the "clean unit" cycle with bleach - makes mine smell clean... :).. then run a rinse cycle with nothing added,,, clean machine and clean smelling..
Jun 20, 2017 | Washing Machines
My washing machine top loader once reaches the spin cycle, with 21minutes time remaining, it goes back to rinse and repeats the cycle. What is the problem of my washer and how do I fix it? Thanks
If the washing is not distributed evenly by the time it reaches the rinse/spin cycle, it goes back to rinse cycle. Be present at the machine when it reaches the spin cycle. observe the drum to see if it is of balance and swaying to the sides, if so distribute washing evenly. Usually happens if there is a big garment or more with smaller items,
Regards
Phillip
Oct 06, 2014 | Samsung SW62ASP Top Load Washer
Why won't my 4GLTF2940FS front load washer will not spin. It will go though a wash cycle, but when it is time to drain/spin the load it immediatley goes to No Spin, then shuts down. The water drains
Hello friend, I appreciate your post!
Based off the information you have provided if your Frigidaire washer is draining and rinsing but not spinning it could be an issue with your timer or motor. I would reset your appliance by disconnecting power to it by unplugging it or flipping the household circuit breaker for ten minutes. If that does not work I would recommend having a technician out to the home to properly diagnose and repair the appliance, since it could be any one of these underlying issues. Hope this helps. -Matt
Jul 28, 2014 | Frigidaire GLTF2940FS 3.5 Cu. Ft. Front...
How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin Read more: How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin | eHow.com http://www.ehow.com/how_6496482
Hello - Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned, or you have another issue with the door lock assembly or the timer and control board not communicating correctly. Contact a professional to move forward accurately.
Oct 21, 2012 | Frigidaire Affinity ATF7000E Front Load...
Can someone please call me karen jones 07 54 996 781 thanks :)
Karen !
Well, somebody called you Karen. Ahahaha..
Feb 02, 2011 | Samsung Washing Machines
My LG front loading washer makes a train noise during the rinse cycle. What could be the cause?
if it is right after the drain cycle; it then goes into a spin. It then starts to fill with water for the rinse while the tub is still turning. The water entering the tub while the tub is spinning, cleans the tub of soap and the water going through the holes in the tub are causing the noise. It is normal if only in the rinse cycle.
Aug 29, 2010 | Frigidaire GLTF1670A Front Load Washer
My neptune washer is stuck in pause mode I can't set it any any wash mode to wash a load the start/pause light just keeps blinking. Is there any way to reset it or boot it to get it started again thanks...
Karen,
Power it down by pulling the 120VAC power cord to the washer then plug back in and see if it will progress with the wash cycle. Which machine do you own the FAV6800A LED console display or the FAB9800A LCD console.
If still no good I will have you try to get into Service Mode but let’s see if a power cycle will clear the issue…….Rich
You will need the Service Manual for reference. Sears Parts Direct for reference.
May 21, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My front Loading Frigidaire Washer goes throu all the wash & Rinse cycles, but it wont Spin the wet clothes out!! Any Help? Thanks...
Likely the timer has failed - but check the motor controller first. Also the load balance sensor may be on its way out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
122 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
