Question about Hitachi 53FDX01B 53" Rear Projection Television
Lightning strike Lost picture and sound. All leds on power board are lit. led is lit on big board where the secondary power feeds in. The led next to the high voltage coil doesn't light. Was wondering if the strike hit the antenna input and fed through the back door, or went through the power supply. one voltage reading is -38 volts were the block diagram says should be +39. Should I purchase a schematic fo $20 or is there a site with free downloads? Don't know where to find a test point on the secondary power supply. Old TVs used to say the voltages on the boards where test points were.
  • 927 Answers
Good Day;
Make sure when measuring voltages that your'e on the proper ground, all TV's this day has two grounds. The HIT has #'s near the components, LED's that light or do not light. YES, get info to trouble shoot further.
Good Luck, big IRISH.
Posted on Sep 08, 2008
Hisense 50k22dg should i replace led strips first or power board
I would inspect the power board for mushroomed caps and brunt traces. A edge lit led screen has two ribbon cables coming from the power supply, I would unplug one at a time to see if one side lights up. Both led strips rarely go bad at the small time. The problem is most likely in the power supply.
May 02, 2017 | Hisense Televison & Video
I have a LED TV that was hit with a power surge caused by lightning.
Could be your household insurance would cover the damage.
Unless the lightning strike was very local to you, on your side of the local substation, the responsibility for the cost of repair or replacement could be the power company's.
Surges from lightning strikes aren't supposed to get past the electrical substation.
Old-fashioned valve tvs and radios sometimes survived huge surges on the powerline and even minor lightning strikes to the antenna but solid state semi-conductors and micro chips aren't very tolerant to overloads of any sort. These days a tv is not longer a tv in the conventional sense but like cars and radios should be considered as just another computer that is full of CMOS chips which are extremely sensitive to overloads and static discharges. Even the screen of your tv is made up of semi-conductors.
I would be very surprised if the set isn't a write-off.
Sep 04, 2015 | Samsung UN55C6500VFXZA 55in Led Hdtv 1080p...
Lightning strike. TV powers on, solid red power LED, No picture on any input
Main board fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 22, 2014 | Panasonic (TH-50PZ700U) Television
Toshiba 37AV500U damaged thru HDMI input.
The lightning stroke has been effected to the main digital board to your TV. It will be best to replace the main digital board as card basis, rather than trying to repair it. Before replacing the board, a through checkup should be done. Contact any expereienced service technician for help, as this work is a very skilled one. No body can predict about the damages to a lightning stroke, as there will be trillions of voltage present for every stroke, and even a slightest voltage can damage so many components in a TV like equipment, as it is designed to work for 110 or 220VAC.
Jul 07, 2012 | Toshiba 37AV500U 37 in. LCD TV
Was watching tv lastnight and the TV just shut off. I have unplugged it for the 30 mins that it recommends for it to rest. That didnt work. Any suggestions? Thanks
Now,the tv turn on,the front of LCD screen panel the power LED light is blinking or no power LED light indication nothing at all?Yes.The tv power supply board have problems,it dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 06, 2010 | Magnavox 32MF338B 32 in. LCD HDTV
60SDX88B. No video, No sound. DP06 Protection
not a solution but i have a 50gx30b doing something similar, no picture no sound, 3 green leds are lit up on the main board and then one red led lit up also on main board, front panel red led stays on for about 30 -50 seconds and then it all shuts off, I then have to unplug and replug to get the same results.
Mar 03, 2010 | Hitachi 60SDX88B 60" Rear Projection...
No Picture & No sound. Red LED, Green LED, Red LED.
If the power supply outputs are good! Then I would say the back light inverter is bad! If the screen stays black and does not come on.
Jan 14, 2009 | Akai LCT2660 26 in. HD-Ready LCD...
Lightning strike
Good Day;
Aug 26, 2008 | Hitachi 53FDX01B 53" Rear Projection...
DP23 LED not lit on deflection board no picture on tv
Good Day, Gil;
Your problem is in deflection circuit (115+v) check these: FP05, DP15, Q777, QH01, TH01, T701, etc. BUT suspect C707 1k pfd, 2kv, and check all the pico fuses (brown) 2" to the right of cap. Good Luck, big IRISH.
Jul 19, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Does not power on. Q951 charred
you can look for the model and brand, look for it on the internet and see if you can have the schematic diagram, you're lucky if u can. Lightning will strike first the tuner side, if there is a red blink, the primary side may be okay in switching type regulator, just replacing the charred part may not solve the problem. look for shorted components on the secondary of the power section.
May 15, 2007 | JVC AV-32230 32" TV
Hitachi 53FDX01B 53" Rear Projection Television Logo
78 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
